The title is self explanatory, I’m trying to dual-boot my pc so I can have both manjaro and win10 however this error keeps happening,(I’m a complete beginner to linux btw)
I did set a 86GB partition on my SSD for this and did set it to mount / with the flag root, and also set the other (100mb or so) partition to /boot/efi
so yeah I’m completely lost on this one
quick follow up here, when I try to use the installer again the previous “Free Space” partition is now called “Manjaro Linux (20.0.3)”, I don’t know if that’s useful or not but I’m completely ignorant so I’m posting here anyway
SOLVED: I HAD TO CONVERT MY SSD FROM BRM TO GPT FORMAT
first search for convert your msdos en GPT under windows (MBR2GPT )
do not care about your partition ext4 you will redo install after ,
1 - convert mbr to GPT ( windows , need usb windows for repair )
2 - it will create /boot/efi ( repair entry EFI for boot windows )
then you can see after for install manjaro
A- check after boot windows in your bios
–> save a profile windows
create one profile for linux with
secure boot disable
fast boot disable
no legacy
uefi only
disks on AHCI ( no raid or rst )
maybe keep USB mass storage on
B - for install ,you can recheck with commands before
then install manjaro
ok, there is MBR2GPT.exe in my pc but it doesnt seem to do anything, should I convert MBR to GPT by using a windows reinstallation with a Live USB then?
and also, this profile thing should be created in the BIOS menu ? (in my case I use a ASUS motherboard)
