Difficulty: ★☆☆☆☆
Do you get the following message when you try to TRIM your external SSD?
the discard operation is not supported
We can easily overcome this by creating a udev rule in /etc/udev/rules.d
How to do it
Identify the VendorID and ProductID of your device.
Type:
lsusbin your terminal and locate your external SSD. In my case:
Bus 002 Device 005: ID 04e8:61f5 Samsung Electronics Co., Ltd Portable SSD T5You’ll see an ID value, mine is 04e8:61f5 The VendorID is the first part and the second part is the ProductID.
Create a udev rule
sudo nano /etc/udev/rules.d/50-usb-ssd-trim.rulesAnd enter this rule:
ACTION=="add|change", ATTRS{idVendor}=="04e8", ATTRS{idProduct}=="61f5", SUBSYSTEM=="scsi_disk", ATTR{provisioning_mode}="unmap"Ensure to use your VendorID and ProductID! Save and exit the editor.
The next time you plug in your device you can Trim it manually using the
fstrimcommand:sudo fstrim -v /path/to/SSD/mountpoint
Once a week/month should suffice, depending on your usage.
