Hello everyone, my laptop is not increasing or decreasing the brightness of the screen, before and after upgrading to the Manjaro Ornara [Plasma KDE] version. This is since I installed Manjaro Plasma (without internet on that day, but then I updated the system with the command “sudo pacman -Syyuu” in later days, but it still didn’t solve it.)
Here is a screenshot showing me decreasing de brightness, but not changing nothing on laptop screen
https://paste.pics/7fee793b29357d99c163a0016389b20a
Belows follow my inxi output
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=a41f300c-9125-4bb7-822e-550ea37ae62b ro quiet apparmor=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Hewlett-Packard product: N/A v: A3009DD10303
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 1946 v: KBC Version 89.17 serial: <filter>
UEFI: Hewlett-Packard v: L73 Ver. 01.49 date: 08/29/2019
ID-1: BAT0 charge: 26.9 Wh (99.3%) condition: 27.1/27.1 Wh (100.0%)
volts: 17.0 min: 14.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Unknown
RAM: total: 3.73 GiB used: 2.58 GiB (69.2%)
Info: Dual Core model: Intel Core i5-4200U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 3 MiB bogomips: 18367
Speed: 1597 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 1597 2: 1676
3: 1657 4: 1597
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Chicony HP HD Webcam type: USB driver: uvcvideo bus-ID: 2-7:5
chip-ID: 04f2:b3c8 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 120 size: 290x170mm (11.4x6.7")
diag: 336mm (13.2")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Hewlett-Packard driver: ath9k v: kernel port: 3000 bus-ID: 04:00.0
chip-ID: 168c:0036 class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-3: Huawei Broadband stick type: USB
driver: cdc_ether,option,option1,usb-storage bus-ID: 2-2.1:8
chip-ID: 12d1:1436 class-ID: 0806
IF: wwp0s20u2u1i1 state: down mac: <filter>
IF-ID-1: ppp0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> type: noprefixroute scope: global
Device-1: Qualcomm Atheros AR3012 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 2-4:7 chip-ID: 0cf3:311f class-ID: e001
Message: No LVM data was found.
Local Storage: total: 465.76 GiB used: 46.57 GiB (10.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 2C scheme: GPT
Optical-1: /dev/sr0 vendor: HUAWEI model: Mass Storage rev: 2.31
dev-links: cdrom
Features: speed: 1 multisession: yes audio: yes dvd: no rw: none
state: running
ID-1: / raw-size: 30 GiB size: 29.4 GiB (98.00%) used: 13.04 GiB (44.4%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: Manjaro-Root
uuid: a41f300c-9125-4bb7-822e-550ea37ae62b
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 92CC-F6C9
ID-3: /home raw-size: 285 GiB size: 279.53 GiB (98.08%)
used: 33.52 GiB (12.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Home
uuid: afa791ab-389b-44e1-9f83-5e98b16073e9
ID-1: swap-1 type: partition size: 7 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: a433397e-215d-4fc6-a8a6-b3370737d37d
ID-1: /dev/sda4 maj-min: 8:4 size: 113.46 GiB fs: ext4 label: PrimeOS
uuid: e5d445e4-f59f-5158-b9c7-465f7009bc23
ID-2: /dev/sda5 maj-min: 8:5 size: 30 GiB fs: ext4 label: N/A
uuid: 495d43f2-5d08-468b-9c42-04ddeb658fdd
ID-3: /dev/sda7 maj-min: 8:7 size: 2.5 MiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Hub-4: 2-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 2-2.1:8 info: Huawei Broadband stick
type: Ethernet Network,CDC-Data,Mass Storage
driver: cdc_ether,option,option1,usb-storage interfaces: 7 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 12d1:1436 class-ID: 0806
Device-2: 2-4:7 info: Qualcomm Atheros AR3012 Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
Device-3: 2-6:4 info: Primax USB Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 0461:4d22 class-ID: 0301
Device-4: 2-7:5 info: Chicony HP HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b3c8
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-6: 3-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
System Temperatures: cpu: 55.0 C mobo: 0.0 C
Processes: 205 Uptime: 23m wakeups: 1 Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1336 lib: 416 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.0 running-in: konsole inxi: 3.3.03
What should I do to be able to increase the brightness on my laptop screen?
