HP Envy Laptop 16t-h1000 - No output from internal laptop speaker
I’ve been using Manjaro Gnome on my laptop for a few months and haven’t been able to get my laptop speakers working. It’s never really been an issue until now- I need to use my speakers for a school project. The mute mic and speaker LEDs don’t work either- although the mute speaker key works just fine.
I’ve gone through forum posts already and checked the arch linux wiki- I’ve tried installing various sof packages, adjusting levels in alsamixer, and tried swapping to dedicated graphics figuring that the internal speakers may be wired to the discrete gpu. Nothing particularly seems to work :confused:
inxi:
  Kernel: 6.5.13-7-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=bee2d9b5-d6e4-4195-b2b2-ae854a02c0c9 rw quiet splash apparmor=1
    security=apparmor resume=UUID=b4ce1c99-d24b-4914-9e8d-fbb337631b97
    udev.log_priority=3
  Desktop: GNOME v: 45.3 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
  Type: Laptop System: HP product: HP ENVY Laptop 16-h1xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
  Mobo: HP model: 8BE5 v: 72.31 serial: <superuser required> UEFI: Insyde
    v: F.10 date: 07/05/2023
  ID-1: BAT1 charge: 78.1 Wh (93.4%) condition: 83.6/83.0 Wh (100.7%)
    volts: 13.2 min: 11.6 model: 333-2D-27-A FZ06083XL type: Li-ion
    serial: <filter> status: charging
  System RAM: total: 16 GiB note: est. available: 15.32 GiB
    used: 9.96 GiB (65.0%)
  Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
    arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
    process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
    microcode: 0x411C
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 520 high: 942 min/max: 400/5200:5400:4100 scaling:
    driver: intel_pstate governor: powersave cores: 1: 942 2: 400 3: 474 4: 400
    5: 615 6: 400 7: 732 8: 400 9: 780 10: 400 11: 613 12: 400 13: 400 14: 400
    15: 400 16: 400 17: 400 18: 400 19: 607 20: 849 bogomips: 119840
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pconfig pdcm
    rdtscp rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect
    ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tme tpr_shadow
    tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
    RSB filling, PBRSB-eIBRS: SW sequence
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:a7a0 class-ID: 0300
  Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
    vendor: Hewlett-Packard driver: nvidia v: 545.29.06
    alternate: nouveau,nvidia_drm non-free: 545.xx+
    status: current (as of 2023-11) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:28a0 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :1
    screens: 1
  Screen-1: 0 s-res: 2560x1600 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: AU Optronics 0xfda4 built: 2022 res: 2560x1600
    hz: 120 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 2560x1600
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia x11: drv: iris inactive: gbm,wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 14.96 GiB unified: yes
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51ca class-ID: 0401
  Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 10de:22be
    class-ID: 0403
  API: ALSA v: k6.5.13-7-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.0 status: off tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:2 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 125.09 GiB (13.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
    SN810 SDCPNRY-1T00-1006 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: HPS2 temp: 37.9 C scheme: GPT
  ID-1: / raw-size: 936.72 GiB size: 920.94 GiB (98.32%)
    used: 125.09 GiB (13.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: bee2d9b5-d6e4-4195-b2b2-ae854a02c0c9
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4D25-4A16
  ID-1: swap-1 type: partition size: 16.85 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: b4ce1c99-d24b-4914-9e8d-fbb337631b97
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 3 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-10:2 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 39.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Processes: 435 Uptime: 7d 3h 18m wakeups: 19 Init: systemd v: 255
  Packages: pm: pacman pkgs: 1364 libs: 360 tools: gnome-software,pamac,yay
  pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.31
aplay -L:
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=NVidia,DEV=0
    HDA NVidia, HDMI 0
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
    HDA NVidia, HDMI 1
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
    HDA NVidia, HDMI 2
    HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
    HDA NVidia, HDMI 3
    HDMI Audio Output
usbstream:CARD=NVidia
    HDA NVidia
    USB Stream Output
sysdefault:CARD=sofhdadsp
    sof-hda-dsp,
    Default Audio Device
usbstream:CARD=sofhdadsp
    sof-hda-dsp
    USB Stream Output
ALSA info:
http://alsa-project.org/db/?f=8c4d7011eeb61d7e577ed0c27a726bad29a221c1
A patch for the Cirrus CS35L41 amplifiers for the built-in speakers was created yesterday but has not yet been signed off for inclusion in a kernel release:
[v2,4/4] ALSA: hda/realtek: Add quirks for various HP ENVY models
sbinding@opensource.cirrus.com
Jan. 26, 2024, 4:40 p.m. UTC
These models use 2 or 4 CS35L41 amps with HDA using I2C or SPI.
Some models have _DSD support inside cs35l41_hda_property.c.
+ SND_PCI_QUIRK(0x103c, 0x8be5, "HP Envy 16", ALC287_FIXUP_CS35L41_I2C_2),
Kernel v6.5 has been marked End Of Life and will not be updated
I suggest install Long Term Support kernel v6.6 that should be updated to include ALSA patch in the future
sudo mhwd-kernel -i linux66
