Hi running the latest (just installed) manjaro with material shell (15.15.32-1-MANJARO).
When I:
1 launch htop from the GUI and
2 then try to stop it by closing the window
3 the system hangs hard and I have to reboot.
I can open another window and kill the htop process with no ill effect.
I can launch htop in the terminal and kill it or stop it with Ctrl-C no problem.
I thought this might have something to do with the desktop file since terminal is set to true so I tried ranger which also has “terminal=true” but it has no similar problem.
And I tried down grading to the 15.10 kernel but that seems to have no effect either.
So looking for ideas about how to debug/diagnose this.
thanks
provide formated output from:
inxi -Fazy
try uninstalling htop, reboot, install again, reboot and check
I tried uninstall reboot reinstall reboot and there was no change in the behavior.
The only wrinkles I can add are:
1 sometimes I can do the scenario once and there is no hang (but seems to always happen on the second attempt)
2 sometimes the terminal window closes before the hang and sometimes the hang happens with the window still open.
Kernel: 5.10.109-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=1de6f716-b326-4b89-a898-76546e455586 rw quiet splash apparmor=1
Desktop: GNOME v: 41.5 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Desktop Mobo: BESSTAR TECH model: UM700 v: V1.0
serial: <superuser required> UEFI: American Megatrends v: AF5NV701.25
date: 12/15/2020
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1279 high: 1438 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1438 2: 1242
3: 1230 4: 1223 5: 1252 6: 1233 7: 1324 8: 1296 bogomips: 36748
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: Dell S2719DGF serial: <filter> built: 2020
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 model: Dell D3218HN serial: <filter> built: 2018
res: 1920x1080 dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47")
diag: 801mm (31.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon Vega 10 Graphics (RAVEN DRM 3.40.0
5.10.109-1-MANJARO LLVM 13.0.1)
v: 4.6 Mesa 21.3.8 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.1
chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.10.109-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: eno1 state: down mac: <filter>
bus-ID: 3-2:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 5.92 TiB used: 1.55 TiB (26.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-A02
lanes: 4 type: SSD serial: <filter> rev: ECFK52.9 temp: 47.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Toshiba model: EXTERNAL USB
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 5438 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
model: WD20NMVW-11EDZS3 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: HDD rpm: 5200 serial: <filter> rev: 1065 scheme: MBR
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 66.24 GiB (14.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
System Temperatures: cpu: 65.4 C mobo: N/A gpu: amdgpu temp: 65.0 C
Processes: 279 Uptime: 6m wakeups: 0 Memory: 15.4 GiB used: 2.25 GiB (14.6%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: 1347 pacman: 1343 lib: 317 flatpak: 0 snap: 4 Shell: Zsh v: 5.8.1
running-in: gnome-terminal inxi: 3.3.15
try switching to wayland or x11
also check logs after the issue happens
It seems per the inxi output I am running wayland - will try staight x11
X11 still has same behavior.
looking at inxi output under display it now says x11 (not wayland server)
and did you check the logs when the freeze happen
Here is the complete log on google drive
there was only 1 related htop log and it was succesfull … realle have no idea… try disable all extension, reboot, and check if it freezes again
