I have a printer wich is connected to the wifi. In other distros i normally just click on search printers and it works. Probably is 4 the driver? or is bad connected? (Im using a repeater in other room)
Moderator edit: Removed useless screenshot and edited topic title to reflect printer series. Use words, not screenshots.
Hi @Powa ,
I recommend to read the following post in order to solve your problem. The image shows that you have installed a generic printer driver and maybe you have to install the following one:
‘AUR (en) - epson-inkjet-printer-escpr’
