Hi group
I have hplip installed for use with my HP Laser printer.
Now I’m considering an HP ScanJet Pro 2600 f1 but am not sure how to verify there are drivers for it included in hplip, or elsewhere, before I buy. HP used to have a site you could go to specifically look for linux drivers but now it seems like they’re pointing to hplip. Fine, but can I verify support for this scanner before I try to connect it?
Thanks for your advice.
Reid
- Group Search | hp's Developer Portal
- HP Linux Imaging and Printing | hp's Developer Portal
- All Supported Printer Models | hp's Developer Portal
- HP ScanJet Pro 2600 f1 - HP Store Deutschland
- https://www8.hp.com/h20195/V2/GetPDF.aspx/c08228421
Kompatible Betriebssysteme
Windows 11
Windows 10
Windows 8
Windows 8.1
Windows 7
Windows Server
macOS 10.14 Mojave
macOS 10.15 Catalina
macOS 11 Big Sur
macOS 12 Monterey
Linux
Release Notes | hp's Developer Portal
HPLIP 3.22.4 - This release has the following changes:
Added support for following new Distro’s:
Manjaro 21.2
Added support for the following new Printers:
Thanks very much Bango and nikgnomic
