The poll tells me to share what my issue was and how I fixed it, so here it is:
I did an upgrade from two stable updates ago. There were an incredible ONETHOUSANDEIGHTHUNDREDANDNINETYSEVEN updates! It took around four hours and in the meantime made pretty much the entire system unusable, I could only click in the update terminal, but the keyboard didn’t work, the title bar was gone, KDE was frozen and so on.
I could still do some stuff via KDE Connect at first, but later that lost its connection as well.
After a long time and thousands of screen pages of GCC spam (even with “-w” it’s still really bad), I got another of the way too many confirmation prompts and couldn’t press Enter, so I killed the process from the menu bar, switched to line-only mode, killed yay and pacman there (no idea why that was necessary), removed the lock file and continued updating. Another couple thousands of screen pages of GCC output later, updates were done.
I did install kwin-x11 and plasma-x11-session, but after the reboot, it still started with Wayland, without asking me. I decided to give it a try, but it only took me 18 minutes to get way too annoyed with it, so I switched back to X11 (that’s my “solution”).
Weirdly, xdotool actually seems to mostly work. I had to change a bunch of settings to make it and “copyq” work again. But even with the most lenient settings, “gazou” couldn’t register hotkeys, there was a console error about reading the screen also not working and “screenkey” couldn’t show clicks and counted as a full window.
Touchpad settings were reset. Autostart seemed completely broken.
Even after switching back, I still can’t start a script with “./temp.sh &”, only “./temp” works, very weird. I’ll debug that later.
I also can’t move KDE elements (start menu, calendar, notifications, …) with Super+drag anymore. My thin start menu icon is now square again, so there’s a bunch of unused space.
Mod edit: Formatted for better readability. ![]()
