OK then.
I downloaded the latest Bios and put it on the USB stick which still had F36 on it from the last time I attempted this. I really cant remeber what happened at the time but from memory it just kept coming up with errors and I didnt want to force the issue in case I was going to break something.
Anyway F38b updated just fine. Check it
Kernel: 6.3.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.3-x86_64
root=UUID=5d4ba93c-6239-4b42-b587-c9cbc08d78cc rw rootflags=subvol=@ quiet
splash resume=UUID=b6f424ae-1978-4547-87be-dfabe587f19d
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF serial: N/A
Mobo: Gigabyte model: X570 AORUS ELITE serial: N/A BIOS: American
Megatrends LLC. v: F38b date: 03/23/2023
System RAM: available: 31.26 GiB used: 4.26 GiB (13.6%)
Array-1: capacity: 128 GiB slots: 4 EC: None max-module-size: 32 GiB
note: est.
Device-1: DIMM 0 type: no module installed
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 16 GiB speed: 3600 MT/s volts: curr: 1.2 min: 1.2 max: 1.2
width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK32GX4M2D3600C18 serial: N/A
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 7 5800X3D socket: AM4 bits: 64 type: MT MCP
arch: Zen 3+ gen: 4 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA20120A
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 96 MiB
desc: 1x96 MiB
Speed (MHz): avg: 2350 high: 3400 min/max: 2200/4549 boost: enabled
base/boost: 3400/3400 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 2200 11: 2200 12: 2200 13: 2200
14: 2200 15: 2200 16: 2200 bogomips: 108859
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 1002:73bf
class-ID: 0300
Device-2: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2.4:7
chip-ID: 046d:0826 class-ID: 0e02 serial: <filter>
Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: LG (GoldStar) 27GL650F serial: <filter> built: 2019 res: 1920x1080
hz: 144 dpi: 82 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 609mm (24")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6800 XT (navi21
LLVM 15.0.7 DRM 3.52 6.3.11-1-MANJARO) direct-render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech HD Webcam C525 driver: snd-usb-audio,uvcvideo type: USB
Device-4: Focusrite-Novation Scarlett 2i4 driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-4.3:9
chip-ID: 1235:800a class-ID: fe01
API: ALSA v: k6.3.11-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.72 status: n/a (root, process) with:
3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.4.4:9
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 16.71 TiB used: 4.58 TiB (27.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent
model: SB-ROCKET-NVMe4-2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: RKT4B5.1 temp: 36.9 C scheme: MBR
SMART: yes health: PASSED on: 60 hrs cycles: 32
read-units: 21,496,522 [11.0 TB] written-units: 10,428,066 [5.33 TB]
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Sabrent model: N/A size: 1.86 TiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
tech: SSD serial: <filter> fw-rev: RKT303.3 temp: 27.9 C scheme: MBR
SMART: yes health: PASSED on: 1y 258d 7h cycles: 2,516
read-units: 143,897,144 [73.6 TB] written-units: 78,262,162 [40.0 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 2TB
family: based SSDs size: 1.82 TiB block-size: physical: 512 B logical: 512 B
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
temp: 28 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 109d 0h cycles: 748
written: 6.62 TiB
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD60EZAZ-00SF3B0 family: Blue (SMR) size: 5.46 TiB block-size:
physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A80 temp: 30 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 265d 12h cycles: 2536
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
rpm: 5400 serial: <filter> fw-rev: 0A80 temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 268d 23h cycles: 2532
ID-6: /dev/sdd maj-min: 8:48 vendor: SanDisk model: USB 3.2Gen1
size: 232.88 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-7: /dev/sde maj-min: 8:64 vendor: Toshiba model: USB Flash Memory
size: 3.78 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: PMAP
scheme: MBR
ID-8: /dev/sdg maj-min: 8:96 vendor: Generic model: Flash Disk
size: 58.59 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
fw-rev: 8.01 scheme: MBR
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 671.59 GiB (36.2%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:2
label: MANJARO uuid: 5d4ba93c-6239-4b42-b587-c9cbc08d78cc
ID-2: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 671.59 GiB (36.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p1
maj-min: 259:2 label: MANJARO uuid: 5d4ba93c-6239-4b42-b587-c9cbc08d78cc
ID-3: /run/media/thedatabug/DOCUMENTS raw-size: 5.46 TiB
size: 5.46 TiB (100.00%) used: 2.1 TiB (38.5%) fs: ntfs block-size: 4096 B
dev: /dev/sdc1 maj-min: 8:33 label: DOCUMENTS uuid: 01D69E68678D01D0
ID-4: /run/media/thedatabug/ENTERTAINMENT raw-size: 5.46 TiB
size: 5.46 TiB (100.00%) used: 1.82 TiB (33.4%) fs: ntfs block-size: 4096 B
dev: /dev/sdb1 maj-min: 8:17 label: ENTERTAINMENT uuid: 01D69E856214FD30
ID-5: /var/cache raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-6: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 6.5 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:3 label: N/A
uuid: b6f424ae-1978-4547-87be-dfabe587f19d
ID-1: /dev/nvme1n1p1 maj-min: 259:4 size: 1.83 TiB fs: btrfs label: N/A
uuid: 9bb93585-f4e5-4cc7-82da-bbd5d82bc88f
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 34.41 GiB fs: swap label: swap
uuid: 594ee3cc-5213-4a22-b9a2-f4fcf82fa213
ID-3: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: ext4 label: GAMES
uuid: 540a54c6-f85c-4888-ba19-b884f0f92ad4
ID-4: /dev/sdd1 maj-min: 8:49 size: 232.87 GiB fs: vfat label: APP STICK
uuid: 1D57-6408
ID-5: /dev/sde1 maj-min: 8:65 size: 3.78 GiB fs: vfat label: TRANSFER
uuid: ACAF-5D36
ID-6: /dev/sdg1 maj-min: 8:97 size: 58.56 GiB fs: exfat label: Ventoy
uuid: 8676-3B3D
ID-7: /dev/sdg2 maj-min: 8:98 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 7CDB-00D9
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-3.1:4 info: Razer USA Naga Trinity type: mouse,keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:0067 class-ID: 0300
serial: <filter>
Device-2: 1-3.2:6 info: Microdia Backlit Gaming Keyboard
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 400mA
chip-ID: 0c45:652f class-ID: 0301
Device-3: 1-3.3:7 info: HP Photosmart 6520 series
type: printer,mass storage driver: usb-storage,usblp interfaces: 4 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 03f0:af11 class-ID: 0806 serial: <filter>
Hub-3: 1-3.4:8 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Device-1: 1-3.4.4:9 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-2: 1-4:3 info: Integrated Express IT8297 RGB LED Controller
type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
chip-ID: 048d:8297 class-ID: 0301
Device-3: 1-5:5 info: Google Nexus/Pixel Device (MTP) type: still imaging
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 18d1:4ee1 class-ID: 0601 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Hub-6: 3-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 5-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-2.3:4 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 5-2.4:7 info: Logitech HD Webcam C525 type: audio,video
Hub-10: 5-3:3 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-3.1:6 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
Drive 2 GB PNY Attache 4GB Stick type: mass storage driver: usb-storage
power: 200mA chip-ID: 0930:6545 class-ID: 0806 serial: <filter>
Hub-11: 5-4:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 5-4.2:8 info: Holtek USB Gaming Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a0f8 class-ID: 0300
Device-2: 5-4.3:9 info: Focusrite-Novation Scarlett 2i4 type: audio
driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 1235:800a class-ID: fe01
Hub-12: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-13: 6-2:2 info: Genesys Logic Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-14: 6-3:3 info: Genesys Logic Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0612
Device-1: 6-3.3:5 info: SanDisk Ultra Flair type: mass storage
driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5591 class-ID: 0806
serial: <filter>
Device-2: 6-3.4:6 info: Alcor Micro Flash Drive type: mass storage
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 058f:6387 class-ID: 0806
serial: <filter>
Hub-15: 6-4:4 info: Genesys Logic Hub ports: 4 rev: 3.0
System Temperatures: cpu: 39.5 C mobo: 27.0 C gpu: amdgpu temp: 34.0 C
mem: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 424 Uptime: 7m wakeups: 0 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1607 pm: dpkg
pkgs: 0 pm: pacman pkgs: 1562 libs: 429 tools: pamac,paru,yay pm: flatpak
pkgs: 45 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
I havnt thoroughly read through the inxi but it does seem to only show 1 kernel. But Manajro Settings definately shows 2.
Unfortunately my Bootloader is still broken. I can get into Manajro but only via Garuda. But oddly enough since messing around trying to fix it I now get the Garuda boot loader on both the Manajro drive as well as the Garuda drive.
Bloomin annoying. I feel the quickest way to fix this would just be to wipe Manjaro and start again. But that seems so drastic when the system is working great.
