Hplaserjet 1020 not detecting by Hp device manager
After installing hplip and detecting hplaserjet 1020 printer, the hp manager software is not detecting my usb printer after power is on.
Search the forum…
I don’t know who maintains the hplip package but those issues can be partly avoided if the maintainer patch models.dat file in the package?
I recommend installing the manjaro-printer meta-package, it will install several packages for printer drivers and management, such as cups and foomatic. You might manage to get your printer working through those.
https://developers.hp.com/hp-linux-imaging-and-printing/binary_plugin.html
https://aur.archlinux.org/packages/hplip-plugin
Install hplip-plugin from AUR.
Hi, @harupat
Welcome to the forum, I wonder whether you could read the following post and try to install the printer as Inxi wrote. Some old printers have no support with hplip.
[SOLVED] hplip and LaserJet 1020 issues / Kernel & Hardware / Arch Linux Forums
This post was helpful to me when I installed my hp LaserJet 1020 printer.
Follow the steps 1 to 4 in the above link of the first post.
Hope it helps, regards,
not working
stay on hplip software..
not installed in my machine.gives some install error..
