With the recently announced abandonment of Neofetch, many of us are choosing to use an alternative system information display option like Fastfetch.
Fastfetch is written in C and is built for customization. For me, it opens almost instantly, whereas Neofetch often lags before displaying. By default, Fastfetch shows several more categories than Neofetch.
As of now, Arch-based distributions default to the Arch logo in Fastfetch. Iβve tested this on Manjaro and Endeavor, and I assume itβs the same for Reborn, Arco, Garuda and others.
To display the Manjaro logo instead of Arch:
- Generate a configuration file with the following command (hat tip to @scotty65 and @robin0800 in comments below):
fastfetch -l manjaro --gen-config-force
- If youβd like to display the Fastfetch output every time you open a terminal, do the following.
Open the ~/.bashrc file (or equivalent config file, I assume, if youβre using a different shell like zsh or fish) in a text editor, and add this line:
fastfetch
Next time you open a terminal, you should see a Fastfetch display of system information, complete with the Manjaro logo instead of Arch.
Thank you for the guide.
But how to hide ip address and external drives usb drives information from fastfetch?
The developer has created a small configuration guide on Github:
There is a βlocal ipβ entry in the .jsonc file that you can probably remove, as well as βdisk.β The config file seems very simple and straightforward.
fastfetch in the repository came with a variety of logos built-in
To find all available built-in logos:
fastfetch --list-logos
There are 411 of them at the moment.
I just created a fastfetch config file to display the Manjaro logo as default by running the command fastfetch -l manjaro --gen-config
The generated config file has been written in `/home/scotty/.config/fastfetch/config.jsonc`
So, now running fastfetch gives me this output:
ββββββββββββββββββ ββββββββ scotty@scott-ser
ββββββββββββββββββ ββββββββ ----------------
ββββββββββββββββββ ββββββββ OS: Manjaro Linux Wynsdey 24.0.0 x86_64
ββββββββββββββββββ ββββββββ Host: SER
ββββββββ ββββββββ Kernel: 6.9.0-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 8 hours, 26 mins
ββββββββ ββββββββ ββββββββ Packages: 1473 (pacman)[testing]
ββββββββ ββββββββ ββββββββ Shell: zsh 5.9
ββββββββ ββββββββ ββββββββ Display (PHL 243V7): 1920x1080 @ 60Hz [External]
ββββββββ ββββββββ ββββββββ DE: KDE Plasma 6.0.4
ββββββββ ββββββββ ββββββββ WM: KWin (Wayland)
ββββββββ ββββββββ ββββββββ WM Theme: Breeze
ββββββββ ββββββββ ββββββββ Theme: Breeze (CyberHack) [QT], Breeze-Dark [GTK2], Breeze [GTK3]
ββββββββ ββββββββ ββββββββ Icons: BeautyLine [QT], BeautyLine [GTK2/3/4]
Font: Noto Sans (10pt) [QT], Noto Sans (10pt) [GTK2/3/4]
Cursor: Bibata-Rainbow-Modern (28px)
Terminal: konsole 24.2.2
Terminal Font: MesloLGS NF (10pt)
CPU: AMD Ryzen 7 5800H (16) @ 4.46 GHz
GPU: AMD Radeon Vega Series / Radeon Vega Mobile Series @ 0.40 GHz [Integrated]
Memory: 5.78 GiB / 28.31 GiB (20%)
Swap: 0 B / 18.88 GiB (0%)
Disk (/): 45.76 GiB / 457.09 GiB (10%) - ext4
Disk (/run/media/scotty/14TB-Elements): 5.04 TiB / 12.63 TiB (40%) - ext4
Disk (/run/media/scotty/8TB-Elements): 1.30 TiB / 7.22 TiB (18%) - ext4
Local IP (enp1s0): 192.168.20.14/24 *
Locale: en_AU.UTF-8
What if I donβt want output every time I open my terminal?
Might want to update the tutorial with config file changes @scotty65 mentioned above.
Thank you, @Yochanan. I did an edit - hopefully it makes sense. Thanks to @scotty65 and @Pcwolf for their input, as well.
Mya fetchnya looks weird
uwufetch β
replica@dell
β³ β³ β β β β OWOS Myanjawo
MOWODEL Inspiron 15-3567
> Ο < KEWNEL Linuwu 6.6.30-2-MANJARO x86_64
CPUWU Inteww(R) Cowe(TM) i5-7200U CPUwU @ 2.50GHz
GPUWU Inteww COwOpowation HD Gwaphics 620
MEMOWY 2524 MiB/7811 MiB
SHEWW /bin/zsh
PKGS 1361: 33 (flatpak), 1328 (pacman)
UWUPTIME 3h, 7m
ββββββββββββββββ
That didnβt work for me, I donβt know what I did wrong.
I create an configuration file like this located in ~/.config/fastfetch, named config.jsonc, but it gave me only an error:
Error: failed to parse JSON config file `/home/uwe/.config/fastfetch/config.jsonc` at pos 0: invalid literal
what means this?
@anon77480351, you may need to delete the existing ~/.config/fastfetch/config.jsonc before running the command. If you try this and it works, I will edit the tutorial.
Never config.jsonc has been exist before i createt pne. And this one failed.
@anon77480351 In that case, I donβt know why itβs failing for you. Are you able to generate a default config?
fastfetch --gen-config
If not, maybe someone here who is smarter than me will know how to troubleshoot
- or perhaps the developer can help.
The same error message appears then.
I think @scotty65βs concept finally sank in for me, so I just rearranged the instructions to put the config generation first and the .bashrc addition second. I tested this approach on another Manjaro installation and it worked as expected.
fastfetch -l manjaro --gen-config-force will remove the file if it already exists
Thank you @robin0800. Iβve removed the file-deletion step and replaced it with this command.
This is fantastic!
Lot of thanks
