S2 sleep and hibernate both work fine,
hybrid sleep works only if I try to boot the laptop back on after a short amount of time.
Leaving the laptop for a couple hours and then trying to boot from hybrid sleep results in a black screen (not even turned on).
Inxi output:
Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=0fae45e7-a05d-4151-bd5b-9720ebc67797 rw quiet splash apparmor=1
security=apparmor resume=UUID=e6409053-0f84-4a27-80f7-ba2108682f0a
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: HP product: HP EliteBook 840 14 inch G9 Notebook PC
v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8ABB v: KBC Version 20.06.00 serial: <filter> UEFI: HP
v: U71 Ver. 01.02.04 date: 05/23/2022
ID-1: BAT0 charge: 48.7 Wh (93.7%) condition: 52.0/51.3 Wh (101.3%)
volts: 12.6 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 12
RAM: total: 15.3 GiB used: 4.05 GiB (26.5%)
Array-1: capacity: 64 GiB slots: 2 EC: None max-module-size: 32 GiB
note: est.
Device-1: Bottom-Slot 1(left) type: DDR5 detail: synchronous size: 8 GiB
speed: 4800 MT/s volts: curr: 1.1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M425R1GB4BB0-CQKOD serial: <filter>
Device-2: Bottom-Slot 2(right) type: DDR5 detail: synchronous size: 8 GiB
Info: model: 12th Gen Intel Core i5-1235U socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x424
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2353 high: 2500 min/max: 400/4400:3300
base/boost: 3960/4400 scaling: driver: intel_pstate governor: powersave
volts: 1.2 V ext-clock: 100 MHz cores: 1: 2500 2: 2500 3: 741 4: 2500
5: 2500 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
bogomips: 59916
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Device-2: Quanta HP 5MP Camera type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:545b class-ID: 0e02 serial: <filter>
Display: server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: LG Display 0x06df built: 2021 res: 1920x1200 hz: 60
dpi: 161 gamma: 1.2 size: 302x188mm (11.89x7.4") diag: 356mm (14")
ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
IF-ID-1: wwan0 state: down mac: N/A
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 48.74 GiB (10.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HBLU-00BH1
lanes: 4 type: SSD serial: <filter> rev: HPS1NFAV temp: 19.9 C scheme: GPT
ID-1: / raw-size: 459.85 GiB size: 451.56 GiB (98.20%)
used: 48.74 GiB (10.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2 label: N/A uuid: 0fae45e7-a05d-4151-bd5b-9720ebc67797
used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: NO_LABEL uuid: 408B-0094
ID-1: swap-1 type: partition size: 16.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: e6409053-0f84-4a27-80f7-ba2108682f0a
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Quanta HP 5MP Camera type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:545b
Device-2: 3-7:5 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00f0
class-ID: ff00 serial: <filter>
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.0 C mobo: N/A
Processes: 323 Uptime: 1h 15m wakeups: 1279 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1316 pm: pacman pkgs: 1297 libs: 317 tools: gnome-software,pamac
pm: flatpak pkgs: 12 pm: snap pkgs: 7 Shell: Zsh (sudo) v: 5.9 default: Bash
v: 5.1.16 running-in: gnome-terminal inxi: 3.3.24
