Difficulty: ★☆☆☆☆
This is my recommendation for best experience with Google Chrome. Feel free debate about options.
For some reason
--enable-features
and--disable-features
are not to be applied properly from chrome-flags.conf file. Then enable it properly flags inchrome://flags
page. See URLs below.
Create FILE ~/.config/chrome-flags.conf
nano ~/.config/chrome-flags.conf
with SINGLE LINE CMD:
--flag-switches-begin --force-dark-mode --high-dpi-support=1 --force-device-scale-factor=1.2 --ignore-gpu-blacklist --enable-smooth-scrolling --flag-switches-end
Disable Media key controls applet and keyboard binding handling. Disable QUIC protocol against connections issues
SET DISABLED
IN
chrome://flags/#enable-quic
See: https://www.fastvue.co/fastvue/blog/googles-quic-protocols-security-and-reporting-implications/
SET ENABLED
IN
chrome://flags/#tab-groups
chrome://flags/#privacy-settings-redesign
chrome://flags/#omnibox-context-menu-show-full-urls
SET ENABLED (mark as actively dangerous
) IN
chrome://flags/#enable-mark-http-as
