[HowTo] Install the actual Anaconda version and fix the DPI and MESA-LOADER issues
Hi,
I’m doing AI developments and moved from Ubuntu to Manjaro, which works really, really great; love it.
Here are the steps to:
  • Install the actual version of Anaconda by yourself
  • Fix the DPI scaling issue (Fonts / Icons are way too large)
  • Fix the MESA-Loader issue
1.0 Installation of Anaconda
Install some packages, needed by Anaconda with:
pacman -Sy libxau libxi libxss libxtst libxcursor libxcomposite libxdamage libxfixes libxrandr libxrender mesa-libgl  alsa-lib libglvnd
Download the package from https://www.anaconda.com/products/individual . You can just copy the link by right-clicking on the Download - button and select “Copy link address”.
Let’s assume the link is somethink like: https://repo.anaconda.com/archive/Anaconda3-2021.11-Linux-x86_64.sh, then you type:
cd ~
wget https://repo.anaconda.com/archive/Anaconda3-2021.11-Linux-x86_64.sh
After Download, change the execution flag
chmod +x ~/Anaconda3-2021.11-Linux-x86_64.sh
and start the script, in this example:
./Anaconda3-2021.11-Linux-x86_64.sh
saying “yes” to everything. Then close and re-open the Terminal to set the environment (or source your profile).
Start Anaconda to make sure the anaconda-navigator.ini is written (otherwise editing the Anaconda config will not work):
anaconda-navigator
close it.
However, after installation I was facing the DPI - issues as described above. Here’s how I fixed it:
1.1 Edit the Anaconda config:
nano ~/.anaconda/navigator/anaconda-navigator.ini
and set:
enable_high_dpi_scaling = True
1.2 Create an Anaconda startup file
nano ~/anaconda.desktop
and paste the following lines into it:
[Desktop Entry]
Type=Application
Name=Anaconda
Exec=/usr/bin/env QT_AUTO_SCREEN_SCALE_FACTOR=0 QT_SCALE_FACTOR=1.5 /home/uwuertz/anaconda3/bin/anaconda-navigator
Terminal=false
Icon=/home/uwuertz/anaconda3/lib/python3.9/site-packages/anaconda_navigator/static/images/anaconda-icon-256x256.png
Even if you have this already:
There is a different command line for starting up Anaconda: “Exec=/usr/bin/env QT_AUTO_SCREEN_SCALE_FACTOR=0 QT_SCALE_FACTOR=1.5 /home/uwuertz/anaconda3/bin/anaconda-navigator” !
Please check and change the directory “/home/uwuertz/…” to your needs and double check the python version! Otherwise it will not work!
Install it with:
sudo desktop-file-install anaconda.desktop
Caution: This fix will only work, if you start Anaconda via the icon.
1.3 If you want to execute Anaconda from cli, you have to set the scaling factor manually
export QT_AUTO_SCREEN_SCALE_FACTOR=0
QT_SCALE_FACTOR=1.5 anaconda-navigator
2.0 In case you get messages after executing Anaconda, such as:
“libGL error: MESA-LOADER: failed to open iris:…”
then execute:
mv ~/anaconda3/lib/libstdc++.so.6 ~/anaconda3/lib/libstdc++.so.6.bck
to fix this issue. As a last step you can check the installation for updates. To do this, open a terminal and execute:
conda update conda
At least on my Manjaro, this has worked perfect for me. Hope it helps for some others.
What if drivers dont works? I cant install it…
Drivers are not part of any of the instructions above.
Besides which a number of suggestions here are not advisable, including ‘pacman -Sy …’.
