HP OMEN 16 drains battery even if shut down
Good morning everyone, I have installed Manjaro with Cinnamon as the desktop environment on an HP OMEN 16. I am encountering several minor issues, but the most annoying one is that the laptop does not shut down properly; or rather, it does shut down, but if I disconnect the power adapter, the battery is completely empty the next morning.
Here is my PC (say hello to OMEN…):
inxi -zv8
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=6b8a67a2-32d1-4930-986f-6749c219b578 rw rootflags=subvol=@
    quiet apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=force
    acpi_rev_override=5 mem_sleep_default=deep
  Desktop: Cinnamon v: 6.6.7 tk: GTK v: 3.24.51 wm: Muffin v: 6.6.3 tools:
    avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: HP product: OMEN Gaming Laptop 16-ap0xxx v: N/A
  Mobo: HP model: 8E35 v: 99.20 serial: <superuser required>
    part-nu: C0DT0EA#ABZ uuid: <superuser required> Firmware: UEFI vendor: AMI
    v: F.08 date: 07/24/2025
  ID-1: BAT0 charge: 55.7 Wh (81.8%) condition: 68.1/68.1 Wh (100%)
    volts: 16.6 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
    charging: status: not charging cycles: 2
  System RAM: total: 32 GiB available: 30.4 GiB used: 8.66 GiB (28.5%)
  Device-1: Bottom - Slot 1 (top) type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M425R2GA3EB0-CWMOL serial: <filter>
  Device-2: Bottom - Slot 2 (under) type: DDR5 detail: synchronous
    unbuffered (unregistered) size: 16 GiB speed: spec: 5600 MT/s
    actual: 5200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M425R2GA3EB0-CWMOL
    serial: <filter>
  Info: model: AMD Ryzen 9 8940HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 16 MiB
    desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 2629 min/max: 422/5386 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 2629 2: 2629 3: 2629
    4: 2629 5: 2629 6: 2629 7: 2629 8: 2629 9: 2629 10: 2629 11: 2629 12: 2629
    13: 2629 14: 2629 15: 2629 16: 2629 17: 2629 18: 2629 19: 2629 20: 2629
    21: 2629 22: 2629 23: 2629 24: 2629 25: 2629 26: 2629 27: 2629 28: 2629
    29: 2629 30: 2629 31: 2629 32: 2629 bogomips: 153310
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GB206M [GeForce RTX 5070 Max-Q / Mobile]
    vendor: Hewlett-Packard driver: nvidia v: 590.48.01
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-11) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    link-max: gen: 5 speed: 32 GT/s lanes: 16 ports: active: none
    empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2d18 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Hewlett-Packard
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: DP-1,Writeback-1 bus-ID: 06:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 52.0 C
  Device-3: Luxvisions Innotech HP True Vision FHD Camera driver: uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.2:4
    chip-ID: 30c9:00ff class-ID: fe01 serial: <filter>
  Display: x11 server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9 driver:
    X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa dri: radeonsi gpu: amdgpu display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xdbb2 serial: <filter>
    built: 2024 res: mode: 1920x1200 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
    chroma: red: x: 0.569 y: 0.341 green: x: 0.349 y: 0.569 blue: x: 0.161
    y: 0.106 white: x: 0.314 y: 0.329 size: 344x215mm (13.54x8.46")
    diag: 406mm (16") ratio: 16:10 modes: 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2 2: parse_edid: unknown tag
    112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
    raphael_mendocino ACO DRM 3.64 6.18.18-1-MANJARO) device-ID: 1002:164e
    memory: 500 MiB unified: no
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22eb class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 06:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Audio Coprocessor
    vendor: Hewlett-Packard driver: snd_rpl_pci_acp6x v: kernel
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
    snd_sof_amd_vangogh, snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 06:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-4: Advanced Micro Devices [AMD] Ryzen HD Audio
    speed: 16 GT/s lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8852BE-VT PCIe 802.11ax Wireless Network
    vendor: Hewlett-Packard driver: rtw89_8852bte v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:b520
    class-ID: 0280
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1.1:3 chip-ID: 0bda:b86a
  Local Storage: total: 953.87 GiB used: 38.67 GiB (4.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HP02AS00 temp: 31.9 C
    scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 38.67 GiB (4.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 6b8a67a2-32d1-4930-986f-6749c219b578
    used: 640 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4C45-B9BF
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-1:2 info: Trust Isla Keyboard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 145f:0176 class-ID: 0300
  Device-2: 3-2:3 info: Instant USB Optical Mouse type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 30fa:0302 class-ID: 0301
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 5-1:2 info: Genesys Logic Hub ports: 2 rev: 2.0
  Device-1: 5-1.1:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b86a class-ID: e001 serial: <filter>
  Device-2: 5-1.2:4 info: Luxvisions Innotech HP True Vision FHD Camera
    type: video driver: uvcvideo interfaces: 3 rev: 2.0
  System Temperatures: cpu: 39.5 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Packages: pm: pacman pkgs: 1469 libs: 384 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.mirror.garr.it/manjaro/testing/$repo/$arch
    2: https://ct.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
    3: https://ba.mirror.garr.it/mirrors/manjaro/testing/$repo/$arch
    4: https://mirrors2.manjaro.org/testing/$repo/$arch
    5: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/testing/$repo/$arch
    6: https://mirrors.cicku.me/manjaro/testing/$repo/$arch
    7: https://mirrors.manjaro.org/repo/testing/$repo/$arch
    8: https://fosszone.csd.auth.gr/manjaro/testing/$repo/$arch
    9: https://ipng.mm.fcix.net/manjaro/testing/$repo/$arch
    10: https://cofractal-ewr.mm.fcix.net/manjaro/testing/$repo/$arch
    11: https://mirror.init7.net/manjaro/testing/$repo/$arch
    12: https://mirror.telepoint.bg/manjaro/testing/$repo/$arch
    13: http://ftp.uni-kl.de/pub/linux/manjaro/testing/$repo/$arch
    14: https://mirror.yandex.ru/mirrors/manjaro/testing/$repo/$arch
    15: https://mirror.alwyzon.net/manjaro/testing/$repo/$arch
    16: https://manjaro.ynh.ovh/testing/$repo/$arch
    17: https://mirror.bouwhuis.network/manjaro/testing/$repo/$arch
    18: https://distrohub.kyiv.ua/manjaro/testing/$repo/$arch
    19: https://mirror.raiolanetworks.com/manjaro/testing/$repo/$arch
    20: https://ftp.snt.utwente.nl/pub/linux/manjaro/testing/$repo/$arch
    21: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/testing/$repo/$arch
    22: https://mirror.math.princeton.edu/pub/manjaro/testing/$repo/$arch
    23: https://mirrors.dotsrc.org/manjaro/testing/$repo/$arch
    24: https://mirrors.eric.ovh/manjaro/testing/$repo/$arch
    25: https://ftp.halifax.rwth-aachen.de/manjaro/testing/$repo/$arch
    26: https://ftp.psnc.pl/linux/manjaro/testing/$repo/$arch
    27: https://repo.ialab.dsu.edu/manjaro/testing/$repo/$arch
    28: https://ftp.linux.org.tr/manjaro/testing/$repo/$arch
    29: https://mirror1.sox.rs/manjaro/testing/$repo/$arch
    30: https://mirror.easyname.at/manjaro/testing/$repo/$arch
    31: https://muug.ca/mirror/manjaro/testing/$repo/$arch
    32: https://mirror.netcologne.de/manjaro/testing/$repo/$arch
    33: https://manjaro.mirrors.lavatech.top/testing/$repo/$arch
    34: https://volico.mm.fcix.net/manjaro/testing/$repo/$arch
    35: https://ask4.mm.fcix.net/manjaro/testing/$repo/$arch
    36: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/testing/$repo/$arch
    37: https://kartolo.sby.datautama.net.id/manjaro/testing/$repo/$arch
    38: https://mirrors.ft.uam.es/manjaro/testing/$repo/$arch
    39: https://mirror.dkm.cz/manjaro/testing/$repo/$arch
    40: https://mirror.dimensiondata.com/mirrors/manjaro.org/testing/$repo/$arch
    41: https://manjaro.mirror.wearetriple.com/testing/$repo/$arch
    42: https://mirror.vinehost.net/manjaro/testing/$repo/$arch
    43: https://mirror.23m.com/manjaro/testing/$repo/$arch
    44: https://nocix.mm.fcix.net/manjaro/testing/$repo/$arch
    45: https://opencolo.mm.fcix.net/manjaro/testing/$repo/$arch
    46: https://ftp.tu-chemnitz.de/pub/linux/manjaro/testing/$repo/$arch
    47: https://irltoolkit.mm.fcix.net/manjaro/testing/$repo/$arch
    48: https://manjaro.mirrors.uk2.net/testing/$repo/$arch
    49: https://mirror.fcix.net/manjaro/testing/$repo/$arch
    50: https://ziply.mm.fcix.net/manjaro/testing/$repo/$arch
    51: https://mirrors.atlas.net.co/manjaro/testing/$repo/$arch
    52: https://mirror.futureweb.be/manjaro/testing/$repo/$arch
    53: https://coresite.mm.fcix.net/manjaro/testing/$repo/$arch
    54: https://mirror.xenyth.net/manjaro/testing/$repo/$arch
    55: https://mirror.freedif.org/Manjaro/testing/$repo/$arch
    56: https://codingflyboy.mm.fcix.net/manjaro/testing/$repo/$arch
    57: https://nnenix.mm.fcix.net/manjaro/testing/$repo/$arch
    58: https://linorg.usp.br/manjaro/testing/$repo/$arch
    59: https://manjaro.grena.ge/testing/$repo/$arch
    60: https://southfront.mm.fcix.net/manjaro/testing/$repo/$arch
    61: https://ftp.gwdg.de/pub/linux/manjaro/testing/$repo/$arch
    62: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/testing/$repo/$arch
    63: https://mirror.kamtv.ru/manjaro/testing/$repo/$arch
    64: https://ohioix.mm.fcix.net/manjaro/testing/$repo/$arch
    65: https://mirrors.gigenet.com/manjaro/testing/$repo/$arch
    66: https://manjaro.mirror.liquidtelecom.com/testing/$repo/$arch
    67: https://ftp.caliu.cat/pub/distribucions/manjaro/testing/$repo/$arch
    68: https://forksystems.mm.fcix.net/manjaro/testing/$repo/$arch
    69: https://manjaro.c3sl.ufpr.br/testing/$repo/$arch
    70: https://ftp.belnet.be/mirrors/manjaro/repos/testing/$repo/$arch
    71: https://mirror.xeonbd.com/manjaro/testing/$repo/$arch
    72: https://mirrors.xtom.jp/manjaro/testing/$repo/$arch
    73: https://ftp.free.org/mirrors/repo.manjaro.org/repos/testing/$repo/$arch
    74: https://mirror.dc.uz/manjaro/testing/$repo/$arch
    75: https://mirror.csclub.uwaterloo.ca/manjaro/testing/$repo/$arch
    76: https://gsl-syd.mm.fcix.net/manjaro/testing/$repo/$arch
    77: https://mirror.nyist.edu.cn/manjaro/testing/$repo/$arch
    78: https://mirrors.tuna.tsinghua.edu.cn/manjaro/testing/$repo/$arch
    79: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/testing/$repo/$arch
    80: https://mirror.aarnet.edu.au/pub/manjaro/testing/$repo/$arch
    81: https://mirrors.ocf.berkeley.edu/manjaro/testing/$repo/$arch
    82: https://mirrors.ustc.edu.cn/manjaro/testing/$repo/$arch
    83: https://mirror.archlinux.tw/Manjaro/testing/$repo/$arch
    84: https://mirror.it4i.cz/manjaro/testing/$repo/$arch
    85: https://mirrors.sonic.net/manjaro/testing/$repo/$arch
    86: https://mirror.2degrees.nz/manjaro/testing/$repo/$arch
    87: https://ftpmirror1.infania.net/mirror/manjaro/testing/$repo/$arch
    88: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/testing/$repo/$arch
    89: https://mirror.phoepsilonix.love/manjaro/testing/$repo/$arch
    90: https://ftp.lysator.liu.se/pub/manjaro/testing/$repo/$arch
    91: https://manjaro.mirror-services.net/pub/testing/$repo/$arch
    92: https://mirror.alpix.eu/manjaro/testing/$repo/$arch
    93: https://mirrors.sjtug.sjtu.edu.cn/manjaro/testing/$repo/$arch
    94: https://mirrors.up.pt/pub/manjaro/testing/$repo/$arch
Processes:
  CPU top: 5 of 707
  1: cpu: 7.9% command: gnome-terminal-server pid: 590635
    mem: 94.9 MiB (0.3%)
  2: cpu: 5.0% command: chromium pid: 585746 mem: 249.8 MiB (0.8%)
  3: cpu: 3.8% command: Skyrim started-by: gimp-3.0 pid: 530375
    mem: 474.5 MiB (1.5%)
  4: cpu: 1.8% command: chromium pid: 573148 mem: 271.6 MiB (0.8%)
  5: cpu: 1.6% command: chromium pid: 9750 mem: 209.2 MiB (0.6%)
  Memory top: 5 of 707
  1: mem: 520.2 MiB (1.6%) command: Telegram pid: 416595 cpu: 0.3%
  2: mem: 474.5 MiB (1.5%) command: Skyrim started-by: gimp-3.0 pid: 530375
    cpu: 3.8%
  3: mem: 373.3 MiB (1.1%) command: chromium pid: 9711 cpu: 0.3%
  4: mem: 357.4 MiB (1.1%) command: chromium pid: 10089 cpu: 1.0%
  5: mem: 327.0 MiB (1.0%) command: cinnamon pid: 1642 cpu: 1.0%
  Processes: 707 Power: uptime: 9h 20m states: freeze,mem,disk suspend:
    avail: s2idle wakeups: 1 fails: 1 hibernate: platform avail: shutdown,
    reboot, suspend, test_resume image: 12.05 GiB services: csd-power,upowerd
    Init: systemd v: 259 default: graphical tool: systemctl
  Compilers: clang: 22.1.1 gcc: 15.2.1 Shell: Bash v: 5.3.9
    running-in: gnome-terminal inxi: 3.3.40
I attempted to resolve this “on my own” (which means I consulted Gemini), and here are the steps I took:
  • I checked that “Wake on LAN” was disabled in the BIOS, as well as the “USB charging” function when the PC is off.
  • I ran the following commands to display kernel messages and check the power saving status:
sudo dmesg | grep -i aspm [sudo] password di stefano:
[    0.315886] ACPI FADT declares the system does not support PCIe ASPM, so disable it
[    0.405605] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.405793] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    3.656103] r8169 0000:04:00.0: cannot disable ASPM; OS does not have ASPM control
and
sudo lspci -vvv | grep -i aspm
LnkCap:	Port #0, Speed 16GT/s, Width x8, ASPM not supported
			ClockPM- Surprise- LLActRep+ BwNot+ ASPMOptComp+
		LnkCtl:	ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk+
		L1SubCap: PCI-PM_L1.2- PCI-PM_L1.1+ ASPM_L1.2- ASPM_L1.1- L1_PM_Substates+
		L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
		LnkCap:	Port #0, Speed 32GT/s, Width x4, ASPM L1, Exit Latency L1 <64us
		LnkCtl:	ASPM L1 Enabled; RCB 64 bytes, LnkDisable- CommClk+
		L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
		L1SubCtl1: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+
		LnkCap:	Port #247, Speed 32GT/s, Width x1, ASPM L1, Exit Latency L1 <64us
		LnkCtl:	ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk-
		LnkCap:	Port #6, Speed 32GT/s, Width x1, ASPM L1, Exit Latency L1 <64us
		LnkCap:	Port #3, Speed 32GT/s, Width x1, ASPM L1, Exit Latency L1 <64us
		LnkCap:	Port #0, Speed 16GT/s, Width x16, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
		LnkCap:	Port #0, Speed 32GT/s, Width x16, ASPM L1, Exit Latency L1 unlimited
			ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCap:	Port #0, Speed 16GT/s, Width x4, ASPM L1, Exit Latency L1 <64us
			ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s unlimited, L1 <64us
		LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <4us, L1 <64us
		LnkCtl:	ASPM L0s L1 Enabled; RCB 64 bytes, LnkDisable- CommClk+
  • I modified GRUB with this line (and then ran update-grub):
GRUB_CMDLINE_LINUX_DEFAULT='quiet apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=force acpi_rev_override=5 mem_sleep_default=deep'
  • After rebooting, I ran:
cat /sys/power/mem_sleep
[s2idle]
  • I found no reference in the BIOS to any “fastboot” management setting.
    It seems the BIOS is preventing the computer from shutting down completely… I don’t know what to do. :grimacing:
  • After these interventions, I ran the following command again:
[ 0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64 root=UUID=6b8a67a2-32d1-4930-986f-6749c219b578 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=force acpi_rev_override=5 mem_sleep_default=deep
[ 0.039201] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64 root=UUID=6b8a67a2-32d1-4930-986f-6749c219b578 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3 pcie_aspm=force acpi_rev_override=5 mem_sleep_default=deep [ 0.039284] PCIe ASPM is forcibly enabled
[ 0.308663] ACPI FADT declares the system does not support PCIe ASPM, so disable it
[ 0.397335] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.397522] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
Mod edit: Fixed code formatting and Topic title. :wink:
Is this a new battery?
My older HP 17-bs049dx laptop does this. A light stays on. It’s not the hard drive, I assume it’s just to indicate the laptop is still on and the battery will drain. I just look to see that it’s really off, if not I hold the power button down. It also only happens about 1 in 30 times. You might want to check the HP site for alerts. There are many for mine. Just don’t expect much help for Linux.
Finding somebody with the same type of machine who dual boots it with Windows, and perhaps they could test it by turning it off using Windows, will that make any difference? And, will they have the same problem if they turn the machine off using Linux?
Perhaps there is some windowsy driver thing that is needed to break the connection to the battery?
I remember running an old laptop ages ago using Mint 9 that couldn’t use the battery because as soon as I plugged it in, the mouse pointer started living a life completely on its own. Removing the battery and it was okay. Completely weird. That was an Acer, so unrelated, but that something strange can be going on with batteries I am not surprised if that would turn out to be a fact.
I don’t see any reference to Windows partitions in the inxi output (but, of course, I could have missed something).
If this were the case, issuing (in as Windows elevated command prompt) powercfh /h off should fix these issues.
However:
… is the machine really being shut-down fully, or being put in to sleep mode …? Is a USB device connected? :thinking: (Sorry if I’m stating the obvious).
You might have missed my point. 8) I did not mean on OP’s machine, I was talking about finding somebody else that had such a thing and try there. A bit of a long shot, yes, but knowing big companies they are often tied to M$'s leash.
That happened to my HP ZBook G6 about half a year ago.
It worked on battery for several hours, but once i shut it down, the next morning it was empty.
Result: Battery (or at least the management of it) was broken. after exchanging it, the problem was gone.
To elaborate on my previous post, it looks like a battery problem to me too. This is typical for old batteries. On the other hand, the inxi shows 2 cycles…maybe a new, but low quality battery that does not communicate properly with the system?
Here are a few random thoughts, but this isn’t my subject so there’s no deep understanding behind them:
Any errors if you do:
shutdown -h now
Any errors?
journalctl -b -1 | grep -i "acpi\|power\|suspend\|hibernate"
It really looks as if it’s suspending, not shutting down - something askew maybe.
s2idle deep is good…
Check wakeup items:
cat /proc/acpi/wakeup
Disable USB charging/always on
Disable Wake on LAN
Enable ‘Deep Sleep’ if it’s available, set to Enabled or S5 (power off).
That’s indeed suspicious. Mine had already four cycles on delivery. I assume testing.
Currently after a few months the counter is set to 103 cycles.
So i would expect a lot more in a running system.
Thanks for replies.
Yes, I bought this laptop 2 weeks ago and I immediately installed manjaro.
unfortunately I know no-one with this pc and no-one that use linux…
yes, There’s no swap partition, but I simply follow the auto installation procedure… It seemed strange to me too, but I trusted the installer… I thought that with a laptop with 32 GB, the swap partition might be seen as unnecessary, so I left it at that.
When I turn off the pc, I click on the red button “arresta” (stop in italian), so I assume that I turn off the pc :smiley:
your last question is obvious but correct, because I left a keyboard and a mouse connected, but I never had this behaviour with other laptops… I tried to disconnect this devides and the battery (after few hours) remain charged, I connected again and the battery was drained.
For me have no sense, because there are no LEDs that stay lit or anything that suggests the mouse or keyboard is drawing power…
no error
With journalclt I could find this 4 error:
mar 24 17:17:18 Omen-linux kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Index (0x000000032) is beyond end of object (length 0x32) (20250807/exoparg2-393)
mar 24 17:17:18 Omen-linux kernel: ACPI Error: Aborting method \_SB.WMID.WQBZ due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
mar 24 17:17:18 Omen-linux kernel: ACPI Error: Aborting method \_SB.WMID.WQBE due to previous error (AE_AML_BUFFER_LIMIT) (20250807/psparse-529)
mar 24 17:17:26 Omen-linux kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
There may well be an option in the BIOS/(U)EFI setup where you can set whether the USB ports stay powered when the machine is off. Toshiba called this “Sleep and Charge” or along those lines. :wink:
Your system tells you that you only have s2idle available for your device, yet you have tried to force, via your boot parameters, the use of the non-existent deep (a.k.a. Suspend-to-RAM) sleep:
The unavailability of deep sleep could be why your inxi output shows that you have no currently active suspend method (the field is blank), however s2idle is shown as being available (but not used):
I’m not sure if the above is the reason why your battery is going flat. However, it might be best to just revert all of the AI-advised changes that you made & reboot into an unmodified system configuration (i.e. the one created by the Manjaro installer).
Then, when you experience any issues, the inxi output etc will reflect the system as it was initially set up using the Manjaro installer, rather than some random configuration created by an AI.
These 2 pages are worth a read when it comes to power-saving settings:
in office we have a elitebook 16 purchased last year, and noticed a strange behaviour, in the morning opening the lid the laptop and the OS (Win11) was starting automatically. This behavior, a friend told me, was there also in some Lenovo.
That was using the battery over night
I don’t know if it can be your problem but we solved disabling the autostart os in the bios
You may check if there is a option like that in your bios and try if helps
That’s the default behavior of Windows 11 (my ZBook had the same on the first few days where Windows was installed)
To fully shut down a Windows 11 device, you need to press and hold the Shift key while klicking the shutdown option (or for nerds: powershell and enter shutdown /s /f /t 0 :grin:)
To get this permanently it is required to change it in the energy options.
I am pretty sure that isn’t the case with Linux installed.
It is actually a bios setting that can be turned off.
Hello,
It seems this HP Omen 16 might be too new for Linux. I am encountering numerous errors that I am trying to resolve. Regarding power management, there is nothing in the BIOS that I haven’t already disabled, and there is no mention of Fast Boot.
I will try reading the two wiki pages Scotty65 provided to see if I can solve the issue. I also switched the kernel from 6.18 LTS to 6.19 and changed the branch from stable to testing, hoping that newer software would help, but unfortunately, it didn’t work. :frowning:
I don’t think it is too new. The device is on the market for more than a year now.
If you check some other sources, a few have similar problems:
https://www.reddit.com/r/HPOmen/comments/1b3rda5/question_regarding_battery_drain_even_when_shut/
https://www.reddit.com/r/HPOmen/comments/1qxh78x/laptop_drains_battery_while_switched_off/
Maybe these help you.
Laptop/HP - ArchWiki
Omen 16 ap0032ns
After shutting down from a Linux distribution, HP Omen 16 does not fully shutdown all the devices causing battery draining or energy draining when plugged. This may heat up the PC over 85ºC overnight possibly breaking the components. Unfortunately the latest BIOS (F.06) does not resolve the issue.
To be able to use Arch Linux (and any Linux distribution) there are two ways:
  1. After shutting down, press the shutdown ACPI button during 5 seconds. This will trigger a hardware shutdown, avoiding any power consumption.
  2. When using Windows dual boot, boot Windows and shut it down from there
Jesus f. Christ! I know HP is not what they once were but that is…well let’s just say noone here will buy HP anymore, including the OP :slight_smile:
At least there is a workaround.
