You can try to turn off the NVIDIA card in BIOS. But I think that a better idea will install non-free drivers and create a file named 80-nvidia-pm.rules
in /lib/udev/rules.d/
directory. Edit this file with your favourite text editor and enter there this text:
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x0c0330”, ATTR{remove}=“1”
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x0c8000”, ATTR{remove}=“1”
ACTION==“add”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x040300”, ATTR{remove}=“1”
ACTION==“bind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030000”, TEST==“power/control”, ATTR{power/control}=“auto”
ACTION==“bind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030200”, TEST==“power/control”, ATTR{power/control}=“auto”
ACTION==“unbind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030000”, TEST==“power/control”, ATTR{power/control}=“on”
ACTION==“unbind”, SUBSYSTEM==“pci”, ATTR{vendor}==“0x10de”, ATTR{class}==“0x030200”, TEST==“power/control”, ATTR{power/control}=“on”
Next, you should edit file in /etc/modprobe.d/nvidia.conf
and write this text:
options nvidia "NVreg_DynamicPowerManagement=0x02"
Then reboot and everything should be fine.
