[HowTo] have Live wallpaper on Manjaro Gnome
Difficulty: ★★☆☆☆
This guide will show you how to have a Live Wallpaper on Manjaro Linux. ¹
Installation instructions:
  1. Install mpv from the official repositories by executing:
    pamac install mpv
  2. Install xwinwrap-git after activating the AUR by executing:
    pamac install xwinwrap-git
Setup
  1. To set up a script that makes a Live Wallpaper possible:
    cd /usr/local/bin
    sudo nano Live.sh
  2. Insert this command, while modifying the path to the video file you want to use:
    xwinwrap -fs -fdt -ni -b -nf -- mpv -wid WID --no-audio --loop "/path/to/your/videofile"
  3. Press Ctrl+X to exit and Y and Enter to save.
  4. make the script executable:
    sudo chmod +x Live.sh
Launch your new Live Wallpaper
  1. To launch the Live Wallpaper automatically you need a .desktop file in ~/.config/autostart:
    nano ~/.config/autostart/LiveWallpaper.desktop
  2. Copy-paste this and remember to modify its path in Exec;
    [Desktop Entry]
    Type=Application
    Exec=sh -c "path/to/Live.sh"
    Hidden=false
    NoDisplay=false
    X-GNOME-Autostart-enabled=true
    Name=Live wallpaper
  3. Again, press Ctrl+X to exit and Y and Enter to save.
  4. Log out and log in again and if everything goes according to plan you should see your Live Wallpaper now!
:slight_smile: :+1:
Note 1: It have only been tested on Gnome stable, but should work on any DE or WM. RAM consumptions is around ~100MB RAM.
Hi @Storm,
Thank you very much for this. Might give it a try myself at some stage as well.
Please, please, please, see Tutorial Content Creation Guide and edit your post accordingly. I would, but am unable to edit posts that aren’t my own.
Okay :). I’m already editing :stuck_out_tongue:
Thank you! :grinning_face_with_smiling_eyes:
I’m not sure how to use <kbd> command to illustrate keyboard buttons. I need to illustrate save and exit nano.
Command is not the right word. It’s actually markup, more specifically, HTML. That’s the tag for the <kbd> element. And using it is easy. See <kbd>this</kbd> will produce this
For example, if you wish to do Control + O: <kbd>Ctrl</kbd>+<kbd>O</kbd> produces Ctrl + O
I hope this clears it up. At lease somewhat.
Hey man, thanks for the idea and rundown.
I tried it using above scripts but the panel didn’t work properly on kde. After some searching, I found that there is a plugin to set video wallpapers from settings itself.
I’m using this wallpaper -
source: Aeolian Live Wallpaper | Live Wallpaper PC
I have tried KDE’s live wallpaper plugin. It’s nice, but it eats your RAM big time last I tried it.
It depends on the video I guess. Loads the entirely of it into ram.
The wid option must be an integer: WID
Error parsing option wid (option parameter could not be parsed)
Setting commandline option --wid=WID failed.
Exiting... (Fatal error)
mpv died, exit status 1
If you get this error above while running the xwinwrap command on the Setup part of the tutorial change the WID of the command to %WID.
(Try to run the original command on your terminal to reproduce the error, if it happens it won’t work on startup if you don’t change the WID to %WID)
so the final command will be like this:
xwinwrap -fs -fdt -ni -b -nf -- mpv -wid %WID --no-audio --loop "/path/to/your/videofile"
Thanks, does it consume a large amount of computer resources?
