I am running Manjaro XFCE in a QEMU VM and I have no sound
I looked through some of the other posts on this topic but none offer any suggestions which work in my case.
I have tried some “solutions” found on the web but to no avail. Setting up sound using pulseaudio in Manjaro under the VM doesn’t work. Neither does adding a “sound card” in the vm manager.
This actually is the second time I have had sound problems in a vm with Arch-based distros. But I have a second VM running EndeavourOS (which is also Arch-based) but sound works there with no problems.
There is nothing special about this machine - sound and video are motherboard based Intel and it appears this is a stock Manjaro XFCE installation.
Hope to find some ideas and help here.
Thanks
Please post more information about system and audio devices
inxi -SMAaz
pactl list cards
Fixed the problem a little while go. The XML file for sound had inserted a line calling for he “pa” driver for sound. On a hunch I simply removed the line and problem solved. I guess sometimes the defaults QEMU picks are not good choices, Strange that Majaro was the only distro that suffered. I also run EndeavourOS in a VM and never had sound problems with it. Who knows ??
Thanka for your reply.
Arch Linux - qemu-audio-pa 9.2.2-1 (x86_64)
Description: QEMU PulseAudio audio driver
Required By:
qemu-desktop
qemu-full
qemu-base (optional)
