Hello all. I am using a Dell Precision 5490. I am trying to use Manjaro (KDE) instead of Windows. Unfortunately, I am having issues with GPU (integrated intel graphics + Nvidia RTX Ada 2000). Most pressingly, this keeps happening:
This portion of the screen frequently flickers in this manner. It appears to be related to updates on the screen as it doesn’t appear/disappear unless there is keyboard input/mouse movement. There doesn’t seem to be any consistent trigger. I tried seeing if switching to just using nvidia GPU fixed it, but I have to use hybrid driver or else I get a black screen and I was unable to use optimus manager as, in addition to the bug requiring me to run prime-offload before optimus-manager, nothing happens when I do optimus-manager --switch nvidia, and changing the startup setting didn’t work either.
Any help would be appreciated!
post the output of theses 2 commands
echo $XDG_SESSION_TYPE && glxinfo | grep server
Looks like screen tearing…
What session type?
In case of Xorg, you could force Tearfree:
file:/etc/X11/xorg.conf.d/20-intel.conf
Section "Device"
Identifier "Intel Graphics"
Driver "intel"
Option "TearFree" "true"
EndSection
You could try disabling some power saving options, which might cause an issue:
file: /etc/modprobe.d/intel.conf
options i915 enable_psr=0
options i915 enable_dc=0
options i915 enable_fbc=0
options i915 verbose_state_checks=Y
options i915 mitigations=off
Reboot after creating the file to apply.
More information:
modinfo -p i915
Here are the outputs:
Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=20bce419-0170-49aa-877d-9701641fabf1 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Dell product: Precision 5490 v: N/A
Mobo: Dell model: 0G47P7 v: A00 serial: <superuser required> part-nu: 0CC7
uuid: <superuser required> UEFI: Dell v: 1.0.3 date: 01/25/2024
ID-1: BAT0 charge: 31.6 Wh (44.8%) condition: 70.6/70.6 Wh (100.0%)
volts: 14.2 min: 15.4 model: SMP DELL YXP8T425 type: Li-poly serial: <filter>
status: discharging cycles: 3
System RAM: total: 32 GiB available: 30.98 GiB used: 3.37 GiB (10.9%)
Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
max-module-size: 4 GiB note: est.
Device-1: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
spec: 8533 MT/s actual: 7467 MT/s volts: curr: 0.5 width (bits): data: 16
total: 16 manufacturer: N/A part-no: N/A serial: N/A
Device-2: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Device-3: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Device-4: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Device-5: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Device-6: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Device-7: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Device-8: Motherboard type: LPDDR5 detail: synchronous size: 4 GiB speed:
Info: model: Intel Core Ultra 7 165H bits: 64 type: MST AMCP
arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x1C
Topology: cpus: 1x cores: 16 mt: 5 tpc: 2 st: 11 threads: 21 smt: enabled
cache: 24 MiB note: check
Speed (MHz): avg: 1044 high: 3101 min/max: 400/3101 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 3101 2: 400 3: 600 4: 600
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 2706 13: 3101
14: 2100 15: 400 16: 3040 17: 400 18: 400 19: 1096 20: 800 21: 400
bogomips: 129066
bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht ibpb
ibrs ibrs_enhanced ibt ida intel_pt invpcid lahf_lm lm mca mce md_clear
mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae
pat pbe pcid pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt
pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize
sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tme tpr_shadow tsc tsc_adjust
tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: Dell driver: i915
v: kernel alternate: xe arch: Gen-13 process: Intel 4 (7nm+) built: 2023+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:7d55 class-ID: 0300
Device-2: NVIDIA AD107GLM [RTX 2000 Ada Generation Laptop GPU] vendor: Dell
driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:28b8
class-ID: 0302
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: AU Optronics 0xf99a built: 2021 res: 1920x1200
hz: 60 dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: 1920x1200
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.8-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
device-ID: 8086:7d55 memory: 30.25 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
RTX 2000 Ada Generation Laptop GPU driver: nvidia v: 550.78
device-ID: 10de:28b8 surfaces: xcb,xlib
Device-1: Intel vendor: Dell driver: N/A bus-ID: 00:05.0 chip-ID: 8086:7d19
class-ID: 0480
Device-2: Intel Meteor Lake-P HD Audio vendor: Dell
driver: sof-audio-pci-intel-mtl
alternate: snd_hda_intel,snd_sof_pci_intel_mtl bus-ID: 00:1f.3
chip-ID: 8086:7e28 class-ID: 0401
API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 7 AX1775 /AX1790 /BE20 /BE401/BE1750 2x2
driver: iwlwifi v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max:
gen: 4 speed: 16 GT/s bus-ID: 02:00.0 chip-ID: 8086:272b class-ID: 0280
IF: wlp2s0f0 state: up mac: <filter>
IP v4: <filter> type: dynamic scope: global broadcast: <filter>
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0036 class-ID: e001
Local Storage: total: 953.87 GiB used: 624.16 GiB (65.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: KXG80ZNV1T02 NVMe
1024GB size: 953.87 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 11304102
temp: 32.9 C scheme: GPT
ID-1: / raw-size: 780.75 GiB size: 767.43 GiB (98.29%)
used: 624.16 GiB (81.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 20bce419-0170-49aa-877d-9701641fabf1
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 36D1-9EDB
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 240 MiB fs: vfat label: ESP
uuid: 78F4-32F4
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 169.43 GiB fs: bitlocker
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 1.24 GiB fs: ntfs
label: WINRETOOLS uuid: 0410428A104282A2
ID-5: /dev/nvme0n1p5 maj-min: 259:5 size: 1.59 GiB fs: ntfs
label: DELLSUPPORT uuid: A6003CF1003CCA57
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-8:2 info: Intel USB Bridge type: <vendor specific>
driver: gpio_ljca,i2c_ljca,ljca,spi_ljca interfaces: 1 rev: 2.0
chip-ID: 8086:0b63 class-ID: 0000
Device-2: 3-9:3 info: Shenzhen Goodix Fingerprint USB Device
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 27c6:634c class-ID: ef00 serial: <filter>
Device-3: 3-10:4 info: Intel type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
System Temperatures: cpu: 48.0 C mobo: 40.0 C sodimm: Mem C
Fan Speeds (rpm): cpu: 2512 fan-2: 2514
Processes: 424 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
image: 12.36 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 255 default: graphical tool: systemctl
Packages: 1308 pm: pacman pkgs: 1300 libs: 424 tools: pamac pm: flatpak
pkgs: 8 Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
and:
x11
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
for switching to nvidia install envycontrol
pamac install envycontrol
and switch via
sudo envycontrol -s nvidia
reboot and recheck with
it should be nvidia instead sgi (intel)
Thanks for the suggestions! However the x11 setting gave me a blank screen. I tried enable_psr=0 via boot settings also and also got a blank screen. Additionally it is interesting to note that the issue occurs even in tty3 and immediately after selecting the manjaro option in the boot menu before the display manager ever loads!
@Olli
This was successful in switching to nvidia but unsuccessful in removing the screen flickering issue
use a live-iso and boot to a live session. use something different (linux mint or whatever). check if the problem still persist. a hardware failure might cause if the problem persist with a different os-system.
check this first.
I guess you need to modify this file: /usr/share/X11/xorg.conf.d/10-intel-nvidia-drm-outputclass.conf. Copy it to /etc/X11/xorg.conf.d/
Okay… so you did not as I suggested. Alright.
I was trying to say that previously I had tried it through boot settings so I was wondering if I should still try it this way. I’ll take that as a yes. Thanks for helping.
@Olli
I just tested with windows and confirmed it doesn’t occur there. Does it matter if its windows as opposed to linux?
Olli
30 May 2024 19:26
12
no it doesn’t matter. you’ve checked and prooved that it’s no hardware-failure. that’s fine.
a question, did you make any changes to any config files ?
@Olli
I think I have been having this problem since installing manjaro. In fact I reinstalled but it still happened. I don’t think I really changed anything significant other than what was mentioned in this thread.
Olli
30 May 2024 19:31
14
can you try a different kernel ? try kernel 6.1.xx or/and 6.6.xx that are marked as lts (long-term-support).
check what version with
uname -a
after installing and reboot.
I tried 6.6. However i get black screen only tty works. And flickering is occuring still on this tty screen
The black screen is actually most likely because I was also trying the intel tearing setting again. But again, 6.6 did not make a difference to the issue
6x12
30 May 2024 19:53
17
Edit: Sorry, info for wrong model, please delete.
Based on @megavolt 's suggestion that it sounds like screen tearing, I tried changing the refresh rate from 60Hz to 48Hz. Somehow, this appears to have worked, which is strange since the actual refresh rate of the monitor is 60Hz.
system
Closed
2 June 2024 02:51
19
