Greetings, I can not install anything , I think it does not connect to the repositories when trying to update the message it gives me is this:
Error retrieving community.db file 'from mirror.easyname.at: The requested URL returned error: 404 Not Found
Try updating your mirrors:
sudo pacman-mirrors -f 0
Then run:
sudo pacman -Syyu
thanks but this is the command response
::ERROR Not Found
::ERROR _ssl.c:1039: The handshake operation timed out
::ERROR [Errno 101] Network is unreachable
::WARNING No mirrors in selection
::INFO The mirrors has not changed
error: no se pudo obtener el archivo
