fatal: unable to access 'https://github.com/itay-grudev/SingleApplication/': HTTP/2 stream 1 was not closed cleanly before end of the underlying stream
fatal: clone of 'https://github.com/itay-grudev/SingleApplication' into submodule path '/var/tmp/pamac-build-firestar/qv2ray/src/Qv2ray/3rdparty/SingleApplication' failed
Failed to clone '3rdparty/SingleApplication'. Retry scheduled
Cloning into '/var/tmp/pamac-build-firestar/qv2ray/src/Qv2ray/3rdparty/libuv'...
fatal: unable to access 'https://github.com/libuv/libuv.git/': HTTP/2 stream 1 was not closed cleanly before end of the underlying stream
fatal: clone of 'https://github.com/libuv/libuv.git' into submodule path '/var/tmp/pamac-build-firestar/qv2ray/src/Qv2ray/3rdparty/libuv' failed
Failed to clone '3rdparty/libuv'. Retry scheduled
Cloning into '/var/tmp/pamac-build-firestar/qv2ray/src/Qv2ray/3rdparty/puresource'...
The original qv2ray repository have been âarchivedâ
There is already a fork packaged as âqv2ray-static-bin-nightlyâ on AUR but note that is not following best packaging practice (not using source=(), unversioned download, wrong pkgbuild name)
