Difficulty: ★★☆☆☆
The following steps use a Ricoh printer as an example but skip to the bottom for other “not working” printers):
Install the printer PPD (Postscript Printer Description):
- from the App Store (PAMAC, GUI app) from the AUR repository:
E.G.: http://aur.archlinux.org/packages/openprinting-ppds-pxlmono-ricoh
OR - Download the PPD from a PPD respository:
E.G. https://www.openprinting.org/ppd-o-matic.php?driver=pxlmono-Ricoh&printer=Ricoh-SP_320SFN&show=0
Go to your menu
Open
printers -
Click on Add
Click on your printer name under network but don’t let the Linux system fool you by the list of model numbers/drivers.
Instead, close your eyes and go to manually add PPD file -
load your downloaded file and boom
you are ready to print.
This is for Ricoh but below are the RTFM
and download sources that you should read and pick the right PPD / AUR package for the printer you need:
