I can’t rebuild v86d
I had to rebuild some AUR packages. But I got a problem with v86d.
:: la suppression de v86d casse la dépendance « v86d » requise par mhwd
The last update of v86d was in 2022… I can’t rebuild (errors on makefile)
Why mhwd still needs it ?
Edit: a lot of obsoletes dependencies required by mhwd:
mhwd-nvidia>=455 » requise par mhwd-db
mhwd » requise par mhwd-nvidia-390xx
mhwd-nvidia-390xx requise par mhwd-db
v86d
mhwd-nvidia-470xx
mhwd-nvidia-470xx » requise par mhwd-db
v86d is in the Manjaro repos, why are you building it from the AUR?
Either way, you’re right–it doesn’t build currently.
pamac indicates it as an AUR package. I dit try with git clone & makepkg.
Ok, I will only use pacman anayway.
You can simply install it from Manjaro’s repo via
sudo pacman -Syu v86d
