- Difficulty: ★★★☆☆
- Pre-requisites: Working local Bind9 DNS server.
Steps:
To make your local DNS server become an advertising filter all you need to do is make use of a
Response policy zone.
To do that in
Bind9 we make use of
RPZ via the response-policysection in theoptionsconfiguration, eg:options { // RPZ Config response-policy { zone "redirect" policy given; zone "captive-portal" policy cname captive-portal.local.; zone "noads" policy nxdomain; }; };- The advertising filtering will be done via the
noadszone. - The other zones i defined above,
redirectandcaptive-portal, can be left out if you don’t make use of them.
I only added them to show how to make use of multiple RPZs for different purposes.
or use include “/etc/bind/conf/options/rpz.conf”; instead in its place and put the directive in it’s own file for easy administration.
Feel free to use a different file/path for the actual config piece, this path is just what i personally use…/etc/bind/conf/options/rpz.conf
// RPZ Config response-policy { zone "redirect" policy given; zone "captive-portal" policy cname captive-portal.local.; zone "noads" policy nxdomain; }; - The advertising filtering will be done via the
After making that change in the
optionsconfiguration we ofcourse also need to tell Bind9 where to find the zone file(s).
We do that by defining a similarly named zone(s) at the top level of the configuration, eg.:/etc/bind/conf/rpz.conf
/** * For use in response-policy */ zone "redirect" { type master; file "/etc/bind/zones/rpz/redirect.zone"; allow-query { private; corpnets; }; // allow-query {none;}; zone-statistics full; serial-update-method date; }; zone "captive-portal" { type master; file "/etc/bind/zones/rpz/captive-portal.zone"; allow-query { private; corpnets; }; // allow-query {none;}; zone-statistics full; serial-update-method date; }; zone "noads" { type master; file "/etc/bind/zones/rpz/noads.zone"; allow-query { private; corpnets; }; // allow-query {none;}; zone-statistics full; serial-update-method date; }; -
Now the last part to make it complete we create the zone file(s) using the normal syntax of zone file definitions.
Below i will only post the contents of my current “noads.zone” file
; -*- Bind9-Zone -*- ; Response Policy Zone (RPZ) file for NOADS ; See: "Response Policy Zone (RPZ) Rewriting" in Bind9-ARM ; http://localhost/doc/bind9-doc/arm/Bv9ARM.ch06.html#id2589969 ; $TTL 1d ; default TTL @ IN SOA ns.lan. root.lan. ( 2020110901 ; Serial 7d ; Refresh 24h ; Retry 28d ; Expire 7d ) ; Negative Cache TTL IN NS ns.lan. IN NS localhost. ; The domains we want to filter. ; QNAME policy records. There are no periods (.) after the owner names. ;; google google-analytics.com CNAME . ; NXDOMAIN policy *.google-analytics.com CNAME . ; NXDOMAIN policy googleanalytics.com CNAME . ; NXDOMAIN policy *.googleanalytics.com CNAME . ; NXDOMAIN policy googleadservices.com CNAME . ; NXDOMAIN policy *.googleadservices.com CNAME . ; NXDOMAIN policy googlesyndication.com CNAME . ; NXDOMAIN policy *.googlesyndication.com CNAME . ; NXDOMAIN policy ;pagead2.googlesyndication.com CNAME . ; NXDOMAIN policy;; Unneeded because of the wildcards above but included for completeness. googletagservices.com CNAME . ; NXDOMAIN policy *.googletagservices.com CNAME . ; NXDOMAIN policy safebrowsing.google.com CNAME . ; NXDOMAIN policy safebrowsing-cache.google.com CNAME . ; NXDOMAIN policy ;; Windows 10 a.ads1.msn.com CNAME . ; NXDOMAIN policy a.ads2.msads.net CNAME . ; NXDOMAIN policy a.ads2.msn.com CNAME . ; NXDOMAIN policy a.rad.msn.com CNAME . ; NXDOMAIN policy a-0001.a-msedge.net CNAME . ; NXDOMAIN policy a-0002.a-msedge.net CNAME . ; NXDOMAIN policy a-0003.a-msedge.net CNAME . ; NXDOMAIN policy a-0004.a-msedge.net CNAME . ; NXDOMAIN policy a-0005.a-msedge.net CNAME . ; NXDOMAIN policy a-0006.a-msedge.net CNAME . ; NXDOMAIN policy a-0007.a-msedge.net CNAME . ; NXDOMAIN policy a-0008.a-msedge.net CNAME . ; NXDOMAIN policy a-0009.a-msedge.net CNAME . ; NXDOMAIN policy ac3.msn.com CNAME . ; NXDOMAIN policy ad.doubleclick.net CNAME . ; NXDOMAIN policy adnexus.net CNAME . ; NXDOMAIN policy adnxs.com CNAME . ; NXDOMAIN policy ads.msn.com CNAME . ; NXDOMAIN policy ads1.msads.net CNAME . ; NXDOMAIN policy ads1.msn.com CNAME . ; NXDOMAIN policy aidps.atdmt.com CNAME . ; NXDOMAIN policy aka-cdn-ns.adtech.de CNAME . ; NXDOMAIN policy a-msedge.net CNAME . ; NXDOMAIN policy apps.skype.com CNAME . ; NXDOMAIN policy az361816.vo.msecdn.net CNAME . ; NXDOMAIN policy az512334.vo.msecdn.net CNAME . ; NXDOMAIN policy b.ads1.msn.com CNAME . ; NXDOMAIN policy b.ads2.msads.net CNAME . ; NXDOMAIN policy b.rad.msn.com CNAME . ; NXDOMAIN policy bs.serving-sys.com CNAME . ; NXDOMAIN policy c.atdmt.com CNAME . ; NXDOMAIN policy c.msn.com CNAME . ; NXDOMAIN policy cdn.atdmt.com CNAME . ; NXDOMAIN policy cds26.ams9.msecn.net CNAME . ; NXDOMAIN policy compatexchange.cloudapp.net CNAME . ; NXDOMAIN policy corpext.msitadfs.glbdns2.microsoft.com CNAME . ; NXDOMAIN policy cs1.wpc.v0cdn.net CNAME . ; NXDOMAIN policy db3aqu.atdmt.com CNAME . ; NXDOMAIN policy ec.atdmt.com CNAME . ; NXDOMAIN policy fe2.update.microsoft.com.akdns.net CNAME . ; NXDOMAIN policy feedback.microsoft-hohm.com CNAME . ; NXDOMAIN policy flex.msn.com CNAME . ; NXDOMAIN policy g.msn.com CNAME . ; NXDOMAIN policy h1.msn.com CNAME . ; NXDOMAIN policy lb1.www.ms.akadns.net CNAME . ; NXDOMAIN policy live.rads.msn.com CNAME . ; NXDOMAIN policy m.adnxs.com CNAME . ; NXDOMAIN policy m.hotmail.com CNAME . ; NXDOMAIN policy msedge.net CNAME . ; NXDOMAIN policy msftncsi.com CNAME . ; NXDOMAIN policy msnbot-65-55-108-23.search.msn.com CNAME . ; NXDOMAIN policy msntest.serving-sys.com CNAME . ; NXDOMAIN policy pre.footprintpredict.com CNAME . ; NXDOMAIN policy preview.msn.com CNAME . ; NXDOMAIN policy pricelist.skype.com CNAME . ; NXDOMAIN policy rad.live.com CNAME . ; NXDOMAIN policy rad.msn.com CNAME . ; NXDOMAIN policy s.gateway.messenger.live.com CNAME . ; NXDOMAIN policy s0.2mdn.net CNAME . ; NXDOMAIN policy schemas.microsoft.akadns.net CNAME . ; NXDOMAIN policy static.2mdn.net CNAME . ; NXDOMAIN policy statsfe1.ws.microsoft.com CNAME . ; NXDOMAIN policy statsfe2.update.microsoft.com.akadns.net CNAME . ; NXDOMAIN policy statsfe2.ws.microsoft.com CNAME . ; NXDOMAIN policy survey.watson.microsoft.com CNAME . ; NXDOMAIN policy view.atdmt.com CNAME . ; NXDOMAIN policy www.msftncsi.com CNAME . ; NXDOMAIN policy ;; Other wildcard *.ad-x.co.uk CNAME . ; NXDOMAIN policy *.adcolony.com CNAME . ; NXDOMAIN policy *.adkmob.com CNAME . ; NXDOMAIN policy *.adonline.e-kolay.net CNAME . ; NXDOMAIN policy *.ads.anyoption.it CNAME . ; NXDOMAIN policy *.ads.mopub.com CNAME . ; NXDOMAIN policy *.ads.mp.mydas.mobi CNAME . ; NXDOMAIN policy *.ads.yahoo.com CNAME . ; NXDOMAIN policy *.ads.yimg.com CNAME . ; NXDOMAIN policy *.ads.zynga.com CNAME . ; NXDOMAIN policy *.adtilt.com CNAME . ; NXDOMAIN policy *.amazon-adsystem.com CNAME . ; NXDOMAIN policy *.amplitude.com CNAME . ; NXDOMAIN policy *.ashleymadison.com CNAME . ; NXDOMAIN policy *.buysellads.com CNAME . ; NXDOMAIN policy *.carbonads.com CNAME . ; NXDOMAIN policy *.conduit.com CNAME . ; NXDOMAIN policy *.dbreklam2.net CNAME . ; NXDOMAIN policy *.doubleclick.net CNAME . ; NXDOMAIN policy *.exgfnetwork.com CNAME . ; NXDOMAIN policy *.fastclick.net CNAME . ; NXDOMAIN policy *.gameanalytics.com CNAME . ; NXDOMAIN policy *.heyzap.com CNAME . ; NXDOMAIN policy *.hotjar.com CNAME . ; NXDOMAIN policy *.inmobi.com CNAME . ; NXDOMAIN policy *.kontera.com CNAME . ; NXDOMAIN policy *.ksmobile.com CNAME . ; NXDOMAIN policy *.mobileapptracking.com CNAME . ; NXDOMAIN policy *.mobula.sdk.duapps.com CNAME . ; NXDOMAIN policy *.onlinewebstat.com CNAME . ; NXDOMAIN policy *.otomobilfirsati.com CNAME . ; NXDOMAIN policy *.quantserve.com CNAME . ; NXDOMAIN policy *.sayyac.com CNAME . ; NXDOMAIN policy *.sponsorpay.com CNAME . ; NXDOMAIN policy *.startappservice.com CNAME . ; NXDOMAIN policy *.tapjoyads.com CNAME . ; NXDOMAIN policy *.telemetry.mozilla.org CNAME . ; NXDOMAIN policy *.traffichaus.com CNAME . ; NXDOMAIN policy *.trafficjunky.net CNAME . ; NXDOMAIN policy *.trafficstars.com CNAME . ; NXDOMAIN policy *.trovi.com CNAME . ; NXDOMAIN policy *.virgul.com CNAME . ; NXDOMAIN policy ;; Other single domains app-measurement.com CNAME . ; NXDOMAIN policy app.adjust.com CNAME . ; NXDOMAIN policy; Adjust tracking SDK - see: https://firefox-source-docs.mozilla.org/mobile/android/fennec/adjust.html analytics.localytics.com CNAME . ; NXDOMAIN policy analytics.yahoo.com CNAME . ; NXDOMAIN policy beacon.wikia-services.com CNAME . ; NXDOMAIN policy cm.ksmobile.com CNAME . ; NXDOMAIN policy client.midosoo.com CNAME . ; NXDOMAIN policy data.flurry.com CNAME . ; NXDOMAIN policy delivery.reklamz.com CNAME . ; NXDOMAIN policy e.apsalar.com CNAME . ; NXDOMAIN policy hit.clickaider.com CNAME . ; NXDOMAIN policy hitbox.com CNAME . ; NXDOMAIN policy ingameads.gameloft.com CNAME . ; NXDOMAIN policy inmobisdk-a.akamaihd.net CNAME . ; NXDOMAIN policy kampanya.qnbfinansbank.com CNAME . ; NXDOMAIN policy; Advert farm of QNB Finansbank. live.chartboost.com CNAME . ; NXDOMAIN policy marketing-ssl.upsight-api.com CNAME . ; NXDOMAIN policy media.admob.com CNAME . ; NXDOMAIN policy mobile-collector.newrelic.com CNAME . ; NXDOMAIN policy my.mobfox.com CNAME . ; NXDOMAIN policy pokazuwka.com CNAME . ; NXDOMAIN policy pp.appsflyer.com CNAME . ; NXDOMAIN policy propellerads.com CNAME . ; NXDOMAIN policy ptreklam.com.tr CNAME . ; NXDOMAIN policy ptreklamssp.com.tr CNAME . ; NXDOMAIN policy reklam.memurlar.net CNAME . ; NXDOMAIN policy ; This doesnt work... ;reklam*.com CNAME . ; NXDOMAIN policy rubiconproject.com CNAME . ; NXDOMAIN policy supersonic.ironbeast.io CNAME . ; NXDOMAIN policy supersonicads-a.akamaihd.net CNAME . ; NXDOMAIN policy track.appsflyer.com CNAME . ; NXDOMAIN policy www.leanplum.com CNAME . ; NXDOMAIN policy; MMA Mobile Marketing Automation - see: https://firefox-source-docs.mozilla.org/mobile/android/fennec/mma.html -
Restart the Bind9 DNS server to have it apply our RPZ: systemctl restart named
Check that it works by querying a domain that you have put in the zonefile, fe:
trimoon@manjaro ~ resolvectl query googleanalytics.com googleanalytics.com: resolve call failed: 'googleanalytics.com' not found ✘ trimoon@manjaro ~ host -v googleanalytics.com Trying "googleanalytics.com" Host googleanalytics.com not found: 3(NXDOMAIN) Received 37 bytes from 127.0.0.53#53 in 0 ms Received 37 bytes from 127.0.0.53#53 in 0 ms ✘ trimoon@manjaro ~ resolvectl query google.com google.com: 2a00:1450:4017:806::200e 216.58.206.174 -- Information acquired via protocol DNS in 219.1ms. -- Data is authenticated: no trimoon@manjaro ~
I use a custom made AI that detects ads, and blocks them!!
