It’s me again… anyone have hyprland dotfiles they are proud of and willing to share? Yep, I’m on a Wayland journey/ adventure. TIA
@manyroads, are you blacklisted from search engine sites?
My Hyprland configuration
Install grim, slurp, and cliphist.
Enabled blur, drop shadow, opacity, animations with bouncing effect and it is optimized to minimum system resource usage .
hyprland.conf
AUTOGENERATED HYPR CONFIG.
PLEASE USE THE CONFIG PROVIDED IN THE GIT REPO /examples/hypr.conf AND EDIT IT,
OR EDIT THIS ONE ACCORDING TO THE WIKI INSTRUCTIONS.
# Please note not all available settings / options are set here.
# For a full list, see the wiki
#autogenerated = 1 # remove this line to remove the warning
# See https://wiki.hyprland.org/Configuring/Monitors/
monitor=,preferred,auto,auto
# See https://wiki.hyprland.org/Configuring/Keywords/ for more
### Execute your favorite apps at launch
# exec-once = conky
# exec-once = hyprpaper
# exec-once = pkill swaybg | sleep 0.5 && swaybg -o "HDMI-A-2" -m fill -i ~/Pictures/wallpapers/$(ls ~/Pictures/wallpapers|shuf -n 1)
# exec-once = pkill swaybg | sleep 0.5 && swaybg -i ~/Pictures/wallpapers/$(ls ~/Pictures/wallpapers|shuf -n 1) -m fill
# exec-once = /home/qtiler/scripts/autoswitch.sh
exec-once = /home/qtiler/scripts/random_background.sh
exec-once = waybar & dunst & /usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1
exec-once = /home/qtiler/scripts/conky_start.sh
exec-once = nm-applet
exec-once = wl-copy --type text --watch cliphist store # clipboard store text data
exec-once = wl-copy --type image --watch cliphist store # clipboard store image data
exec-once = wl-paste --type text --watch cliphist store # clipboard store text data
exec-once = wl-paste --type image --watch cliphist store # clipboard store image data
### Source a file (multi-file configs)
# source = ~/.config/hypr/myColors.conf
# Some default env vars.
env = XCURSOR_SIZE,24
env = GTK_THEME,Sweet-Dark-v40
# For all categories, see https://wiki.hyprland.org/Configuring/Variables/
input {
kb_layout = us
kb_variant =
kb_model =
kb_options =
kb_rules =
follow_mouse = 1
touchpad {
natural_scroll = no
sensitivity = 0 # -1.0 - 1.0, 0 means no modification.
general {
# See https://wiki.hyprland.org/Configuring/Variables/ for more
gaps_in = 12
gaps_out = 24
border_size = 2
no_cursor_warps = true
col.active_border = rgba(33ccffee) rgba(00ff99ee) 45deg
col.inactive_border = rgba(FF0000ee) rgba(FFFF00ee) 45deg
layout = master
misc {
vfr = true
vrr = 0
focus_on_activate = true
disable_hyprland_logo = true
animate_manual_resizes = false
animate_mouse_windowdragging = false
# enable_swallow = true
# swallow_regex=^(foot|kitty|gnome-terminal)$
binds {
workspace_back_and_forth = true
allow_workspace_cycles = true
pass_mouse_when_bound = false
decoration {
### round corner
rounding = 10
### opacity
# active_opacity = 1.0
# inactive_opacity = 0.80
### blur
blur {
enabled = true
size = 8
passes = 2
new_optimizations = true
drop_shadow = yes
shadow_range = 30
shadow_render_power = 3
col.shadow = 0x66000000
animations {
enabled=true
bezier=slow,0,0.85,0.3,1
bezier=overshot,0.7,0.6,0.1,1.1
bezier=bounce,1,1.6,0.1,0.85
bezier=slingshot,1,-2,0.9,1.25
bezier=nice,0,6.9,0.5,-4.20
animation=windows,1,5,bounce,slide
# animation = windowsOut, 1, 7, default, popin 80%
animation=border,1,20,default
animation=fade,1,10,default
animation=workspaces,1,5,overshot,slide
dwindle {
# See https://wiki.hyprland.org/Configuring/Dwindle-Layout/ for more
pseudotile = yes # master switch for pseudotiling. Enabling is bound to mainMod + P in the keybinds section below
preserve_split = yes # you probably want this
master {
# See https://wiki.hyprland.org/Configuring/Master-Layout/ for more
new_is_master = true
gestures {
workspace_swipe = off
# Example per-device config
# See https://wiki.hyprland.org/Configuring/Keywords/#executing for more
device:epic-mouse-v1 {
sensitivity = -0.5
# Example windowrule v1
# windowrule = float, ^(kitty)$
# Example windowrule v2
# windowrulev2 = float,class:^(kitty)$,title:^(kitty)$
# See https://wiki.hyprland.org/Configuring/Window-Rules/ for more
######## Window rules ########
# Workspace
windowrulev2 = workspace 1, class:^(firefox)$
windowrulev2 = workspace 1, class:^(Opera)$
windowrulev2 = workspace 1, class:^(wf-osk)$
windowrulev2 = workspace 1, class:^(vivaldi-stable)$
windowrulev2 = workspace 2, class:^(org.gnome.Nautilus)$
windowrulev2 = workspace 2, class:^(org.manjaro.pamac.manager)$
windowrulev2 = workspace 3, class:^(kitty)$
windowrulev2 = workspace 3, class:^(gnome-terminal-server)$
windowrulev2 = workspace 4, class:^(gnome-system-monitor)$
windowrulev2 = workspace 4, class:^(org.gnome.Gnote)$
windowrulev2 = workspace 4, class:^(vlc)$
windowrulev2 = workspace 4, class:^(gnome-boxes)$
windowrulev2 = workspace 4, class:^(org.gnome.Meld)$
windowrulev2 = workspace 5, class:^(geany)$
windowrulev2 = workspace 5, class:^(gedit)$
windowrulev2 = workspace 6, class:^(gthumb)$
windowrulev2 = workspace 6, class:^(Gimp-2.10)$
windowrulev2 = workspace 7, class:^(terminal64.exe)$
windowrulev2 = workspace 8, class:^(metaeditor64.exe)$
#windowrulev2 = workspace 8, class:^(org.gnome.Calculator)$
#windowrule = workspace 7 silent,^(Opera)$
### Opacity
windowrulev2 = opacity 0.85 0.75,class:^(geany)$
windowrulev2 = opacity 0.85 0.75,class:^(gedit)$
windowrulev2 = opacity 0.85 0.75,class:^(kitty)$
windowrulev2 = opacity 0.85 0.75,class:^(org.gnome.Gnote)$
windowrulev2 = opacity 0.85 0.75,class:^(gnome.terminal.server)$
windowrulev2 = opacity 0.85 0.75,class:^(gnome.system.monitor)$
windowrulev2 = opacity 0.85 0.75,class:^(org.gnome.Nautilus)$
### Floating
windowrulev2 = float, class:^(rofi)$
windowrulev2 = float, class:^(nm-connection-editor)$
windowrulev2 = float, class:^(wlroots)$
windowrulev2 = float, class:^(pavucontrol)$
windowrulev2 = float, class:^(com.github.hluk.copyq)$
windowrulev2 = float, class:^(org.gnome.Calculator)$
windowrulev2 = float, title:^(Open Files)$
windowrulev2 = float, title:^(Bluetooth Devices)$
windowrulev2 = float, title:^(Picture in Picture)$
windowrulev2 = float, title:^(Authentication)$
windowrulev2 = float, title:^(Authenticate)$
windowrulev2 = float, title:^(All Files)$
windowrulev2 = float, title:^(Open Theme File)$
windowrulev2 = float, title:^(Select one or more files to open)$
windowrulev2 = float, title:^(Location)$
#windowrule conky
windowrule = noborder,Conky
#windowrule = noblur,Conky
windowrule = noshadow,Conky
windowrulev2 = float, class:^(Conky)$
windowrulev2 = move 14 49,class:^(Conky)$
windowrule = workspace 1 silent,^(Conky)$
windowrulev2 = pin,class:^(Conky)$
#windowrule Picture-in-Picture
windowrulev2 = float, title:^(Picture-in-Picture)$
windowrulev2 = size 800 450, title:(Picture-in-Picture)
windowrulev2 = pin, title:^(Picture-in-Picture)$
windowrulev2 = float, title:^(Firefox)$
windowrulev2 = size 800 450, title:(Firefox)
windowrulev2 = pin, title:^(Firefox)$
$mainMod = SUPER
# Example binds, see https://wiki.hyprland.org/Configuring/Binds/ for more
bind = $mainMod, Q, exec, kitty
bind = $mainMod, C, killactive,
bind = $mainMod, M, exit,
bind = $mainMod, E, exec, nautilus
bind = $mainMod, TAB,workspace,previous
bind = $mainMod, F, togglefloating
bind = $mainMod, R, exec, wofi --show drun,
bind = $mainMod, X, exec, jgmenu_run,
bind = $mainMod, Z, exec, rofi -combi-modi window,drun,ssh -icon-theme Papirus -show combi -hover-select -me-select-entry '' -me-accept-entry MousePrimary
#bind = $mainMod, S, pseudo, # dwindle
bind = $mainMod, S, movetoworkspacesilent, special
bind = $mainMod SHIFT, S, togglespecialworkspace
bind = $mainMod, J, togglesplit, # dwindle
bind = $mainMod, P, exec, grim -g "$(slurp -p)" -t ppm - | convert - -format '%[pixel:p{0,0}]' txt:- | tail -n 1 | cut -d ' ' -f 4 | wl-copy # color-picker
bind = $mainMod, PRINT, exec, grim $(xdg-user-dir PICTURES)/$(date +'%Y%m%d-%H%M%S_grim.png') # screenshot
bind = $mainMod, V, exec, cliphist list | rofi -dmenu | cliphist decode | wl-copy
bind = $mainMod, W, exec, killall -SIGUSR1 waybar
#bind = $mainMod, P, exec, /home/qtiler/scripts/wayland-color-picker # color-picker
# Move focus with mainMod + arrow keys
bind = $mainMod, left, movefocus, l
bind = $mainMod, right, movefocus, r
bind = $mainMod, up, movefocus, u
bind = $mainMod, down, movefocus, d
# Switch workspaces with mainMod + [0-9]
bind = $mainMod, 1, workspace, 1
bind = $mainMod, 2, workspace, 2
bind = $mainMod, 3, workspace, 3
bind = $mainMod, 4, workspace, 4
bind = $mainMod, 5, workspace, 5
bind = $mainMod, 6, workspace, 6
bind = $mainMod, 7, workspace, 7
bind = $mainMod, 8, workspace, 8
bind = $mainMod, 9, workspace, 9
bind = $mainMod, 0, workspace, 10
# Move active window to a workspace with mainMod + SHIFT + [0-9]
bind = $mainMod SHIFT, 1, movetoworkspace, 1
bind = $mainMod SHIFT, 2, movetoworkspace, 2
bind = $mainMod SHIFT, 3, movetoworkspace, 3
bind = $mainMod SHIFT, 4, movetoworkspace, 4
bind = $mainMod SHIFT, 5, movetoworkspace, 5
bind = $mainMod SHIFT, 6, movetoworkspace, 6
bind = $mainMod SHIFT, 7, movetoworkspace, 7
bind = $mainMod SHIFT, 8, movetoworkspace, 8
bind = $mainMod SHIFT, 9, movetoworkspace, 9
bind = $mainMod SHIFT, 0, movetoworkspace, 10
# Scroll through existing workspaces with mainMod + scroll
bind = $mainMod, mouse_down, workspace, e+1
bind = $mainMod, mouse_up, workspace, e-1
# Move/resize windows with mainMod + LMB/RMB and dragging
bindm = $mainMod, mouse:272, movewindow
bindm = $mainMod, mouse:273, resizewindow
Please edit the line “env = GTK_THEME,Sweet-Dark-v40” with your preferred theme.
For wallpaper :- Install hyprpaper
hyprpaper.conf
ipc = off
preload = /home/qtiler/Pictures/wallpapers/nI1u6Ihc.jpeg
#preload = /home/qtiler/Pictures/wallpapers/og94oqtbirga1.jpg
wallpaper = HDMI-A-2,/home/qtiler/Pictures/wallpapers/nI1u6Ihc.jpeg
#wallpaper = HDMI-A-2,/home/qtiler/Pictures/wallpapers/og94oqtbirga1.jpg
#hyprctl monitors | grep 'Monitor' | awk '{ print $2 }' to get monitor name
For random wallpaper :- Install swaybg for random_background.sh
#!/bin/sh
while true; do
# Find image files and select one randomly
image=$(find /home/qtiler/Pictures/wallpapers/. -type f | shuf -n1)
# Check if an image was found
if [ -n "$image" ]; then
# Set the wallpaper
swaybg -i "$image" -m fill &
sleep 600
# Kill the old swaybg process quietly
pkill -f "swaybg"
# Start a new process with a new image
# Set the new wallpaper
sleep 600
pkill -f "swaybg"
else
echo "No image found for the next wallpaper."
fi
else
echo "No image found for the wallpaper."
fi
done
waybar
config
"layer": "top", // Waybar at top layer
// "position": "top", // Waybar position (top|bottom|left|right)
"height": 30, // Waybar height (to be removed for auto height)
// "width": 1280, // Waybar width
"spacing": 6, // Gaps between modules (4px)
// Choose the order of the modules
"modules-left": ["custom/launcher", "custom/icon1", "custom/icon2", "custom/icon3", "custom/icon4", "custom/icon5", "custom/icon6", "custom/icon7", "custom/icon8", "custom/icon9", "custom/icon10", "custom/icon11", "custom/icon12", "custom/icon13", "custom/icon14", "hyprland/workspaces", "custom/media"],
"modules-center": ["custom/icon15", "wlr/taskbar"],
"modules-right": ["pulseaudio", "network", "disk", "cpu", "memory", "temperature", "backlight", "keyboard-state", "sway/language", "battery", "battery#bat2", "clock", "custom/weather", "custom/pacman", "custom/power", "tray"],
// Modules configuration
"hyprland/workspaces": {
"disable-scroll": false,
"active-only": false,
"on-scroll-up": "hyprctl dispatch workspace +1",
"on-scroll-doun": "hyprctl dispatch workspace -1",
"show-special": true,
"all-outputs": false,
"on-click": "activate",
//"format": "{icon}",
"persistent_workspaces": {
"1": ["HDMI-A-2"],
"2": ["HDMI-A-2"],
"3": ["HDMI-A-2"],
"4": ["HDMI-A-2"],
"5": ["HDMI-A-2"],
"6": ["HDMI-A-2"],
"7": [""],
"8": [""],
"9": [""]
"keyboard-state": {
"numlock": true,
"capslock": true,
"format": "{name} {icon}",
"format-icons": {
"locked": "",
"unlocked": ""
"sway/mode": {
"format": "<span style=\"italic\">{}</span>"
"wlr/taskbar": {
"format": "{icon} {app_id}",
"markup": true,
"icon-theme": "/usr/share/icons/Papirus-Dark",
"icon-size": 13,
"tooltip": true,
"active-first": true,
"on-click-right": "close",
"on-scroll-up": "hyprctl dispatch workspace e+1",
"on-scroll-down": "hyprctl dispatch workspace e-1",
"ignore-list": [
"Conky"
"app_ids-mapping": {
"org.gnome.Nautilus": "Files",
"org.gnome.Meld": "Meld",
"org.gnome.Gnote": "gnote",
"org.gnome.Calculator": "Calc",
"terminal64.exe": "Mt5",
"metaeditor64.exe": "Mt5edit",
"vivaldi-stable": "vivaldi",
"gnome-terminal-server": "Term",
"gnome-system-monitor": "monitor",
"org.manjaro.pamac.manager": "pamac",
"Manjaro.manjaro-settings-manager": "settings"
"sway/scratchpad": {
"format": "{icon} {count}",
"show-empty": false,
"format-icons": ["", ""],
"tooltip": true,
"tooltip-format": "{app}: {title}"
"mpd": {
"format": "{stateIcon} {consumeIcon}{randomIcon}{repeatIcon}{singleIcon}{artist} - {album} - {title} ({elapsedTime:%M:%S}/{totalTime:%M:%S}) ⸨{songPosition}|{queueLength}⸩ {volume}% ",
"format-disconnected": "Disconnected ",
"format-stopped": "{consumeIcon}{randomIcon}{repeatIcon}{singleIcon}Stopped ",
"unknown-tag": "N/A",
"interval": 2,
"consume-icons": {
"on": " "
"random-icons": {
"off": "<span color=\"#f53c3c\"></span> ",
"on": " "
"repeat-icons": {
"on": " "
"single-icons": {
"on": "1 "
"state-icons": {
"paused": "",
"playing": ""
"tooltip-format": "MPD (connected)",
"tooltip-format-disconnected": "MPD (disconnected)"
"idle_inhibitor": {
"format": "{icon}",
"format-icons": {
"activated": "",
"deactivated": ""
"tray": {
// "icon-size": 21,
"spacing": 10
"clock": {
// "timezone": "Asia/Kolkata",
"interval": 1,
"tooltip-format": "<big>{:%Y %B}</big>\n<tt><small>{calendar}</small></tt>",
"format-alt": "{:%Y-%m-%d}",
"format": "{:%e %a %b %I:%M:%S}"
"cpu": {
"interval": 1,
"format": "{usage}% ",
"on-click": "gnome-system-monitor",
"min-length": 8,
"tooltip": false
"disk": {
"format": "{used}",
"format-alt": " {used}/{total} GiB",
"interval": 5,
"path": "/"
"custom/launcher": {
"format": "",
"tooltip": false,
"min-length": 4,
"on-click": "rofi -combi-modi window,drun,ssh -icon-theme Papirus -show combi -hover-select -me-select-entry '' -me-accept-entry MousePrimary",
// "on-click": "wofi --show drun -I -a -n -W 500 -H 376 -s ~/.config/wofi/themes/gruvbox.css",
"on-click-middle": "wtype -k escape",
"on-click-right": "jgmenu_run"
"memory": {
"on-click-right": "kitty -e bashtop",
"interval": 2,
"format": "{used:0.1f}G/{total:0.1f}G/{swapUsed:0.1f}G "
"temperature": {
//"thermal-zone": 2,
//"hwmon-path": "/sys/class/hwmon/hwmon1/temp1_input",
"hwmon-path-abs": "/sys/devices/platform/coretemp.0/hwmon",
"input-filename": "temp1_input",
"interval": 1,
"critical-threshold": 55,
// "format-critical": "{temperatureC}°C {icon}",
"format": "{temperatureC}°C {icon}",
"format-icons": ["", "", ""]
"backlight": {
// "device": "acpi_video1",
"format": "{percent}% {icon}",
"format-icons": ["", "", "", "", "", "", "", "", ""]
"battery": {
"states": {
// "good": 95,
"warning": 30,
"critical": 15
"format": "{capacity}% {icon}",
"format-charging": "{capacity}% ",
"format-plugged": "{capacity}% ",
"format-alt": "{time} {icon}",
// "format-good": "", // An empty format will hide the module
// "format-full": "",
"format-icons": ["", "", "", "", ""]
"battery#bat2": {
"bat": "BAT2"
"network": {
// "interface": "wlp2*", // (Optional) To force the use of this interface
"interval": 1,
"format-wifi": "{essid} ({signalStrength}%) ",
"format-ethernet": "{bandwidthDownBytes}/{bandwidthUpBytes} ",
"tooltip-format": "{ifname} via {gwaddr} ",
"format-linked": "{ifname} (No IP) ",
"format-disconnected": "Disconnected ⚠",
"min-length": 18,
"format-alt": "{ifname}: {ipaddr}/{cidr}"
"custom/pacman": {
"format": "{} ",
"min-length": 5,
"tooltip": false,
"interval": 3600,
"exec": "checkupdates | wc -l",
"exec-if": "exit 0",
"on-click": "gnome-terminal -e 'sudo pacman -Syu'; pkill -SIGRTMIN+8 waybar",
"signal": 8
"custom/weather": {
"exec": "python ~/.config/waybar/weather.py",
"return-type": "json",
"format": "{}",
"tooltip": true,
"on-click": "xdg-open https://weather.com/en-IN/weather/today/l/6121c511144d639b3932fe2a28537be31b9be0d714e86f7ca41f69528423c3a8",
"interval": 600
"custom/icon1": {
"format": "{} ",
"tooltip": false,
"on-click": "vivaldi-stable",
"on-click-right": "opera"
"custom/icon2": {
"format": "{} ",
"tooltip": false,
"on-click": "nautilus",
"on-click-right": "kitty -e ranger"
"custom/icon3": {
"format": "{} ",
"tooltip": false,
"custom/icon4": {
"format": "{} ",
"on-click": "gnome-calculator",
"on-click-right": "kitty -e bc"
"custom/icon5": {
"format": "{} ",
"tooltip": false,
"on-click": "gnome-boxes"
"custom/icon6": {
"format": "{} ",
"on-click": "vlc",
"on-click-right": "lollypop"
"custom/icon7": {
"format": "{} ",
"tooltip": false,
"on-click": "wf-osk"
"custom/icon8": {
"format": "{} ",
"tooltip": false,
"on-click": "firefox",
"on-click-right": "qutebrowser"
"custom/icon9": {
"format": "{} ",
"on-click": "kitty",
"on-click-right": "gnome-terminal"
"custom/icon10": {
"format": "{} ",
"tooltip": false,
"on-click": "pamac-manager",
"on-click-right": "kitty -e sudo pacman -Scc"
"custom/icon11": {
"format": "{} ",
"tooltip": false,
"on-click": "gimp-2.10",
"on-click-middle": "pkill swaybg | sleep 0.5 && swaybg -i ~/Pictures/wallpapers/$(ls ~/Pictures/wallpapers|shuf -n 1) -m fill",
"on-click-right": "/home/qtiler/scripts/wayland-color-picker"
"custom/icon12": {
"format": "{} ",
"tooltip": false,
"on-click": "cliphist list | rofi -dmenu -hover-select -me-select-entry '' -me-accept-entry MousePrimary | cliphist decode | wl-copy",
"on-click-right": "wtype -k escape"
"custom/icon13": {
"format": "{} ",
"tooltip": false,
"on-click": "gnote",
"on-click-right": "kitty -e newsboat"
"custom/icon14": {
"format": "{} ",
"tooltip": false,
"on-click": "geany $HOME/.config/hypr/hyprland.conf",
"on-click-middle": "geany $HOME/.config/waybar/style.css",
"on-click-right": "geany $HOME/.config/waybar/config"
"custom/icon15": {
"format": "{} ",
"tooltip": false,
"on-click": "hyprctl dispatch movetoworkspace -1",
"on-click-right": "hyprctl dispatch movetoworkspace +1"
"custom/power": {
"format": " ",
"tooltip": false,
"on-click": "killall -9 Hyprland",
"on-click-middle": "systemctl reboot",
"on-click-right": "systemctl -i poweroff"
"pulseaudio": {
// "scroll-step": 1, // %, can be a float
"format": "{volume}% {icon} {format_source}",
"format-bluetooth": "{volume}% {icon} {format_source}",
"format-bluetooth-muted": " {icon} {format_source}",
"format-muted": " {format_source}",
"format-source": "{volume}% ",
"format-source-muted": "",
"format-icons": {
"headphone": "",
"hands-free": "",
"headset": "",
"phone": "",
"portable": "",
"car": "",
"default": ["", "", ""]
"on-click": "pavucontrol",
"on-click-right": "amixer -q set Master toggle"
// "custom/media": {
// "format": "{icon} {}",
// "return-type": "json",
// "max-length": 40,
// "format-icons": {
// "spotify": "",
// "default": "🎜"
// "escape": true,
// "exec": "$HOME/.config/waybar/mediaplayer.py 2> /dev/null" // Script in resources folder
// // "exec": "$HOME/.config/waybar/mediaplayer.py --player spotify 2> /dev/null" // Filter player based on name
style.css
/* `otf-font-awesome` is required to be installed for icons */
font-family: FontAwesome, Roboto, Helvetica, Arial, sans-serif;
font-size: 14px;
window#waybar {
background-color: rgba(43, 48, 59, 0.6);
border-bottom: 3px solid rgba(100, 114, 125, 0.5);
color: #ffffff;
transition-property: background-color;
transition-duration: .5s;
window#waybar.hidden {
opacity: 0.2;
window#waybar.empty {
background-color: transparent;
window#waybar.solo {
background-color: #FFFFFF;
window#waybar.termite {
background-color: #3F3F3F;
window#waybar.chromium {
background-color: #000000;
border: none;
button {
/* Use box-shadow instead of border so the text isn't offset */
box-shadow: inset 0 -3px transparent;
/* Avoid rounded borders under each button name */
border: none;
border-radius: 0;
/* https://github.com/Alexays/Waybar/wiki/FAQ#the-workspace-buttons-have-a-strange-hover-effect */
button:hover {
background: inherit;
box-shadow: inset 0 -3px #ffffff;
#workspaces button {
padding: 0 5px;
background: rgba(0, 0, 0, 0.2);
color: #ffffff;
#workspaces button.persistent {
#workspaces button:hover {
background: rgba(0, 0, 0, 0.3);
#workspaces button.active {
background-color: #ff0088;
#workspaces button.focused {
background-color: #64727D;
#workspaces button.urgent {
background-color: #eb4d4b;
#mode {
border-bottom: 3px solid #ffffff;
#clock,
#battery,
#cpu,
#memory,
#disk,
#temperature,
#backlight,
#network,
#pulseaudio,
#wireplumber,
#custom-weather,
#custom-pacman,
#custom-icon,
#custom-power,
#custom-media,
#tray,
#mode,
#idle_inhibitor,
#scratchpad,
#taskbar {
border-radius: 8px 8px 8px 8px;
padding: 0 3px;
margin: 0 0px;
color: #ffffff;
background-color: rgba(120,118,117,0.3);
#taskbar button {
border-radius: 3px 3px 3px 3px;
padding: 0 0 0 3px;
margin: 3px;
color: #ffffff;
background-color: rgba(120,118,117,0.1);
#taskbar button.active {
background-color: rgba(120,118,117,0.8);
#mpd {
padding: 0 10px;
color: #ffffff;
#window,
#workspaces {
margin: 0 4px;
/* If workspaces is the leftmost module, omit left margin */
.modules-left > widget:first-child > #workspaces {
margin-left: 0;
/* If workspaces is the rightmost module, omit right margin */
.modules-right > widget:last-child > #workspaces {
margin-right: 0;
#clock {
background-color: #FF6347;
#battery {
background-color: #ffffff;
color: #000000;
#battery.charging, #battery.plugged {
color: #ffffff;
background-color: #26A65B;
@keyframes blink {
to {
color: #000000;
#battery.critical:not(.charging) {
background-color: #f53c3c;
color: #ffffff;
animation-name: blink;
animation-duration: 0.5s;
animation-timing-function: linear;
animation-iteration-count: infinite;
animation-direction: alternate;
label:focus {
#cpu {
background-color: #FD3F92;
color: #ffffff;
#memory {
background-color: #0080FF;
#disk {
background-color: #FFA500;
#backlight {
background-color: #90b1b1;
#network {
background-color: #008000;
#network.disconnected {
#pulseaudio {
background-color: #BD33A4;
color: #ffffff;
#pulseaudio.muted {
color: #2a5c45;
#wireplumber {
background-color: #fff0f5;
color: #000000;
#wireplumber.muted {
#custom-media {
background-color: #66cc99;
color: #2a5c45;
min-width: 100px;
#custom-media.custom-spotify {
#custom-media.custom-vlc {
background-color: #ffa000;
#temperature {
background-color: #16A085;
#temperature.critical {
#tray {
background-color: #2980b9;
#tray > .passive {
-gtk-icon-effect: dim;
#tray > .needs-attention {
-gtk-icon-effect: highlight;
#idle_inhibitor {
background-color: #2d3436;
#idle_inhibitor.activated {
background-color: #ecf0f1;
color: #2d3436;
#mpd {
color: #2a5c45;
#mpd.disconnected {
#mpd.stopped {
#mpd.paused {
background-color: #51a37a;
#language {
background: #00b093;
color: #740864;
padding: 0 5px;
margin: 0 5px;
min-width: 16px;
#keyboard-state {
background: #97e1ad;
color: #000000;
padding: 0 0px;
margin: 0 5px;
min-width: 16px;
#keyboard-state > label {
padding: 0 5px;
#keyboard-state > label.locked {
#custom-weather{
background-color: #9400D3;
#custom-pacman {
background-color: #00CCCC;
#custom-icon {
#custom-power {
background-color: #FF0000;
#scratchpad {
#scratchpad.empty {
weather.py for waybar custom/weather widget which shows detailed weather data from weather.com
Install python-pyquery and json for weather.py
weather.py
#!/usr/bin/env python
import subprocess
from pyquery import PyQuery # install using `pip install pyquery`
import json
# weather icons
weather_icons = {
"sunnyDay": "🌤",
"clearNight": "望",
"cloudyFoggyDay": "",
"cloudyFoggyNight": "",
"rainyDay": "",
"rainyNight": "",
"snowyIcyDay": "",
"snowyIcyNight": "",
"severe": "",
"default": "",
# get location_id
# to get your own location_id, go to https://weather.com & search your location.
# once you choose your location, you can see the location_id in the URL(64 chars long hex string)
# like this: https://weather.com/en-IN/weather/today/l/c3e96d6cc4965fc54f88296b54449571c4107c73b9638c16aafc83575b4ddf2e
location_id = "6121c511144d639b3932fe2a28537be31b9be0d714e86f7ca41f69528423c3a8" # TODO
# location_id = "8139363e05edb302e2d8be35101e400084eadcecdfce5507e77d832ac0fa57ae"
# priv_env_cmd = 'cat $PRIV_ENV_FILE | grep weather_location | cut -d "=" -f 2'
# location_id = subprocess.run(
# priv_env_cmd, shell=True, capture_output=True).stdout.decode('utf8').strip()
# get html page
url = "https://weather.com/en-IN/weather/today/l/" + location_id
html_data = PyQuery(url=url)
# current temperature
temp = html_data("span[data-testid='TemperatureValue']").eq(0).text()
# print(temp)
# current status phrase
status = html_data("div[data-testid='wxPhrase']").text()
status = f"{status[:16]}.." if len(status) > 17 else status
# print(status)
# status code
status_code = html_data("#regionHeader").attr("class").split(" ")[2].split("-")[2]
# print(status_code)
# status icon
icon = (
weather_icons[status_code]
if status_code in weather_icons
else weather_icons["default"]
# print(icon)
# temperature feels like
temp_feel = html_data(
"div[data-testid='FeelsLikeSection'] > span > span[data-testid='TemperatureValue']"
).text()
temp_feel_text = f"Feels like {temp_feel}c"
# print(temp_feel_text)
# min-max temperature
temp_min = (
html_data("div[data-testid='wxData'] > span[data-testid='TemperatureValue']")
.eq(0)
.text()
temp_max = (
.eq(1)
.text()
temp_min_max = f" {temp_min}\t\t {temp_max}"
# print(temp_min_max)
# wind speed
wind_speed = html_data("span[data-testid='Wind']").text().split("\n")[1]
wind_text = f"煮 {wind_speed}"
# print(wind_text)
# humidity
humidity = html_data("span[data-testid='PercentageValue']").text()
humidity_text = f" {humidity}"
# print(humidity_text)
# visibility
visbility = html_data("span[data-testid='VisibilityValue']").text()
visbility_text = f" {visbility}"
# print(visbility_text)
# air quality index
air_quality_index = html_data("text[data-testid='DonutChartValue']").text()
# print(air_quality_index)
# hourly rain prediction
prediction = html_data("section[aria-label='Hourly Forecast']")(
"div[data-testid='SegmentPrecipPercentage'] > span"
).text()
prediction = prediction.replace("Chance of Rain", "")
prediction = f"\n\n (hourly) {prediction}" if len(prediction) > 0 else prediction
# print(prediction)
# tooltip text
tooltip_text = str.format(
"\t\t{}\t\t\n{}\n{}\n{}\n\n{}\n{}\n{}{}",
f'<span size="xx-large">{temp}</span>',
f"<big>{icon}</big>",
f"<big>{status}</big>",
f"<small>{temp_feel_text}</small>",
f"<big>{temp_min_max}</big>",
f"{wind_text}\t{humidity_text}",
f"{visbility_text}\tAQI {air_quality_index}",
f"<i>{prediction}</i>",
# add degree symbol
temp_with_degree_symbol = temp + "C"
# print waybar module data
out_data = {
"text": f"{icon} {temp_with_degree_symbol}",
"alt": status,
"tooltip": tooltip_text,
"class": status_code,
print(json.dumps(out_data))
I admire the desktop wallpaper although I’d have to wear sunglasses…
