[HowTo] install and run screenFetch or Neofetch
Difficulty: ★☆☆☆☆
ScreenFetch and Neofetch are command-line system information tools. More specifically they can display information about your operating system, software and hardware like this:
neofetch
██████████████████  ████████   fab-user@fab-manjaro
██████████████████  ████████   OS: Manjaro Linux x86_64
██████████████████  ████████   Host: Predator G9-793 V1.13
████████            ████████   Kernel: 5.8.6-1-MANJARO
████████  ████████  ████████   Uptime: 7 days, 28 mins
████████  ████████  ████████   Packages: 1327 (pacman)
████████  ████████  ████████   Shell: bash 5.0.18
████████  ████████  ████████   Resolution: 1920x1080
████████  ████████  ████████   DE: Plasma
████████  ████████  ████████   WM: KWin
████████  ████████  ████████   WM Theme: Breeze
████████  ████████  ████████   Theme: Breath2 [Plasma], Breath [GTK2/3]
████████  ████████  ████████   Icons: breath2 [Plasma], breath2 [GTK2/3]
                               Terminal: konsole
                               Terminal Font: Envy Code R 8
                               CPU: Intel i7-7700HQ (8) @ 3.800GHz
                               GPU: NVIDIA GeForce GTX 1070 Mobile
                               Memory: 7088MiB / 15951MiB
  • To install them, open the terminal and type: sudo pacman -S sceenfetch for screenFetch or sudo pacman -S neofetch for Neofetch.
  • To run them type: screenfetch or neofetch.
  • To make them autostart every time you open the terminal,
    The automatic way
    • Type sudo su.
    • After giving your password
    • type:
      echo screenfetch >> /etc/bash.bashrc for screenFetch
      OR
      echo neofetch >> /etc/bash.bashrc for Neofetch.
    The manual way
    • you have to edit the bash.bashrc located at /etc/.
    • Navigate as root to /etc/bash.bashrc
    • Add screenfetch or neofetch at the bottom.
    • Then save the file.
  • Close the terminal, reopen it and you are done.
Why are you using a manjaro logo as your profile picture? Are you somehow affiliated with Manjaro?
Because the Manjaro logo is awesome. No I am not.
Hi!
You miss something
Run a source .bashrc or .zshrc after edit the file to update it
… or just open a new Terminal window. That seems to work. :wink:
Thanks, nice tutorial :slight_smile:
A post was split to a new topic: Converted to Personal Message
Hi, I’m trying to make fastfetch to run every time I open the terminal on Manjaro Gnome, installed fastfetch it should work like neofetch or screenfetch.
Tried adding “fastfetch” and “/usr/bin/fastfetch” to “~/.bashrc” and to “/etc/bash.bashrc” but doesn’t work.
Tryed also installing and setting up neofetch in the same way but doesn’t work either.
Am I doing something wrong?
GNOME uses ZSH by default. If you’re using ZSH, add it to ~/.zshenv.
If you are using BASH, try adding it to ~/.bash_profile.
That’s it…
ZSH. Thanks.
Added /usr/bin/fastfetch to ~/.zshrc.
FYI, .zshenv is always sourced while .zshrc is per session.
Tip: use backticks ` instead of quotation marks " for monospaced text. :wink:
But I have not .zshenv file in my /home folder.
Thanks for the tip.
