how i can access wayfire session via lightdm
The wayfire
is an AUR package and should install by default the file /usr/share/wayland-sessions/wayfire.desktop
that gives access from GDM or LightDM. Should work once you reboot after install.
There is an issue opened already cannot login into wayfire session in lightdm · Issue #1479 · WayfireWM/wayfire · GitHub
Anyway, you should check the documentation for configuration as suggested on their github
Configuration · WayfireWM/wayfire Wiki · GitHub
