just tried Hyprland Config on freshly installed manjaro sway edition and it works great - thx to JaKooLit.
your system must be up to date
run ./install-Hyprland-v3 as user
script will ask you now and then
yay should be installed
if you already using hyprland, the script will create a backup and also it’ll not overwrite
already existing waybar config, because the (hypr) waybar config located in new hypr folder.
after first login press $mainMod CTRL, S then choose the first entry on the list and enjoy the Music.
" Die Realität ist eine Illusion, die durch Mangel an ehrlicher Kommunikation entsteht "
