When i execute “paru -S kazam”, i get this error:
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating internal conflicts...
Aur(1)kazam-1.4.5-9
:: Edit now? [Y/n]: yes
:: Downloading PKGBUILDs...
Updated PKGBUILDs
nothing new to review
getting development info....
==> Creating the package: kazam 1.4.5-9 (Tue Jun 20 2023 21:49:48)
==> Receiving the sources...
-> kazam-1.4.5.tar.gz has been found
-> configparser_api_changes.patch has been found
-> fix-PyGIWarnings.patch has been found
-> setlocale.patch has been found
kazam-1.4.5.tar.gz ... Passed
configparser_api_changes.patch ... Passed
fix-PyGIWarnings.patch ... Passed
setlocale.patch ... Passed
==> Creating the package: kazam 1.4.5-9 (Tue Jun 20 2023 21:49:49)
==> Checking dependencies while running...
==> Checking dependencies while compiling...
==> Removing the $srcdir/... directory
==> Extracting sources...
-> Extracting kazam-1.4.5.tar.gz with bsdtar
==> The sources are ready.
kazam-1.4.5-9: reading pkg list...
==> Creating the package: kazam 1.4.5-9 (Tue Jun 20 2023 21:49:52)
==> WARNING: Using the existing tree $srcdir/
==> Removing the $pkgdir/... directory
==> Starting build()...
Applying patch configparser_api_changes.patch...
/home/snx/.cache/paru/clone/kazam/PKGBUILD: line 46: patch: command not found
==> ERROR: A failure occurred in build().
Canceling...
error: could not build 'kazam-1.4.5-9':
error: could not build the following packages: kazam-1.4.5-9
Btw, i also tried with “pamac install kazam” but also gives error
That type of error also happens with wps-office, simplescreenrecorder
Is possible to fix that?
