Hi lovely community!
I am in need of help, since the last update I broke the Gnome environment. What happened is exactly the same as described in this post.
Which is marked as solved and the poster claims he updated “SO” which I believe is the libgtk-4.so.1 library.
The twist is that I am up-to-date on my system and the gtk4 package is the latest version
sudo pacman -S gtk4
warning: gtk4-1:4.18.5-2 is up to date -- reinstalling
resolving dependencies...
Packages (1) gtk4-1:4.18.5-2
Total Download Size: 8,69 MiB
Total Installed Size: 48,03 MiB
Net Upgrade Size: 0,00 MiB
:: Retrieving packages...
gtk4-1:4.18.5-2-x86_64 8,7 MiB 5,47 MiB/s 00:02 [#############################################################################] 100%
(1/1) checking keys in keyring [#############################################################################] 100%
(1/1) checking package integrity [#############################################################################] 100%
(1/1) loading package files [#############################################################################] 100%
(1/1) checking for file conflicts [#############################################################################] 100%
(1/1) checking available disk space [#############################################################################] 100%
(1/1) reinstalling gtk4 [#############################################################################] 100%
(1/3) Arming ConditionNeedsUpdate...
(2/3) Compiling GSettings XML schema files...
(3/3) Updating GTK4 module cache...
21:22 $ gnome-tweaks
Segmentation fault (core dumped)
pacman -Qi gtk4
Version : 1:4.18.5-2
Description : GObject-based multi-platform GUI toolkit
Architecture : x86_64
URL : https://www.gtk.org/
Licenses : LGPL-2.1-or-later
Groups : None
Provides : libgtk-4.so=1-64
Depends On : adwaita-fonts adwaita-icon-theme at-spi2-core cairo dconf desktop-file-utils fontconfig fribidi gcc-libs gdk-pixbuf2 glib2 graphene gst-plugins-bad-libs harfbuzz iso-codes
libcloudproviders libcolord libcups libegl libepoxy libgl libjpeg-turbo libpng librsvg libtiff libx11 libxcursor libxdamage libxext libxfixes libxi libxinerama libxkbcommon
libxrandr libxrender pango shared-mime-info tinysparql wayland bash glibc gst-plugins-base-libs gstreamer gtk-update-icon-cache vulkan-icd-loader
Optional Deps : evince: Default print preview command [installed]
Required By : baobab celluloid colord-gtk4 d-spy decibels deja-dup endeavour epiphany file-roller font-manager ghex glycin gnome-bluetooth-3.0 gnome-builder gnome-calculator gnome-calendar
gnome-characters gnome-chess gnome-clocks gnome-console gnome-contacts gnome-control-center gnome-desktop-4 gnome-font-viewer gnome-logs gnome-mahjongg gnome-maps gnome-mines
gnome-music gnome-nibbles gnome-online-accounts gnome-shell gnome-software gnome-sound-recorder gnome-sudoku gnome-system-monitor gnome-text-editor gnome-tour gnome-tweaks
gnome-weather granite7 gst-plugin-gtk4 gtkmm-4.0 gtksourceview5 ibus libadwaita libedataserverui4 libgnome-games-support-2 libnma-gtk4 libpanel libportal-gtk4 libshumate
libspelling lightsoff loupe malcontent mutter nautilus nautilus-share pamac-gtk pantheon-camera polari simple-scan snapshot sysprof tecla vte4 webkitgtk-6.0
xdg-desktop-portal-gnome
Optional For : chromium electron30-bin electron31 electron34 electron35 electron36 gcr-4 gssdp libinput libreoffice-still
Conflicts With : None
Replaces : None
Installed Size : 48,03 MiB
Packager : Jan Alexander Steffens (heftig) <heftig@archlinux.org>
Build Date : Fr 09 Mai 2025 18:57:28 CEST
Install Date : Mo 26 Mai 2025 20:05:20 CEST
Install Reason : Installed as a dependency for another package
Install Script : No
Validated By : Signature
I tried refreshing the mirrors, and doing a system upgrade but no dice, it does not work. I tried rebooting the system as well. The disk is not full, I just get the segmetation error.
sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
there is nothing to do
Please help, the system is working but only apps that are dependent on gtk4 are not, it looks exactly like the screenshot from the other post.
The poster whose thread you are referencing is a native Spanish speaker, and — like many non-English speakers — he was blending his native tongue into his English post.
“SO” in this case would be a gratuitous acronym for “sistema operativo”, which means “operating system” in English.
For that matter, gtk4 is already installed system-wide on your system, and reinstalling it won’t make any difference at all.
Please keep in mind that GNU/Linux, like all UNIX-family operating systems, is a multi-user platform. By consequence, configuration problems inside of your home directory are rarely ever related to the system-wide configuration, unless you’ve been messing with the system-wide settings — and thus, from within the root account, because a regular user does not have write access to those.
Concrete advice:
Remove electron32, which is an AUR package.
sudo pacman -Rns electron32
Update your system.
sudo pacman -Syu
Reinstall electron32 if you really need it, even though that shouldn’t be the case.
HI All,
thanks for the help here. @Aragorn I appreciate the fix for the tittle it was indeed me who broke it. Also for the clarification of what the other person meant with “SO”.
I also appreciate the help @Yochanan soundofthunder (I can only mention two users in a post) .
Anyways back to the problem at hand and the suggestions.
I actually did not have electron32 installed, that’s what I remember doing back when I broke it. I removed electron32, so that I can proceed with the system upgrade. Due to some dependency (I don’t remember which) of electron32 I couldn’t update the system.
I did install electron32-bin as suggested but still nothing. I did a reboot for a good measure, and I still have gnome not loading properly.
My system was and still is up-to-date.
I just did all of the same commands as suggested, and here’s the output
19:27 $ sudo pacman -Rns electron32-bin
checking dependencies...
Packages (1) electron32-bin-32.3.3-2
Total Removed Size: 283,50 MiB
:: Do you want to remove these packages? [Y/n]
(1/1) removing electron32-bin [#############################################################################] 100%
(1/1) Arming ConditionNeedsUpdate...
19:27 $ sudo pacman -Syu
core is up to date
extra is up to date
19:27 $ pamac build electron32-bin
Preparing...
Cloning electron32-bin build files...
Generating electron32-bin information...
Checking electron32-bin dependencies...
cp: cannot access '/var/lib/pacman/sync/download-xaNWLi': Permission denied
Resolving dependencies...
Checking inter-conflicts...
To build (1):
electron32-bin 32.3.3-2 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Authenticating as: user
Password:
Building electron32-bin...
==> Making package: electron32-bin 32.3.3-2 (Fr 30 Mai 2025 19:27:45 CEST)
==> Retrieving sources...
-> Found electron32-chromedriver-32.3.3-x86_64.zip
-> Found electron32-32.3.3-x86_64.zip
==> Validating source_x86_64 files with sha256sums...
electron32-chromedriver-32.3.3-x86_64.zip ... Passed
electron32-32.3.3-x86_64.zip ... Passed
==> Extracting sources...
==> Starting prepare()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "electron32-bin"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: electron32-bin 32.3.3-2 (Fr 30 Mai 2025 19:28:05 CEST)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading packages files... [1/1]
Checking file conflicts... [1/1]
Checking available disk space... [1/1]
Installing electron32-bin (32.3.3-2)... [1/1]
You have not been maintaining your system, and you probably have loads of .pacnew files on your system. Check with…
pacdiff -o
If you do not have that command at your disposal, then you must install pacman-contrib first. .pacnew files should be merged — not blindly copied over, nor ignored — in order for your system to remain up-to-date with the latest changes in development, configuration standards, et al.
The community.db repo was dropped two years ago. It still exists as an empty repository — or perhaps I should say “it has been re-added as an empty repo” — which is why you’re not getting any error messages about it during the update process.
Well, then it seems that had nothing to do with anything. Most likely whatever required electron32 now depends on a newer Electron version as 32 is EOL (End Of Life), so you don’t need it anymore.
I did some reading about this tool and then I just ran pacdiff focusing on these guys:
/etc/pamac.conf.pacnew
/etc/pacman.conf.pacnew
I did a diff on them, but there was nothing to crazy there. No ignored packaged etc… I did remove the “contrib” as suggested.
Ran the update again and nothing.
I just double checked for ignored packages but this command gives me commented out lines only.
There is no wonder there. You don’t seem to be following advice given; either that, or not sufficiently reporting that you had.
With regard electron:
If you had electron32 installed, this would remove it: sudo pacman -Rns electron32
A sync/update of your system: sudo pacman -Syu
Then (only if you still need it) source the binary from the AUR: pamac build electron32-bin
From the information given, the main issue seems to be that;
This doesn’t tell us what you did; whether you merged a .pacnew file safely, or deleted it because there were no significant differences between the pacnew and the actual file, or didn’t know what to do and left it in place.
It seems more research is needed on the proper handling of .pacnew files. When you find specific differences that you don’t understand, please ask in the forum rather than just deleting (or ignoring) them.
