HP Envy x360 2022 Ryzen 5 5625U 2-in-1 has a problem with bluetooth. bluetooth.service is running without issues. But the device can’t find any Bluetooth devices.
Kernel: 6.0.2-arch1-1 ? How about with 6.0.2-2-MANJARO ? Does it work with linux515 ?
Well, that is part of bluez-utils and KDE Plasma (is that your default DE as per your profile description?) uses bluedevil that relies on bluez-qt and they do not need bluez-utils, and work just fine without it on my end …
I didn’t try 6.0.2-2-manjaro. I tried to install the latest Manjaro KDE (21.3.7) with linux kernel version 5.15 LTS, but sadly it even didn’t boot into the installer. That’s why I installed Arch . When it comes to the part of bluez-utils, I just followed the Arch wiki to make my Bluetooth work.
I found this https://unix.stackexchange.com/questions/705772/bluetooth-not-working-debian which tells about the patchwork. But I don’t know how to apply patches to my kernel.
Then I even tried to compile mainline kernel 6.1.0-rc2-1. With the newer kernel Bluetooth: hci0: Opcode 0x c03 failed: -110 message “disappeared”. Here is the output of dmesg | grep -i blue:
But even if there’s no warning or errors. It is not working can’t find any devices nearby and still No default controller available.
When it comes to the bluedevil which KDE DE relies on, I have already installed it but not working. I can’t enable the Bluetooth from System Settings. There is Enable button but if I click it nothing happens.
