Hi,
I’m not really used to asking help on fora but right now I’m having such a hard time.
I recently switched to Linux on my HP Spectre 15-eb0xxx for multiple reasons.
First I went on Ubuntu 20.10 but I had many issues, including no sound coming from speakers. Then I switched to Manjaro and most of my issues were solved, except for the sound (btw I have not installed a dual boot, just linux and erased the drive).
Here’s my issue : not a single sound is coming out of my speakers, although they’re recognized but my system, when I play a video, the sound settings tells me that sound is coming out of the speakers, and when I plug jack headphones they work just fine, along with bluetooth devices…
I have been looking on the web for more than a week now and ran out of solutions, I have checked alsamixer, modified the /etc/modprobe.d/.conf file, disabled Secure Boot but nothing seems to work so I came here for help. Furthermore, I have changed kernel (I currently run the 5.9.1 but I’ve tried every single one from the 5.4.8 to the 5.10) and distros, still the same issue.
Here’s the output of inxi -Fza :
Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=621e9748-b43f-4387-9473-496a7894984f rw quiet splash apparmor=1
Desktop: GNOME 3.38.1 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.38.2
Distro: Manjaro Linux
Type: Convertible System: HP
product: HP Spectre x360 Convertible 15-eb0xxx v: N/A serial: <filter>
Chassis: type: 31 serial: <filter>
Mobo: HP model: 86E8 v: 01.72 serial: <filter> UEFI: AMI v: F.05
date: 04/28/2020
ID-1: BAT0 charge: 12.2 Wh condition: 64.7/64.7 Wh (100%) volts: 12.3/11.6
model: HP Primary type: Li-ion serial: <filter> status: Charging
cycles: 165
Device-1: hid-0018:04F3:2A54.0001-battery model: ELAN2514:00 04F3:2A54
serial: N/A charge: N/A status: N/A
Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: N/A
family: 6 model-id: A5 (165) stepping: 2 microcode: E0 L2 cache: 12.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
bogomips: 62431
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800
3: 801 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:9bc4
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f95
Display: x11 server: X.org 1.20.10 compositor: gnome-shell
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:06c8
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Intel Wireless-AC 9462/9560 driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3 chip ID: 8086:06f0
Local Storage: total: 953.87 GiB used: 47.57 GiB (5.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB1T0HBLR-000H1
size: 953.87 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: HPS0NEXF scheme: GPT
ID-1: / raw size: 953.57 GiB size: 937.60 GiB (98.33%)
used: 47.57 GiB (5.1%) fs: ext4 dev: /dev/nvme0n1p2
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 319 Uptime: 4m Memory: 15.38 GiB used: 1.77 GiB (11.5%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: 1287 pacman: 1274
lib: 401 flatpak: 7 snap: 6 Shell: Zsh v: 5.8 running in: gnome-terminal
inxi: 3.1.08
And the output of lspci :
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics (rev 05)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:13.0 Serial controller: Intel Corporation Device 06fc
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:14.3 Network controller: Intel Corporation Wireless-AC 9462/9560
00:15.0 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:15.1 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH Serial IO I2C Controller #1
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:1b.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #17 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.7 PCI bridge: Intel Corporation Device 06b7 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
00:1f.3 Multimedia audio controller: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller [0c80]: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
02:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
03:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
04:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
38:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
6d:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
6e:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS525A PCI Express Card Reader (rev 01)
I hope someone can help me because I’m starting to lose hope and really don’t want to go back to Windows, especially considering how much I enjoy Manjaro.
Thank you very much
