Hi,
Since last two major updates i cannot scan documents with my printer HP MFP M130fw any more, printing works.
I tried setting up printer multiple times through gnome and HP Device manager with no luck.
The device used to be set up as “mfp_129-m134” since this driver is closest to my model and was completely funtional.
When I try to scan with HP Device manager xsane starts but it imedietly says I/O error.
scanimage -L
device `escl:http://10.0.0.25:8080' is a HP LaserJet MFP M130fw (21447D) platen,adf scanner
device `hpaio:/net/HP_LaserJet_MFP_M129-M134?ip=10.0.0.25' is a Hewlett-Packard HP_LaserJet_MFP_M129-M134 all-in-one
scanimage -T
Output format is not set, using pnm as a default.
scanimage: rounded value of br-x from 215.9 to 215.9
scanimage: rounded value of br-y from 297.011 to 297.011
scanimage: sane_start: Invalid argument
The HP Device manager sets up two devices, which I find strange, also when trying to use M129 for scanning I get a prompt to install proprietary driver.
None of that was necessary before and I prefer not to use any proprietary driver especially from HP.
UPDATE:
There seems to be a solution HERE with HPLIP plugin which is HPs driver and also when trying to download it with hp-plugin I get an error:
error: /home/danizmax/.hplip/hplip-3.20.11-plugin.run file does not match its checksum. File may have been corrupted or altered
As said before I would prefer to solve this without HPLIP if possible and would be my last resort.
Any help and ideas would be appreciated.
Thanks!
