The output of cat /etc/modprobe.d/linux515-broadcom-wl.conf
is
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
blacklist brcm80211
blacklist brcmfmac
blacklist brcmsmac
blacklist bcma
is
blacklist b43
blacklist b43legacy
blacklist ssb
blacklist bcm43xx
blacklist brcm80211
blacklist brcmfmac
blacklist brcmsmac
blacklist bcma
its the same, so you can remove it:
sudo rm /etc/modprobe.d/blacklist.conf
also uninstall everything:
sudo pacman -R linux515-broadcom-wl linux54-broadcom-wl linux515-headers linux54-headers
reboot
and post output from:
inxi -xN
ls /etc/modprobe.d
When I try to uninstall using the command you gave this comes
checking dependencies...
:: removing linux515-headers breaks dependency 'linux-headers' required by rtl8821ce-dkms-git
why do you have it installed? its for rtl8821ce card, which you dont have…
post output from:
pacman -Qs dkms
The output of pacman -Qs dkms
is
local/dkms 3.0.6-1
Dynamic Kernel Modules System
local/rtl8821ce-dkms-git 1.0.5.r140.gbe733dc-1
rtl8821CE driver with firmware
local/rtw89-dkms-git 1:r178.f3ea327-1
Driver for Realtek 8852AE, an 802.11ax device
so why do you have it installed? you dont have this card
I don’t know maybe i installed when I was trying the methods of other forms
you have also installed rtw89-dkms-git, which you also dont have…
remove it all:
pamac remove rtl8821ce-dkms-git rtw89-dkms-git
then:
reboot
inxi -xN
ls /etc/modprobe.d
The output of inxi -xN
is
Device-1: Broadcom BCM43142 802.11b/g/n vendor: Dell Wireless 1704 802.11n
+ BT 4.0 driver: bcma-pci-bridge v: N/A bus-ID: 07:00.0
vendor: Dell driver: r8168 v: 8.050.03-NAPI port: e000 bus-ID: 09:00.0
The output of ls /etc/modprobe.d
is
hp.conf r8169_blacklist.conf
just to be sure, post output from:
pamac list -qm
The output of pamac list -qm
is
easywifi-git
remove it too, you dont have a working wifi anyway:
pamac remove easywifi-git
then reboot
and try installing again the drivers:
sudo mhwd -i pci network-broadcom-wl
if you dont get the same error, reboot
Still got the same error
I just noticed that before in the network section I had a wifi and airplane mode options but now it is not there
i dont know whats heppening here… are you dualbooting with windows?
post output from:
find /lib/modules/ -name "wl"
sudo dmesg | grep wl
pacman -Qs manjaro-firmware
No I am not dual booting, I deleted windows and installed Manjaro
There is no output for find /lib/modules/ -name "wl"
and sudo dmesg | grep wl
The output for pacman -Qs manjaro-firmware
is
local/manjaro-firmware 20160419-1
Extra firmwares for Manjaro Linux
what is the output from this:
sudo mhwd -r pci network-broadcom-wl
The output for sudo mhwd -r pci network-broadcom-wl
is
> Removing network-broadcom-wl...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/local/pci/network-broadcom-wl/MHWDCONFIG
Processing classid: 0200
Processing classid: 0280
Processing classid: 0282
> Successfully removed network-broadcom-wl
now were going somewhere…
so reboot and post output again from:
inxi -xN
The output for inxi -xN
