Hi all!
I have permanent problem with suspend laptop to s2idle.
So, after press “KDE sleep” or lid close, I have black screen and freeze. Fn and Cals is on. Cooling system is on.
inxi -zav7
  Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    root=UUID=0a332c60-2018-43c5-adfb-ae626f733e4c rw quiet
    cryptdevice=UUID=02399a1f-a34f-4854-9c75-8f0bdb32fdd5:luks-02399a1f-a34f-4854-9c75-8f0bdb32fdd5
    root=/dev/mapper/luks-02399a1f-a34f-4854-9c75-8f0bdb32fdd5 splash
    udev.log_priority=3 ibt=off mem_sleep_default=deep nowatchdog
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
  Type: Laptop System: HUAWEI product: RLEF-XX v: M1010 serial: <filter>
  Mobo: HUAWEI model: RLEF-XX-PCB v: M1010 serial: <filter> UEFI: HUAWEI
    v: 1.26 date: 01/30/2023
  ID-1: BAT0 charge: 32.5 Wh (53.5%) condition: 60.8/59.4 Wh (102.3%)
    power: 33.9 W volts: 12.3 min: 11.6 model: DESAY HB5781P1EEW-31T
    type: Li-ion serial: <filter> status: charging cycles: 4
  System RAM: total: 16 GiB available: 15.36 GiB used: 3.15 GiB (20.5%)
    igpu: 60 MiB
  Array-1: capacity: 16 GiB slots: 8 modules: 8 EC: None
    max-module-size: 2 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR4 detail: synchronous
    size: 2 GiB speed: spec: 4267 MT/s actual: 3733 MT/s volts: curr: 0.6
    width (bits): data: 64 total: 64 manufacturer: N/A part-no: N/A
    serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR4 detail: synchronous
    serial: N/A
  Device-3: Controller0-ChannelC type: LPDDR4 detail: synchronous
    serial: N/A
  Device-4: Controller0-ChannelD type: LPDDR4 detail: synchronous
    serial: N/A
  Device-5: Controller1-ChannelA type: LPDDR4 detail: synchronous
    serial: N/A
  Device-6: Controller1-ChannelB type: LPDDR4 detail: synchronous
    serial: N/A
  Device-7: Controller1-ChannelC type: LPDDR4 detail: synchronous
    serial: N/A
  Device-8: Controller1-ChannelD type: LPDDR4 detail: synchronous
    serial: N/A
  Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x42A
  Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
    cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB
    L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 1099 high: 2500 min/max: 400/4400:3300
    base/boost: 4059/4400 scaling: driver: intel_pstate governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 778 2: 627 3: 777 4: 2500 5: 574
    6: 2500 7: 564 8: 2500 9: 559 10: 630 11: 619 12: 569 bogomips: 59916
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb
    pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
    rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss
    ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
    filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Huawei driver: i915
    v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:46a3 class-ID: 0300
  Device-2: Quanta FHD Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 0408:1060
  Display: server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
    s-diag: 599mm (23.57")
  Monitor-1: eDP-1 model: BOE Display 0x0a74 built: 2021 res: 1920x1200
    hz: 60 dpi: 141 gamma: 1.2 size: 345x215mm (13.58x8.46") diag: 407mm (16")
    ratio: 16:10 modes: 1920x1200
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Graphics (ADL GT2)
    direct-render: Yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Huawei
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.74 status: n/a (root, process) with: wireplumber
    status: active tools: pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
    class-ID: e001
  Device-1: luks-02399a1f-a34f-4854-9c75-8f0bdb32fdd5 maj-min: 254:0
    type: LUKS dm: dm-0 size: 476.64 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 476.64 GiB
  Local Storage: total: 476.94 GiB used: 240.82 GiB (50.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: PCIe-8 SSD 512GB size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: YM00D216 temp: 37.9 C scheme: GPT
  SMART: yes health: PASSED on: 61 hrs cycles: 73
    read-units: 2,969,865 [1.52 TB] written-units: 1,712,265 [876 GB]
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 240.81 GiB (51.4%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: luks-02399a1f-a34f-4854-9c75-8f0bdb32fdd5
    label: N/A uuid: 0a332c60-2018-43c5-adfb-ae626f733e4c
    used: 11.4 MiB (3.8%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: 5529-4233
  ID-1: swap-1 type: file size: 20 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-7:2 info: Quanta FHD Camera type: video driver: uvcvideo
    interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 0408:1060 class-ID: fe01 serial: <filter>
  Device-2: 3-10:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0026 class-ID: e001
  System Temperatures: cpu: 40.0 C mobo: N/A
  Processes: 284 Uptime: 12m wakeups: 1 Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1260 libs: 372 tools: pamac Shell: Bash (sudo)
  v: 5.1.16 running-in: konsole inxi: 3.3.28
journalctl --boot -2 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
июл 22 09:22:03 apanyovin-hw systemd[1]: Starting System Suspend...
июл 22 09:22:03 apanyovin-hw wpa_supplicant[1082]: p2p-dev-wlp0s20: CTRL-EVENT-DSCP-POLICY clear_all
июл 22 09:22:03 apanyovin-hw wpa_supplicant[1082]: nl80211: deinit ifname=p2p-dev-wlp0s20 disabled_11b_rates=0
июл 22 09:22:03 apanyovin-hw wpa_supplicant[1082]: wlp0s20f3: CTRL-EVENT-DSCP-POLICY clear_all
июл 22 09:22:03 apanyovin-hw systemd-sleep[6218]: Entering sleep state 'suspend'...
июл 22 09:22:03 apanyovin-hw kernel: PM: suspend entry (deep)
Thanks!
