I can’t get a printer to work. I can add them to CUPS. HP Device Manager does not see them. Same for USB, Wifi.
Magically Manjaro found my HP Envy 5000. Still having problems with the P1102W Laserjet. I can add OK but it won’t work
You might need to install a driver. Without knowing the model, there is no way on telling. Usually hplip
package should help …
try running hp-doctor
in terminal and follow the steps. Make sure printer is connected to the pc
Have you checked this to make sure you have printing enabled
Printing - Manjaro.
I’ve always found HPLIP useless. Currently it cannot find a printer which is installed and working.
hp-doctor is not configured for Manjaro:
cmd =python-pyqt5
error: Failed to install ‘python-pyqt5’ package, please install manually.
cmd =make
error: Failed to install ‘make’ package, please install manually.
cmd =xsane
error: Failed to install ‘xsane’ package, please install manually.
If you need to install these packages,
sudo pacman -S python-pyqt5 xsane base-devel
Many thanks. I solved the problem in CUPS by changing the hpcups driver to ‘IPP’. However, HP Device Manager still fails to find my wifi printers.
