Will HDD also be trimmed while it is not necessary?
TRIM doesnt work on the HDD … enabling the timer will just mean your SSD runs fstrim from time to time.
According to the post below, HDD is also trimmed.
https://askubuntu.com/questions/1297642/is-it-normal-to-have-hdd-fstrimed
Fstrim only works with SSDs.
If you open
man fstrim
and read the documentation you will find that fstrim only tries to discard for devices that supports it.
E.g.
-a, --all
Trim all mounted filesystems on devices that support the
discard operation.
Which essentially means that devices which do not support it are skipped.
For your reference to an almost 3 year old topic - I’d say - either fstrim got smarter or the poster had other issues.
Please heed the warning in the manual
Running fstrim frequently, or even using mount -o discard,
might negatively affect the lifetime of poor-quality SSD
devices. For most desktop and server systems a sufficient
trimming frequency is once a week. Note that not all devices
support a queued trim, so each trim command incurs a
performance penalty on whatever else might be trying to use
the disk at the time.
Another thing to note is
If you do not enable the fstrim.timer - then after some time - depending on your usage - e.g. a lot of ISO files coming and going and the size of your SSD - you will run into mysterious slow-down of your disk - this is the consequence of not running trim - because trim free’s up memory cell marked as in use even the content has been deleted.
This is normal and part of the design - a design that makes it very hard to scrub a SSD device completely for reuse. It this is a topic that interest you the following links are interesting and very educating
- Data-at-rest encryption - ArchWiki
- Securely wipe disk - ArchWiki
- Solid state drive/Memory cell clearing - ArchWiki
This research paper https://www.usenix.org/events/fast11/tech/full_papers/Wei.pdf is an interesting read.
