This is a short one
1. Locate eclipse.ini
for zsh:
print -l /**/eclipse.ini
In my installation this was at /opt/eclipse-cpp/eclipse.ini
change the line after the line "-vm"
-vm
#plugins/org.eclipse.justj.openjdk.hotspot.jre.full.linux.x86_64_20.0.2.v20230801-2057/jre/bin/java
to:
-vm
/usr/lib/jvm/default/bin/java
Everytime you use archlinux-java set java ......
,this will also set the java-version used by eclipse
or you could set the path to your prefered java-version for eclipse:
-vm
/usr/lib/jvm/java-21-openjdk-bin/bin/java
