Hello all,
I have discovered right before a zoom meeting that the microphone on my HyperX headphones is not working for some reason.
I have found the thread below but although it is marked as solved, it stops short with no actual solution (or at least I don’t know what to make of the solution).
Can someone help me out with this?
Here is the output from pacmd list-sources
$ pacmd list-sources
3 source(s) available.
index: 3
driver: <module-alsa-card.c>
flags: DECIBEL_VOLUME LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 0 KiB
sample spec: s32le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
fixed latency: 250.00 ms
monitor_of: 1
card: 2 <alsa_card.pci-0000_0a_00.4>
module: 8
properties:
device.description = "Monitor of Starship/Matisse HD Audio Controller Digital Stereo (IEC958)"
device.class = "monitor"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfca00000 irq 93"
device.bus_path = "pci-0000:0a:00.4"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:0a:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.string = "1"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
index: 14
name: <alsa_output.usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00.analog-stereo.monitor>
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1040
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
sample spec: s16le 2ch 48000Hz
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
monitor_of: 7
card: 4 <alsa_card.usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00>
module: 32
properties:
device.description = "Monitor of HyperX 7.1 Audio Analog Stereo"
alsa.card = "0"
alsa.card_name = "HyperX Virtual Surround Sound"
alsa.long_card_name = "Kingston HyperX Virtual Surround Sound at usb-0000:05:00.1-3.1, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:05:00.1-usb-0:3.1:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:01.2/0000:01:00.0/0000:02:08.0/0000:05:00.1/usb1/1-3/1-3.1/1-3.1:1.0/sound/card0"
udev.id = "usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00"
device.bus = "usb"
device.vendor.id = "0951"
device.vendor.name = "Kingston Technology"
device.product.id = "16a4"
device.product.name = "HyperX 7.1 Audio"
device.serial = "Kingston_HyperX_Virtual_Surround_Sound_00000000"
device.string = "0"
device.icon_name = "audio-card-usb"
* index: 15
name: <alsa_input.usb-Kingston_HyperX_Virtual_Surround_Sound_00000000-00.analog-stereo>
flags: HARDWARE HW_MUTE_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9049
volume: front-left: 51401 / 78% / -6.33 dB, front-right: 51401 / 78% / -6.33 dB
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 1
module: 32
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
device.bus = "usb"
device.string = "front:0"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "HyperX 7.1 Audio Analog Stereo"
ports:
analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: unknown)
properties:
active port: <analog-input-headset-mic>
