HP printer seen but not responding to print commands
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=722d2fc0-e926-4117-8d67-d114ac83bcc8 rw quiet splash
    resume=UUID=c6d32ee6-aa10-4c68-ae27-261ad233c02e udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.18.0
  Mobo: ASUSTeK model: PRIME Z690-A v: Rev 1.xx serial: <superuser required>
    part-nu: SKU uuid: <superuser required> UEFI: American Megatrends v: 4101
    date: 12/03/2024
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
    status: discharging
  System RAM: total: 128 GiB available: 125.54 GiB used: 7.04 GiB (5.6%)
  Array-1: capacity: 256 GiB slots: 4 modules: 4 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Controller0-DIMM0 type: DDR5 detail: synchronous size: 32 GiB
    speed: 4000 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Crucial Technology
    part-no: CT32G48C40U5.M16A1 serial: <filter>
  Device-2: Controller0-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
  Device-3: Controller1-DIMM0 type: DDR5 detail: synchronous size: 32 GiB
  Device-4: Controller1-DIMM1 type: DDR5 detail: synchronous size: 32 GiB
  Info: model: 12th Gen Intel Core i7-12700 bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
    microcode: 0x3A
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
    st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
    KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB desc: 1x25 MiB
  Speed (MHz): avg: 800 min/max: 800/4800:4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 84500
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pconfig pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: XFX Pine driver: amdgpu v: kernel
    arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20 pcie:
    gen: 3 speed: 8 GT/s lanes: 16 ports: active: DVI-D-1,HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 55.0 C
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1200 s-dpi: 96 s-size: 1016x317mm (40.00x12.48")
    s-diag: 1064mm (41.9") monitors: <missing: xrandr>
  Monitor-1: DVI-D-1 model: Samsung SyncMaster serial: <filter> built: 2007
    res: 1920x1200 dpi: 94 gamma: 1.6 size: 518x324mm (20.39x12.76")
    diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
  Monitor-2: HDMI-A-1 model: Acer G276HL serial: <filter> built: 2016
    res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 580 Series (radeonsi
    polaris10 ACO DRM 3.61 6.12.48-1-MANJARO) device-ID: 1002:67df
    memory: 7.81 GiB unified: no
  API: Vulkan v: 1.4.321 layers: 1 device: 0 type: discrete-gpu name: AMD
    Radeon RX 580 Series (RADV POLARIS10) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:67df surfaces: N/A
  Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon RX
    470/480 / 570/580/590] vendor: XFX Pine driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0
    class-ID: 0403
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
  Local Storage: total: 5.91 TiB used: 1.72 TiB (29.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 38.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 2000GB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 04RL scheme: MBR
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20SDRW-11VUUS0 size: 1.82 TiB block-size: physical: 512 B
    logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
  Optical-1: /dev/sr0 vendor: ASUS model: DRW-24B1ST a rev: 1.04
    dev-links: cdrom
  Optical-2: /dev/sr1 vendor: TSSTcorp model: CD/DVDW SH-S183L rev: SB03
    dev-links: N/A
  ID-1: / raw-size: 50.04 GiB size: 48.95 GiB (97.83%) used: 27.83 GiB (56.9%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 722d2fc0-e926-4117-8d67-d114ac83bcc8
    used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: C191-DE1A
  ID-3: /home raw-size: 1.76 TiB size: 1.73 TiB (98.37%)
    used: 85.77 GiB (4.8%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: db4ac4df-c377-4d7f-a120-89b91f6f430e
  ID-4: /home/<filter>/attic raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 801.45 GiB (43.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: attic
    uuid: 91039440-2cde-4e0c-abe0-5d76dc558502
  ID-5: /home/<filter>/halfgig raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 153.34 GiB (33.5%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: halfgig
    uuid: 19c76030-ac89-44a6-943a-b1233a08d128
  ID-6: /mnt/usb raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
    used: 697.91 GiB (38.1%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33
    label: Easystore uuid: c942fb5b-f39b-4fb7-bd99-ae52684aa502
  ID-1: swap-1 type: partition size: 8 GiB used: 2.5 MiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: c6d32ee6-aa10-4c68-ae27-261ad233c02e
  Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-2.1:8 info: HP LaserJet 2300d type: printer driver: usblp
    interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    chip-ID: 03f0:0b17 class-ID: 0701 serial: <filter>
  Device-2: 1-2.2:6 info: Holtek Keyboard [Diatec Filco Majestouch 2]
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 04d9:1818 class-ID: 0301
  Device-3: 1-4:3 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Device-4: 1-6:5 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-5: 1-10:7 info: Wacom PTZ-630 [Intuos3 (6x8)] type: mouse
    driver: usbhid,wacom interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 056a:00b1 class-ID: 0301
  Hub-3: 2-0:1 info: super-speed hub ports: 9 rev: 3.1
  Device-1: 2-4:2 info: Western Digital easystore 2648 type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 1058:2648 class-ID: 0806
    serial: <filter>
  Hub-4: 2-9:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  System Temperatures: cpu: 35.8 C mobo: N/A gpu: amdgpu temp: 55.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 775
  Processes: 415 Power: uptime: 1d 18h 19m states: freeze,mem,disk
    suspend: deep avail: s2idle wakeups: 2 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 50.19 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1521 libs: 393 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.3
    running-in: konsole inxi: 3.3.39
HP printer seen but not printing (no response) when “print” command sent.
What I’ve tried so far:
[sudo] password for chas:
Failed to enable unit: Unit now.service does not exist
lsusb -v | grep -A 3 bInterfaceClass.*7
zsh: no matches found: bInterfaceClass.*7
Couldn't open device, some information will be missing
zsh: command not found: manjaro-printer
install manjaro-printer
install: missing destination file operand after 'manjaro-printer'
Try 'install --help' for more information.
pamac install manjaro-printer
Preparing...
Warning: manjaro-printer-20240827-1 is up to date -- skipping
Nothing to do.
pamac build hplip-plugin
Preparing...
Checking hplip-plugin dependencies...
Resolving dependencies...
Checking inter-conflicts...
To install (3):
  libusb-compat  0.1.8-2     (Required By: hplip-plugin)  extra  13.8 kB
  python-distro  1.9.0-3     (Required By: hplip-plugin)  extra  38.2 kB
  hplip          1:3.25.6-1  (Required By: hplip-plugin)  extra  23.3 MB
To build (1):
  hplip-plugin   3.25.2-1                                 AUR
Total download size: 23.4 MB
Total installed size: 41.0 MB
Edit build files : [e]
Apply transaction ? [e/y/N] y
Cloning hplip-plugin build files...
fatal: unable to access 'https://aur.archlinux.org/hplip-plugin.git/': Recv failure: Connection reset by peer
Error: Failed to prepare transaction: Failed to clone hplip-plugin build files
Don’t know what to do next.
Are you certain you need to install these drivers from the AUR?
I have installed only this without any AUR stuff. I think this should do already.
What do you mean by the “print” command - is this from the command line? Have you tried printing from multiple apps?
Do you have hplip installed (sudo -Syu hplip)?
Only some printers need the hplip-plugin (this is a separate package from hplip); there is a list here of printers which require the extra package:
https://developers.hp.com/hp-linux-imaging-and-printing/binary_plugin.html
It looks like you have a HP LaserJet 2300d and since I don’’t see it on the list, you probably don’e need the plugin.
I’m a bit confused by
manjaro-printer is a meta-package which pulls in multiple packages required for printing - it is not a command.
Problem solved by going into CUPS settings, deselecting “Allow all users except:” (there were no exceptions) and selecting “Allow only this user:” (or some such wording) and added my computer user name in the “location” column. Printer now works like it should.
