HWINFO for linux?
I have it in Windows 11, but my Windows color scheme messes it up, Is there a version for linux?
yes - package hwinfo - if you are point and click
pamac search system info
Depending on what you need, you may need several programs for it under linux. As far as gui goes, i do not know an exact analogue. For the command line, if you need system component information, you can use hwinfo or inxi. If you need temperatures, sensors is your friend.
There is a gui program psensors. Also, if you need cpu-z, an almost exact analogue is cpu-x, but it is not in the repos (appimage is available).
There is a similar package, as @linux-aarhus has already mentioned, but the following command-line using inxi also returns a wealth of system information:
inxi --admin --verbosity=8 --filter --no-host --width
This produces information that you might post when asking for support - all personally identifiable details are filtered out.
If you want those details (just for your own use) just leave out --filter --no-host from the command.
Cheers.
Ok how do I post what I got with out it being a huge post?
paste the output here.
:point_up_2: Just like that. Use 3 backticks before and after the pasted output. It creates a (scrollable) text box, (just like the HTML <pre> element), like this:
However, we don’t need that information right now. :slight_smile:
Copy it to somewhere handy for when you need the command again.
Cheers.
B450I GAMING Plus AC, starting to fail? | Page 3 | MSI Global English Forum I posted under Edward78 if you care. It is the last by me.
The backticks I mentioned are entered using the ` key, which you should find under the Esc key. You can edit the post and just replace the other characters that you used. If you’re using another keyboard language, and the key isn’t where I said it was, I can’t help with that; but, someone else might.
Cheers.
Or you can use
output
or you can select text and press </> button above. (What you have now is not it.)
  Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=7b6ceeeb-aa48-461a-bd38-cf33d381564c rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: B450I GAMING PLUS AC (MS-7A40) v: 2.0
    serial: <superuser required> uuid: <superuser required> BIOS: American
    Megatrends LLC. v: A.H3 date: 05/16/2023
  System RAM: total: 16 GiB available: 15.54 GiB used: 4.32 GiB (27.8%)
  Array-1: capacity: 128 GiB note: check slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
    (unregistered) size: 8 GiB speed: 2400 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD4-3200 serial: <filter>
  Info: model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+ gen: 2
    level: v3 note: check built: 2018-21 process: GF 12nm family: 0x17 (23)
    model-id: 8 stepping: 2 microcode: 0x800820D
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 768 KiB desc: d-8x32 KiB; i-8x64 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
    desc: 2x8 MiB
  Speed (MHz): avg: 1756 high: 3200 min/max: 1550/3200 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1550 2: 1550
    3: 1550 4: 1550 5: 1550 6: 1550 7: 1550 8: 3200 9: 3200 10: 1550 11: 1550
    12: 1550 13: 1550 14: 1550 15: 1550 16: 1550 bogomips: 102446
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
    cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
    flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
    lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
    sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
    v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
    xsaveerptr xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: eVga.com.
    driver: nvidia v: 550.67 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 29:00.0
    chip-ID: 10de:2489 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 140 s-size: 464x261mm (18.27x10.28")
    s-diag: 532mm (20.96") monitors: <missing: xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: nvidia v: 550.67 device-ID: 10de:2489
    surfaces: xcb,xlib
  Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
    link-max: gen: 4 speed: 16 GT/s bus-ID: 29:00.1 chip-ID: 10de:228b
    class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    bus-ID: 2b:00.3 chip-ID: 1022:1457 class-ID: 0403
  Device-3: Realtek LG Monitor HP MIC driver: hid-generic,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.4:7
    chip-ID: 0bda:4027 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 26:00.0
    chip-ID: 8086:24fb class-ID: 0280
  IF: wlp38s0 state: down mac: <filter>
  Info: services: NetworkManager,wpa_supplicant
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 8087:0aa7
    class-ID: e001
  Local Storage: total: 1.82 TiB used: 13.28 GiB (0.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech.
    model: SHGS31-1000GS-2 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0Q00
    scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUD0N rev: 1.00
    dev-links: cdrom
  ID-1: / raw-size: 767.48 GiB size: 754.36 GiB (98.29%) used: 13.28 GiB (1.8%)
    fs: ext4 dev: /dev/sdb4 maj-min: 8:20 label: N/A
    uuid: 7b6ceeeb-aa48-461a-bd38-cf33d381564c
  ID-1: swap-1 type: partition size: 17.15 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sdb3 maj-min: 8:19 label: swap
    uuid: 432e1292-b63d-42c2-8b0f-55fed2854879
  ID-1: /dev/sda1 maj-min: 8:1 size: 118.02 GiB fs: ntfs label: N/A
    uuid: FEDE7716DE76C705
  ID-2: /dev/sda2 maj-min: 8:2 size: 100 MiB fs: vfat label: NO NAME
    uuid: B362-0880
  ID-3: /dev/sda3 maj-min: 8:3 size: 538 MiB fs: ntfs label: N/A
    uuid: 407C57BC7C57AC02
  ID-4: /dev/sda4 maj-min: 8:4 size: 621.03 GiB fs: ntfs label: Data
    uuid: 1CE33ADD03B8E5A9
  ID-5: /dev/sda5 maj-min: 8:5 size: 191.83 GiB fs: ntfs label: Download
    uuid: 0AB4DCAC3851D241
  ID-6: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: vfat label: N/A
    uuid: 6DB0-0A0F
  ID-7: /dev/sdb2 maj-min: 8:18 size: 146.59 GiB fs: ext4 label: N/A
    uuid: 00fe227e-366b-4a04-a791-494353b485a6
  Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 1-1.1:4 info: Logitech F310 Gamepad [XInput Mode]
    type: <vendor specific> driver: xpad interfaces: 1 rev: 2.0
    chip-ID: 046d:c21d class-ID: ff00 serial: <filter>
  Device-2: 1-1.3:6 info: LG USA Monitor Controls
    type: HID,abstract (modem),CDC-data driver: cdc_acm,hid-generic,usbhid
    interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 043e:9a8a class-ID: 0a00 serial: <filter>
  Device-3: 1-1.4:7 info: Realtek LG Monitor HP MIC type: HID
  Device-4: 1-2:3 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4b61 class-ID: 0301
  Device-5: 1-8:5 info: Intel Wireless-AC 3168 Bluetooth type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0aa7 class-ID: e001
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 2-1:2 info: Realtek Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-4:2 info: Microsoft Classic IntelliMouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 045e:0823 class-ID: 0300
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 49.2 C mobo: N/A gpu: nvidia temp: 43 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 36%
  Packages: pm: pacman pkgs: 1177 libs: 358 tools: pamac pm: flatpak pkgs: 0
    1: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    3: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 318
  1: cpu: 33.1% command: firefox pid: 1158 mem: 768.7 MiB (4.8%)
  2: cpu: 10.9% command: firefox pid: 1672 mem: 233.0 MiB (1.4%)
  3: cpu: 8.7% command: firefox pid: 1634 mem: 125.6 MiB (0.7%)
  4: cpu: 5.2% command: kwin_x11 pid: 822 mem: 294.6 MiB (1.8%)
  5: cpu: 3.2% command: Xorg pid: 711 mem: 119.4 MiB (0.7%)
  Memory top: 5 of 318
  1: mem: 768.7 MiB (4.8%) command: firefox pid: 1158 cpu: 33.1%
  2: mem: 500.2 MiB (3.1%) command: firefox pid: 12589 cpu: 2.8%
  3: mem: 477.6 MiB (3.0%) command: plasmashell pid: 861 cpu: 0.9%
  4: mem: 455.4 MiB (2.8%) command: firefox pid: 1449 cpu: 3.0%
  5: mem: 387.7 MiB (2.4%) command: firefox pid: 1478 cpu: 0.7%
  Processes: 318 Power: uptime: 3h 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.34
Good job! :partying_face:
No ESP? Have you installed in BIOS mode? If yes, then you have chosen a rather unfavorable combination of BIOS mode and gpt parted disk. Could be changed:
I think there is a problem.
Incorrectly assembled or configured
1 x PCIe 3.0 x16 slot
Supports x16 speed with AMD® Ryzen™ 1st and 2nd Generation processors
Supports x8 speed with AMD® Ryzen™ with Radeon Vega Graphics processors
yo have
run sensors-detect and answer all questions with yes
I am used to MATE termininzl, I paste that it says I need to be roor, but when I type sudo comands pop up after it.
Maybe cpu-x or hardinfo2? Both are in the AUR (Arch User Repository).
https://forum.manjaro.org/t/howto-use-public-command-line-pastebin-services-without-installing-anything/38378/1
I never see a Monitoring Program in Linux that comes even close to the superior information from HwInfo in Windows Environment…
I miss in Linux all possible sensor data… all my 5x Casefan’s/2xCPU Fan’s/2xGPU Fan’s/GPU Temp/GPU Hot Spot Temp/VRam Temp/Ram Timings/Ram Temp/Wear Status from SSD, a.s.o.
The information is perfect with this HWinfo (Windows application).
HwInfo/sensors/inxi under Linux is a joke, when i compare it to HwInfo (Windows Application) :face_with_thermometer:
The difference is night/day… this is still a really big handicap for Linux User’s like us and i could go on with MSI Afterburner (GPU undervolting isn’t possible) or did i miss here something?
:scream:
There’s always Conky…
However, Eww seems interesting: ElKowars wacky widgets
Cheers.
I always found linux information to be leagues better than what you find in windoze.
Now whether that information looks fancy or is easy to read for a newbie may be another matter.
As to HWINFO64 or whatever (a third party application on windoze) … based mainly on its aesthetic appearance … kinfocenter might be something you are looking for?
Maybe?
I might be beginning to gather what you are after is something like “OEM Control Panel”.
Of course it should not be surprising that such tools are more common on windoze for a hundred reasons.
But I would still wager that in most scenarios if you know what you want to do … you will find a linux tool for that and it will probably be superior to the crapware that came with your windoze.
If you even need a standalone utility at all. intel-undervolt etc.
