HP Laptop /inaktive / schlafmodus
Hallo Manjarouser ,
Es geht um ein HP Pavilion -15 cw0527ng
Das Problem , wenn Laptop in inaktivemodus hängt / glaube es heist Schlafmodus , nach Touchpad bewegung solte eigentlich die KDE oberfläche erscheinen , leider kommt die Maus , ansonsten ist Display dunkel , was fehlt dem Laptop .
   ~  lsb_release -sirc         ✔
ManjaroLinux 24.0.3 Wynsdey
    ~  inxi -v7azy         ✔
  Kernel: 6.9.5-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=8c86be82-9e1a-4961-9f19-5657e4c6ac38 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Laptop System: HP product: HP Pavilion Laptop 15-cw0xxx v: N/A
  Mobo: HP model: 84E5 v: 50.04 serial: <superuser required>
    part-nu: 6LD37EA#ABD uuid: <superuser required> UEFI: AMI v: F.42
    date: 11/12/2019
  ID-1: BAT0 charge: 32.9 Wh (92.7%) condition: 35.5/35.5 Wh (100.0%)
    volts: 12.3 min: 11.6 model: HP Primary type: Li-ion serial: N/A
    status: discharging cycles: 319
  System RAM: total: 8 GiB available: 7.2 GiB used: 1.59 GiB (22.0%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom-Slot 1 (left) type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 4 GiB speed: spec: 2400 MT/s actual: 1866 MT/s volts:
    note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: HP26D4S9S1ME-4 serial: <filter>
  Device-2: Bottom-Slot 2 (right) type: DDR4 detail: synchronous unbuffered
  Info: model: AMD A9-9425 RADEON R5 5 COMPUTE CORES 2C+3G bits: 64 type: MCP
    arch: Excavator level: v3 note: check built: 2015 process: GF 28nm
    family: 0x15 (21) model-id: 0x70 (112) stepping: 0 microcode: 0x6006705
  Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 192 KiB
    desc: d-2x32 KiB; i-2x64 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 2261 high: 2322 min/max: 1400/3100 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2322
    bogomips: 12381
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avic avx avx2
    bmi1 bmi2 bpext clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy
    cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fma4
    fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs lahf_lm lbrv lm lwp mca
    mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nodeid_msr
    nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni popcnt pse
    pse36 ptsc rdtscp rep_good sep skinit smep ssbd sse sse2 sse4_1 sse4_2
    sse4a ssse3 svm_lock syscall tbm tce tsc tsc_scale v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wdt xop xsave xsaveopt
  Device-1: AMD Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
    driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
    process: TSMC 28nm built: 2014-19 ports: active: eDP-1 empty: HDMI-A-1
    bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
  Device-2: Chicony HP Wide Vision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:3
    chip-ID: 04f2:b627 class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: BOE Display 0x076e built: 2017 res: 1366x768
    dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: max: 1366x768 min: 640x480
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.5 vendor: amd mesa v: 24.1.1-manjaro1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon R5 Graphics (radeonsi stoney LLVM
    17.0.6 DRM 3.57 6.9.5-1-MANJARO) device-ID: 1002:98e4 memory: 500 MiB
    unified: no
  Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    bus-ID: 00:01.1 chip-ID: 1002:15b3 class-ID: 0403
  Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
    class-ID: 0403
  API: ALSA v: k6.9.5-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
    chip-ID: 10ec:c821 class-ID: 0280
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4:4 chip-ID: 0bda:b00a
  Local Storage: total: 238.47 GiB used: 8.45 GiB (3.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPNUW-256G-1006 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20110006 temp: 38.9 C scheme: GPT
  ID-1: / raw-size: 140.32 GiB size: 137.06 GiB (97.68%) used: 8.45 GiB (6.2%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 8c86be82-9e1a-4961-9f19-5657e4c6ac38
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
    uuid: 28E7-216E
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: 6A53-6C60
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 96.88 GiB fs: ntfs label: N/A
    uuid: F0306EDC306EA974
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 683 MiB fs: ntfs label: N/A
    uuid: A47EFAFB7EFAC558
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
    chip-ID: 0438:7900 class-ID: 0900
  Device-1: 1-1.3:3 info: Chicony HP Wide Vision HD Camera type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 04f2:b627 class-ID: 0e02
  Device-2: 1-1.4:4 info: Realtek Bluetooth 4.2 Adapter type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 53.1 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (rpm): N/A
  Processes: 185 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.86 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1177 libs: 345 tools: pamac pm: flatpak pkgs: 0
    Compilers: N/A Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole
    inxi: 3.3.35
    ~  mhwd -li         ✔  3s 
Warning: No installed PCI configs!
    ~  lsblk -fa         ✔
NAME        FSTYPE FSVER LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1
├─nvme0n1p1 vfat   FAT32       6A53-6C60
├─nvme0n1p2
├─nvme0n1p3 ntfs               F0306EDC306EA974
├─nvme0n1p4 ntfs               A47EFAFB7EFAC558
├─nvme0n1p5 vfat   FAT32       28E7-216E                             510,7M     0% /boot/efi
└─nvme0n1p6 ext4   1.0         8c86be82-9e1a-4961-9f19-5657e4c6ac38  121,6G     6% /
