$ poetry <any command/-v/-h/etc>
/home/qwerty/.local/share/pypoetry/venv/bin/python: error while loading shared libraries: libpython3.10.so.1.0: cannot open shared object file: No such file or directory
I suppose it happens because i have python 3.11.6 version, while poetry wants libpython3.10. So i tried to reinstall poetry, but unfortunately… i have no idea how it was installed.
pip freeze
gives no positive result, pacman -Qqe
as well…
So, how to fix my poetry?
P.S. poetry self update
not working
Hi @gamer_girl_2007_nah ,
Please provide the output for:
pamac search --installed poetry
and:
pamac search --installed python | grep --ignore-case 'poetry'
If both return empty, then you didn’t install it with pamac . Please post the output of:
pip list
and
pipenv lock -r
and
conda list
and
ls -l ~/.local/share/pypoetry
pamac reinstall python-poetry
It is a virtual environment, which hasn’t been updated.
python -m venv --upgrade /home/qwerty/.local/share/pypoetry/venv
Won’t work as it’s not installed with pamac
Package Version
anytree 2.12.1
apparmor 3.1.6
application-utility 1.3.2
attrs 23.1.0
beautifulsoup4 4.12.2
btrfsutil 6.6.2
certifi 2023.11.17
cffi 1.16.0
chardet 5.2.0
charset-normalizer 3.3.2
cryptography 41.0.7
dbus-python 1.3.2
distro 1.8.0
docutils 0.20.1
idna 3.4
lensfun 0.3.4
LibAppArmor 3.1.6
lit 16.0.6.dev0
lxml 4.9.2
Mako 1.2.4
mallard-ducktype 1.0.2
manjaro-sdk 0.1.1
Markdown 3.5.1
MarkupSafe 2.1.3
meson 1.3.0
moddb 0.10.0
netsnmp-python 1.0a1
nftables 0.1
npyscreen 4.10.5
packaging 23.2
pacman_mirrors 4.24.0
pexpect 4.8.0
Pillow 10.1.0
pip 23.3.1
ply 3.11
psutil 5.9.6
ptyprocess 0.7.0
pybind11 2.11.1
pycairo 1.25.1
pycparser 2.21
Pygments 2.17.2
PyGObject 3.46.0
pyinotify 0.9.6
pyparsing 3.1.1
PyQt5 5.15.10
PyQt5-sip 12.13.0
pyrate-limiter 3.1.0
PySide6 6.6.1
python-pam 2.0.2
pytz 2023.3.post1
PyYAML 6.0.1
requests 2.31.0
setproctitle 1.3.3
shiboken6 6.6.1
shiboken6-generator 6.6.1
six 1.16.0
soupsieve 2.5
systemd-python 235
TBB 0.2
tinycss2 1.2.1
toolz 0.12.0
tqdm 4.66.1
typing_extensions 4.9.0
urllib3 1.26.18
vboxapi 1.0
webencodings 0.5.1
wheel 0.40.0
dont use pipenv or conda
Unable to symlink '/usr/bin/python' to '/home/qwerty/.local/share/pypoetry/venv/bin/python'
now its
$ poetry
File "/home/qwerty/.local/bin/poetry", line 5, in <module>
from poetry.console.application import main
ModuleNotFoundError: No module named 'poetry'
No idea then, how you installed it. But a folder venv indicates that python-venv was used.
I’m now thinking:
pipx install poetry
Note: I have no idea if this will work or if it’ll beak something, so do at your own risk.
Unknown. ¯\_(ツ)_/¯:
pipx install poetry
-bash: pipx: command not found
i really have no clue how my poetry was installed
perhaps i need a solution how to delete it now…
to reinstall properly
That’s actually what I was also thinking…
What is the output of
which poetry
gamer_girl_2007_nah:
OK. I think delete it:
mv /home/qwerty/.local/bin/poetry /home/qwerty/.local/bin/poetry.backup
And then reinstall it, properly this time:
pamac install python-poetry
…and hope for good news.
Yay! Now its working, thanks
Then you can safely remove the backed up file:
rm /home/qwerty/.local/bin/poetry.backup
I’m glad it worked. Next time, be more careful of how you do something.
system
Closed
4 January 2024 18:52
18
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
