I did.
That’s how I know.
Of course I did not check all 600.000+ lines, just made it down to domains starting with “d” and took some (many) random samples.
… legitimate sites where not uncommon
We have an extremely precise aggregation system that the system must be 85% certain of its decision, then a back checker re-verify and validates whether or not this domain is to be black listed.
Any other domains that are flagged but does not meet specified requirements are all verified manually.
If a “legitimate” domain is blacklisted, there are pretty high chance there’s a very good reason why it is that way.
The original list contained over 2 000 000 domains, but we indeed trimmed that down to 600 000 after multiple verification cycles, a bit like playing elimination.
If one of your favorite domain is blocked, please let us know. Although some in the past claimed some domains that were scammy, that ended up to be their own.
I hope this helped elucidate some questionning you may have had.
I do have a suggestion for improving the installer.
As it is, it is replacing the current /etc/hosts file -
with no backup and thus with no easy way to restore the original. … and no clear notice that this is about to occur …
You/it could,
perhaps even should,
advise the potential user to make this backup copy before running the installer
or
extend the installer to do that by default during the install process, but still inform the user about it.
Next step could be an “uninstall” option.
Of course, the -O option can be used to write the new hosts file to a custom location.
This could be utilized to facilitate easy swapping between original and altered.
