Im trying to install hyprland, but when I choose the desktop environment, It goes black for a second, and puts me back on the login screen. I used the install command sudo pacman -S hyprland
. Am I doing everything right?
If I try to install nvidia-dkms
, I get the notice nvidia-dkms and linux61-nvidia are in conflict (NVIDIA-MODULE). Remove linux61-nvidia? [y/N]
. Do I click yes?
Why do you need nvidia-dkms? You already have it installed.
The guide says to install nvidia-dkms
What guide?
Well you can skip that part.
Turns out my kernel parameters weren’t working so I fixed it and now it runs
Good to hear.
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
