HP Blooglet (N5030 Gemini Lake) - Only shows Dummy output
Hi all,
I installed Manjaro XFCE with proprietary drivers on a HP Chromebook 14a (Blooglet) using Mr.Chromebox’s UEFI firmware, but sound isn’t working.
Internal speakers and aux don’t work. I can’t test HDMI sound since I don’t have a USB-C > HDMI dongle. Bluetooth and USB headsets work.
[denisuu@blooglet ~]$ inxi -Fazy
  Kernel: 5.16.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64
    root=UUID=21de0141-71de-4878-8fed-168d5c8fda16 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: Blooglet v: rev4
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: HP model: Blooglet v: rev4 serial: <superuser required>
    UEFI: coreboot v: MrChromebox-4.15 date: 01/18/2022
  ID-1: BAT0 charge: 10.8 Wh (23.5%) condition: 46.0/47.4 Wh (97.1%)
    volts: 7.4 min: 7.7 model: 333-54- GH02047 type: Li-ion serial: <filter>
    status: Discharging cycles: 22
  Info: model: Intel Pentium Silver N5030 bits: 64 type: MCP
    arch: Goldmont Plus family: 6 model-id: 0x7A (122) stepping: 8
    microcode: 0x1A
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 2217 high: 2902 min/max: 800/3100 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1927 2: 2575 3: 1466
    4: 2902 bogomips: 8756
  Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Device-1: Intel GeminiLake [UHD Graphics 605] driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:3184 class-ID: 0380
  Device-2: Luxvisions Innotech Limited HP Wide Vision HD Camera type: USB
    driver: uvcvideo bus-ID: 1-7:3 chip-ID: 30c9:0016 class-ID: 0e02
    serial: <filter>
  Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
    loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1728x972 s-dpi: 96 s-size: 457x257mm (18.0x10.1")
    s-diag: 524mm (20.6")
  Monitor-1: eDP-1 res: 1728x972 hz: 60 dpi: 142 size: 309x174mm (12.2x6.9")
    diag: 355mm (14")
  Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_apl
    bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
  Sound Server-1: ALSA v: k5.16.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.43 running: yes
  Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
    port: 1000 bus-ID: 01:00.0 chip-ID: 10ec:c822 class-ID: 0280
  Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 1-3:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
  Local Storage: total: 58.24 GiB used: 18.59 GiB (31.9%)
  ID-1: /dev/mmcblk0 maj-min: 179:0 model: CUTB42 size: 58.24 GiB
    block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
    rev: 0x8 scheme: GPT
  ID-1: / raw-size: 57.95 GiB size: 56.74 GiB (97.91%) used: 18.59 GiB (32.8%)
    fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2
    used: 288 KiB (0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 54.0 C mobo: N/A
  Processes: 215 Uptime: 21m wakeups: 7082 Memory: 3.7 GiB
  used: 1.84 GiB (49.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: 1203 pacman: 1195 lib: 324 flatpak: 0
  snap: 8 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
[denisuu@blooglet ~]$ pacmd dump
### Configuration dump generated at Wed Feb  2 17:56:44 2022
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-null-sink sink_name=auto_null sink_properties='device.description="Dummy Output"'
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-alsa-card device_id="0" name="pci-0000_00_0e.0" card_name="alsa_card.pci-0000_00_0e.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-x11-publish display=:0.0 xauthority=/home/denisuu/.Xauthority
load-module module-x11-xsmp display=:0.0 xauthority=/home/denisuu/.Xauthority session_manager=local/blooglet:@/tmp/.ICE-unix/748,unix/blooglet:/tmp/.ICE-unix/748
load-module module-cli-protocol-unix
set-sink-volume auto_null 0x10000
set-sink-mute auto_null no
suspend-sink auto_null yes
set-source-volume auto_null.monitor 0x10000
set-source-mute auto_null.monitor no
suspend-source auto_null.monitor yes
set-card-profile alsa_card.pci-0000_00_0e.0 off
set-default-sink auto_null
set-default-source auto_null.monitor
### EOF
[denisuu@blooglet ~]$ pacmd list-sinks
1 sink(s) available.
  * index: 2
	driver: <module-null-sink.c>
	flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1000
	volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max request: 375 KiB
	max rewind: 375 KiB
	monitor source: 3
	sample spec: s16le 2ch 48000Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
	module: 28
	properties:
		device.description = "Dummy Output"
		device.class = "abstract"
		device.icon_name = "audio-card"
[denisuu@blooglet ~]$ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=PCH,DEV=0
    HDA Intel PCH, HDMI 0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDA Intel PCH, HDMI 1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDA Intel PCH, HDMI 2
    HDMI Audio Output
hdmi:CARD=PCH,DEV=3
    HDA Intel PCH, HDMI 3
    HDMI Audio Output
hdmi:CARD=PCH,DEV=4
    HDA Intel PCH, HDMI 4
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
Any help would be appreciated, thanks!
Can you post pacmd list-sinks ?
What is the ouput of alsamixer ?
alsamixer just shows a gui, should I add any options? I added the output to the first post too.
  * index: 2
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1000
	        balance 0.00
	volume steps: 65537
	muted: no
	max rewind: 375 KiB
	monitor source: 3
	             Stereo
	used by: 0
	linked by: 0
	module: 28
	properties:
null
lavrate
samplerate
speexrate
jack
oss
    Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
hdmi:CARD=PCH,DEV=0
    HDMI Audio Output
hdmi:CARD=PCH,DEV=1
    HDMI Audio Output
hdmi:CARD=PCH,DEV=2
    HDMI Audio Output
hdmi:CARD=PCH,DEV=3
    HDMI Audio Output
hdmi:CARD=PCH,DEV=4
    HDMI Audio Output
usbstream:CARD=PCH
    HDA Intel PCH
    USB Stream Output
Can you show the output of alsamixer as root on console ?
This shows the volume of the channels.
This is as my user:
This is as root (Pressing F6 has the same options as above)
Then the sound chip is not supported “out of box”.
Does anybody know, if a firmware or a different sound driver is needed for sound output ?
Not sure if this is helpful, this is the output of sudo alsa-info.sh --upload
!!ALSA Information Script v 0.5.1
!!Script ran on: Thu Feb  3 21:28:37 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      HP
Product Name:      Blooglet
Product Version:   rev4
Firmware Version:  MrChromebox-4.15
System SKU:        sku68
Board Vendor:      HP
Board Name:        Blooglet
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 	 15
/sys/bus/acpi/devices/BOOT0000:00/status 	 11
/sys/bus/acpi/devices/DLGS7219:00/status 	 15
/sys/bus/acpi/devices/ELAN0000:00/status 	 15
/sys/bus/acpi/devices/ELAN0001:00/status 	 15
/sys/bus/acpi/devices/GDIX0000:00/status 	 15
/sys/bus/acpi/devices/GOOG0002:00/status 	 15
/sys/bus/acpi/devices/GOOG0003:00/status 	 11
/sys/bus/acpi/devices/GOOG0004:00/status 	 11
/sys/bus/acpi/devices/GOOG0006:00/status 	 11
/sys/bus/acpi/devices/GOOG000A:00/status 	 15
/sys/bus/acpi/devices/GOOG0014:00/status 	 11
/sys/bus/acpi/devices/GTCH7503:00/status 	 15
/sys/bus/acpi/devices/INT33D3:00/status 	 15
/sys/bus/acpi/devices/INT33D6:00/status 	 15
/sys/bus/acpi/devices/INT3400:00/status 	 15
/sys/bus/acpi/devices/INT3403:00/status 	 15
/sys/bus/acpi/devices/INT3403:01/status 	 15
/sys/bus/acpi/devices/INT3403:02/status 	 15
/sys/bus/acpi/devices/INT3403:03/status 	 15
/sys/bus/acpi/devices/INT3453:00/status 	 15
/sys/bus/acpi/devices/INT3453:01/status 	 15
/sys/bus/acpi/devices/INT3453:02/status 	 15
/sys/bus/acpi/devices/INT3453:03/status 	 15
/sys/bus/acpi/devices/LNXPOWER:00/status 	 1
/sys/bus/acpi/devices/LNXPOWER:01/status 	 1
/sys/bus/acpi/devices/LNXPOWER:02/status 	 1
/sys/bus/acpi/devices/MX98357A:00/status 	 15
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:01/status 	 15
/sys/bus/acpi/devices/PNP0C02:02/status 	 15
/sys/bus/acpi/devices/PNP0C0A:00/status 	 31
/sys/bus/acpi/devices/PRP0001:00/status 	 15
/sys/bus/acpi/devices/device:17/status 	 15
/sys/bus/acpi/devices/device:2f/status 	 15
!!Kernel Information
Kernel release:    5.16.2-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.16.2-1-MANJARO
Library version:    1.2.6.1
Utilities version:  1.2.6
!!Loaded ALSA modules
snd_hda_intel (card 0)
!!Sound Servers on this system
PipeWire:
      Installed - Yes (/usr/bin/pipewire)
      Running - Yes
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0x91418000 irq 122
!!PCI Soundcards installed in the system
00:0e.0 Multimedia audio controller [0401]: Intel Corporation Celeron/Pentium Silver Processor High Definition Audio [8086:3198] (rev 06)
	DeviceName: Multimedia audio controller
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N,N
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 1
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
!!Sysfs card info
!!Card: /sys/class/sound/card0
Driver: /sys/bus/pci/drivers/snd_hda_intel
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Geminilake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280d
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
  Converter: stream=0, channel=0
  Digital: Enabled KAE
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0x1a]: 16 24 32
    formats [0x5]: PCM AC3
  Power states:  D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
  PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-Out vals:  [0x00 0x00]
  Pincap 0x0b000094: OUT Detect HBR HDMI DP
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=00, enabled=0
  Devices: 0
  Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw----  1 root audio 116,  8 Feb  3 22:15 /dev/snd/controlC0
crw-rw----  1 root audio 116,  7 Feb  3 22:15 /dev/snd/hwC0D2
crw-rw----  1 root audio 116,  6 Feb  3 22:15 /dev/snd/pcmC0D10p
crw-rw----  1 root audio 116,  2 Feb  3 22:15 /dev/snd/pcmC0D3p
crw-rw----  1 root audio 116,  3 Feb  3 22:15 /dev/snd/pcmC0D7p
crw-rw----  1 root audio 116,  4 Feb  3 22:15 /dev/snd/pcmC0D8p
crw-rw----  1 root audio 116,  5 Feb  3 22:15 /dev/snd/pcmC0D9p
crw-rw----  1 root audio 116,  1 Feb  3 22:14 /dev/snd/seq
crw-rw----  1 root audio 116, 33 Feb  3 22:15 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Feb  3 22:15 .
drwxr-xr-x 3 root root 240 Feb  3 22:15 ..
lrwxrwxrwx 1 root root  12 Feb  3 22:15 pci-0000:00:0e.0 -> ../controlC0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
!!Amixer output
!!-------Mixer controls for card PCH
Card sysdefault:0 'PCH'/'HDA Intel PCH at 0x91418000 irq 122'
  Mixer name	: 'Intel Geminilake HDMI'
  Components	: 'HDA:8086280d,80860101,00100000'
  Controls      : 35
  Simple ctrls  : 5
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.32 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.33 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.34 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.35 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
chromeos_tbmc
cmac
coreboot_table
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cros_ec
cros_ec_chardev
cros_ec_debugfs
cros_ec_dev
cros_ec_lpcs
cros_ec_sysfs
cros_ec_typec
cros_kbd_led_backlight
cros_peripheral_charger
cros_usbpd_charger
cros_usbpd_logger
cros_usbpd_notify
cryptd
crypto_simd
crypto_user
dw_dmac
dwc3_pci
ecdh_generic
elan_i2c
elants_i2c
ext4
fat
fuse
ghash_clmulni_intel
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_punit_ipc
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_platform
intel_telemetry_core
intel_telemetry_debugfs
intel_telemetry_pltdrv
intel_vbtn
ip_tables
jbd2
joydev
ledtrig_audio
libarc4
libps2
loop
lpc_ich
mac80211
mac_hid
mbcache
mc
mmc_block
mmc_core
mousedev
mtd
pcspkr
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
qrtr
rapl
rfcomm
rfkill
rng_core
roles
rtw88_8822c
rtw88_8822ce
rtw88_core
rtw88_pci
sdhci
sdhci_pci
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_da7219
snd_soc_hdac_hda
snd_soc_max98357a
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soc_button_array
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_nor
spi_pxa2xx_platform
squashfs
tpm
tpm_tis_core
tpm_tis_spi
ttm
typec
uinput
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
x86_pkg_temp_thermal
x_tables
xhci_pci
xhci_pci_renesas
!!Sysfs Files
/sys/class/sound/hwC0D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC0D2/driver_pin_configs:
/sys/class/sound/hwC0D2/user_pin_configs:
/sys/class/sound/hwC0D2/init_verbs:
/sys/class/sound/hwC0D2/hints:
!!ALSA/HDA dmesg
[    0.122578] ACPI: Added _OSI(Linux-Dell-Video)
[    0.122578] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.122578] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    2.909090]  </TASK>
[    2.909092] Modules linked in: cros_ec_typec( ) typec roles i2c_i801( ) snd_intel_sdw_acpi snd_soc_da7219 processor_thermal_device_pci_legacy snd_soc_max98357a processor_thermal_device cros_usbpd_notify snd_soc_core tpm_tis_spi snd_hda_codec i2c_smbus lpc_ich rfkill processor_thermal_rfim tpm_tis_core i915( ) intel_vbtn snd_compress processor_thermal_mbox cros_ec_lpcs sparse_keymap soc_button_array i2c_hid_acpi chromeos_tbmc cros_ec i2c_hid snd_hda_core processor_thermal_rapl ac97_bus elants_i2c elan_i2c tpm snd_pcm_dmaengine snd_hwdep int3403_thermal intel_rapl_common rng_core int340x_thermal_zone snd_pcm int3400_thermal intel_soc_dts_iosf snd_timer ttm intel_lpss_pci snd intel_pmc_bxt intel_lpss intel_gtt dwc3_pci acpi_thermal_rel idma64 soundcore video cros_kbd_led_backlight mac_hid coreboot_table squashfs loop uinput fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 mmc_block serio_raw atkbd libps2 i8042 sdhci_pci cqhci sdhci xhci_pci crc32c_intel mmc_core
[    2.909171]  xhci_pci_renesas serio
[    3.060364] i915 0000:00:02.0: [drm] RC6 and powersaving disabled by BIOS
[    3.155303] snd_hda_intel 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[    3.214802] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    3.219024] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    3.219280] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[    3.226403] Console: switching to colour frame buffer device 240x67
[    3.540663] loop7: detected capacity change from 0 to 8
[    3.559698] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input10
[    3.559826] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input11
[    3.559941] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input12
[    3.560048] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input13
[    3.560150] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input14
[    3.759783] NET: Registered PF_QIPCRTR protocol family
output of cat /proc/asound/modules and lspci -v | grep -A7 -i "audio"
[denisuu@blooglet ~]$ cat /proc/asound/modules
 0 snd_hda_intel
[denisuu@blooglet ~]$ lspci -v | grep -A7 -i "audio"
libkmod: kmod_config_parse: /etc/modprobe.d/alsa-fix.conf line 1: ignoring bad line starting with '“options'
00:0e.0 Multimedia audio controller: Intel Corporation Celeron/Pentium Silver Processor High Definition Audio (rev 06)
	Subsystem: Intel Corporation Device 7270
	Flags: bus master, fast devsel, latency 0, IRQ 122
	Memory at 91418000 (64-bit, non-prefetchable) [size=16K]
	Memory at 91200000 (64-bit, non-prefetchable) [size=1M]
	Capabilities: <access denied>
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel, snd_soc_skl, snd_sof_pci_intel_apl
Output of dmesg | grep snd
[denisuu@blooglet ~]$ sudo dmesg | grep snd
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64 root=UUID=21de0141-71de-4878-8fed-168d5c8fda16 rw quiet apparmor=1 security=apparmor udev.log_priority=3 snd_hda_intel.dmic_detect=0
[    0.021450] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.16-x86_64 root=UUID=21de0141-71de-4878-8fed-168d5c8fda16 rw quiet apparmor=1 security=apparmor udev.log_priority=3 snd_hda_intel.dmic_detect=0
[    3.041371] Modules linked in: rapl(+) cros_ec_typec(+) snd_soc_da7219 intel_cstate snd_intel_dspcfg typec snd_soc_max98357a mac80211 cros_usbpd_notify snd_intel_sdw_acpi roles pcspkr i915(+) intel_vbtn i2c_i801(+) snd_hda_codec cros_ec_lpcs i2c_smbus snd_soc_core libarc4 cros_ec soc_button_array sparse_keymap chromeos_tbmc tpm_tis_spi snd_hda_core processor_thermal_device_pci_legacy tpm_tis_core cfg80211 processor_thermal_device snd_compress tpm processor_thermal_rfim ac97_bus i2c_hid_acpi elan_i2c rng_core processor_thermal_mbox snd_pcm_dmaengine snd_hwdep i2c_hid elants_i2c ttm snd_pcm processor_thermal_rapl intel_rapl_common snd_timer dwc3_pci int3403_thermal rfkill video int340x_thermal_zone snd intel_gtt intel_lpss_pci coreboot_table int3400_thermal soundcore intel_soc_dts_iosf intel_lpss intel_pmc_bxt mac_hid lpc_ich cros_kbd_led_backlight idma64 acpi_thermal_rel squashfs loop uinput crypto_user fuse ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 mmc_block serio_raw
[    3.076891] snd_hda_intel 0000:00:0e.0: dmic_detect option is deprecated, pass snd-intel-dspcfg.dsp_driver=1 option instead
[    3.115039] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
it needs the sof drivers and sof firmware (blobs) - specifically sof-audio-pci-intel-apl and glk_rt5682_max98357a
works OOTB here on a similar GeminiLake Chromebook with Manjaro Cinnamon 21.2.1 w/proprietary drivers
how about dmesg | grep -e sof- -e glk -e snd
Kernel boot option snd_hda_intel.dmic_detect=0 was deprecated with release of kernel v5.8
I suggest removing this option from /etc/default/grub and
sudo update-grub
lspci data suggests option to disable dmic may also have been added in file /etc/modprobe.d/alsa-fix.conf
I suggest /etc/modprobe.d/alsa-fix.conf is deleted
and system rebooted to ensure the boot and modprobe options are not loaded
How do I install these? I already tried to install sof-firmware with: sudo pacman -S sof-firmware
Here’s the output of sudo dmesg | grep -e sof- -e glk -e snd:
[denisuu@blooglet ~]$ sudo dmesg | grep -e sof- -e glk -e snd
[    2.899311] Modules linked in: snd_soc_da7219(+) libarc4 snd_soc_max98357a(+) i2c_i801(+) cros_ec_typec(+) processor_thermal_device_pci_legacy snd_soc_core processor_thermal_device typec snd_hda_core i2c_smbus processor_thermal_rfim cros_usbpd_notify snd_compress roles processor_thermal_mbox cfg80211 processor_thermal_rapl ac97_bus ttm snd_hwdep intel_lpss_pci snd_pcm_dmaengine intel_rapl_common int3403_thermal rfkill intel_lpss cros_ec_lpcs intel_vbtn int340x_thermal_zone intel_soc_dts_iosf dwc3_pci intel_gtt tpm_tis_spi soc_button_array snd_pcm cros_ec idma64 sparse_keymap tpm_tis_core snd_timer chromeos_tbmc tpm i2c_hid_acpi snd i2c_hid soundcore cros_kbd_led_backlight elants_i2c rng_core elan_i2c coreboot_table mac_hid int3400_thermal video acpi_thermal_rel intel_pmc_bxt squashfs loop uinput fuse crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 mmc_block serio_raw atkbd libps2 sdhci_pci cqhci sdhci i8042 xhci_pci crc32c_intel mmc_core xhci_pci_renesas serio
[    3.091488] snd_hda_intel 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[    3.513891] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
[    3.683845] snd_hda_intel 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
I removed both and rebooted, but still no audio.
data from ‘lspci’ shows that ALSA driver snd_sof_pci_intel_apl is present, so attempt to install sof-firmware was probably successful
Data also shows legacy driver snd_hda_intel is in use rather than snd_sof_pci_intel_apl
snd_hda_intel does not support internal digital array microphone (dmic) but it may be needed as a workaround option if the SOF driver is not working correctly
If audio is not working as expected, please post more information about ALSA configuration of audio devices
snd_sof_pci_intel_apl seemed to be present since the first post?
So maybe installing sof-firmware didn’t do anything? Probably unrelated but restart, suspend, shutdown and hibernate aren’t working either. So maybe there’s more going on than just the driver? If not I’ll troubleshoot it later.
This is the output of sudo alsa-info.sh --upload
upload=true&script=true&cardinfo=
!!Script ran on: Fri Feb  4 13:04:28 UTC 2022
ID_LIKE=arch
!!DMI Information
Manufacturer:      HP
System SKU:        sku68
Board Vendor:      HP
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
PipeWire:
      Running - Yes
Pulseaudio:
      Running - Yes
Jack:
      Running - No
	dmic_detect : Y
	enable_msi : -1
	pm_blacklist : Y
	power_save : 1
	single_cmd : -1
	snoop : -1
!!Sysfs card info
Tree:
--startcollapse--
Address: 2
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
  PCM:
  PCM:
  PCM:
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
  Pin-ctls: 0x00:
  Devices: 0
  Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116,  8 Feb  4 10:15 /dev/snd/controlC0
crw-rw----+ 1 root audio 116,  7 Feb  4 10:15 /dev/snd/hwC0D2
crw-rw----+ 1 root audio 116,  6 Feb  4 10:15 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116,  2 Feb  4 10:15 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  3 Feb  4 10:15 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116,  4 Feb  4 10:15 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116,  5 Feb  4 10:15 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116,  1 Feb  4 10:15 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Feb  4 10:15 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root  60 Feb  4 10:15 .
drwxr-xr-x 3 root root 240 Feb  4 10:15 ..
lrwxrwxrwx 1 root root  12 Feb  4 10:15 pci-0000:00:0e.0 -> ../controlC0
APLAY
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
  Subdevices: 1/1
ARECORD
!!Amixer output
  Controls      : 35
  Simple ctrls  : 5
  Mono: Playback [on]
  Mono: Playback [on]
  Mono: Playback [on]
  Mono: Playback [on]
  Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
	control.1 {
		iface CARD
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.7 {
		iface CARD
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.13 {
		iface CARD
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.19 {
		iface CARD
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface PCM
		device 3
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.32 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.33 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.34 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.35 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
--endcollapse--
8250_dw
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
atkbd
blake2b_generic
bluetooth
bnep
btbcm
btintel
btrfs
btrtl
btusb
ccm
cdrom
cfg80211
chromeos_tbmc
cmac
coreboot_table
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cros_ec
cros_ec_chardev
cros_ec_debugfs
cros_ec_dev
cros_ec_lpcs
cros_ec_sysfs
cros_ec_typec
cros_usbpd_charger
cros_usbpd_logger
cros_usbpd_notify
cryptd
crypto_simd
crypto_user
dm_mod
dw_dmac
dwc3_pci
ecdh_generic
elan_i2c
elants_i2c
ext4
fat
fuse
ghash_clmulni_intel
hfs
hfsplus
hid_logitech_hidpp
i2c_hid
i2c_hid_acpi
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
int3400_thermal
int3403_thermal
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_punit_ipc
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_platform
intel_vbtn
ip_tables
jbd2
jfs
joydev
ledtrig_audio
libarc4
libcrc32c
libps2
loop
lpc_ich
mac80211
mac_hid
mbcache
mc
minix
mmc_block
mmc_core
mousedev
msdos
mtd
pcspkr
qrtr
raid6_pq
rapl
rfcomm
rfkill
rng_core
roles
rtw88_8822c
rtw88_8822ce
rtw88_core
rtw88_pci
sdhci
sdhci_pci
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_soc_acpi
snd_soc_core
snd_soc_da7219
snd_soc_hdac_hda
snd_soc_max98357a
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soc_button_array
soundcore
soundwire_bus
soundwire_cadence
soundwire_intel
sparse_keymap
spi_nor
spi_pxa2xx_platform
squashfs
tpm
tpm_tis_core
tpm_tis_spi
ttm
typec
ufs
uhid
uinput
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
x_tables
xfs
xhci_pci
xhci_pci_renesas
xor
!!Sysfs Files
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
!!ALSA/HDA dmesg
[    0.123018] ACPI: Added _OSI(Linux-Dell-Video)
[    0.123018] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.123018] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    2.898439]  </TASK>
[    2.907202] CR2: 000000000000030c
[    2.977152] da7219 i2c-DLGS7219:00: Using default DAI clk names: da7219-dai-wclk, da7219-dai-bclk
[    3.148642] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[    3.683554] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0
[    3.707202] Console: switching to colour frame buffer device 240x67
[    3.812855] loop7: detected capacity change from 0 to 8
[    3.839261] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input10
[    3.839388] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input11
[    3.839547] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input12
[    3.839647] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input13
[    3.839759] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:0e.0/sound/card0/input14
[    3.852267] iTCO_wdt iTCO_wdt.1.auto: Found a Apollo Lake SoC TCO device (Version=5, TCOBASE=0x0460)
Thanks for the help guys, really appreciate it!
according to the site below I need: sof-glkda7219max too.
I checked those files, I don’t see anything helpful in them: Content
https://chromeos.guide/osdev/overlays/overlay-octopus
(chromium_source_tree)/src/overlays/overlay-octopus
├── chromeos-base
│   ├── chromeos-bsp-octopus
│   │   ├── chromeos-bsp-octopus-0.0.2-r48.ebuild
│   │   ├── chromeos-bsp-octopus-9999.ebuild
│   │   ├── files
│   │   │   ├── 93-powerd-overrides.rules
│   │   │   ├── 99-chromeos-octopus-usb-charge-mode.rules
│   │   │   ├── 99-chromeos-octopus-usb-runtime-suspend.rules
│   │   │   ├── ampton
│   │   │   │   ├── audio
│   │   │   │   │   ├── cras-config
│   │   │   │   │   │   ├── card_settings
│   │   │   │   │   │   └── dsp.ini
│   │   │   │   │   └── ucm-config
│   │   │   │   │       └── sof-glkrt5682max.2loc
│   │   │   │   │           ├── HiFi.conf
│   │   │   │   │           └── sof-glkrt5682max.conf
│   │   │   │   └── thermal
│   │   │   │       └── dptf.dv
│   │   │   ├── blooglet
│   │   │   │   ├── audio
│   │   │   │   │   │   ├── board.ini
│   │   │   │   │   │   ├── card2_settings
│   │   │   │   │       ├── sof-glkda7219max.1loc
│   │   │   │   │       │   ├── HiFi.conf
│   │   │   │   │       │   └── sof-glkda7219max.conf
│   │   │   │   │       └── sof-glkrt5682max.1loc
│   │   │   │   └── thermal
│   │   │   │       └── dptf.dv
Crouton shows:
cat /proc/asound/cards
 0 [sofglkda7219max]: sof-glkda7219ma - sof-glkda7219max
                      HP-Bloog-rev4-Bloog
yes, seems like BLOOG has a slightly different audio config than AMPTON. Is that module/driver available on your system?
The problem was the DMI (SMBIOS) did not match what sof-audio expected in a Chromebook. MrChromebox Firmware update solved this.
More info:
