Difficulty: ★★☆☆☆
This guide will show you how to set up Manjaro Plasma with what I call Robot theme (named after the wallpaper):
Activate the AUR if needed
Lets pull all the themes from the repositories and extra plasma applets:
yay -S plasma5-applets-latte-separator plasma5-applets-latte-spacer plasma5-applets-betterinlineclock-git latte-dock-git sudo pacman -S --needed arc-gtk-theme yay -S papirus-icon-theme kvantum-theme-arc arc-kde -
LATTE
- Latte Theme: Float - KDE Store
- Latte git may need a logout/login for working properly,
- import Float theme to Latte.
SYSTRAY TWEAKS
- To get spaces between the items in systray you need a tweak to do so. You’ll find it here
- unpack it to
~/.local/share/plasma/plasmoids - Logout/login is required.
- Configure Systray to have 15 px spaces.
WALLPAPER
- You can get the wallpaper here.
