Hey! Im using the google noto font (emoji) rn, but i want to use twemoji and i dont know how to. i already have them installed, but it isnt working. thanks
If you don’t have any use for noto-fonts-emoji
simply remove it from your system and ttf-twemoji
should take over.
https://wiki.archlinux.org/index.php/Fonts#Emoji_and_symbols
If you want to force the ttf-twemoji
font to specific applications, see here:
https://wiki.archlinux.org/index.php/Font_configuration#Force_emoji_font
If you’re using Firefox, which has a built-in emoji font called Twemoji Mozilla, see the troubleshooting instructions here:
https://wiki.archlinux.org/index.php/Firefox#Font_troubleshooting
nice! it worked, but some emojis is in black & white (like if dont have a font).
if i install the noto-fonts-emoji again, it should replace only these?
I’m not sure if that’s going to work, you can give it a try though.
In case that doesn’t work, there is a package in the AUR called ttf-twemoji-color
https://aur.archlinux.org/packages/ttf-twemoji-color/
Maybe this font is going to work better for you.
this package turn all emojis in b&w, and i am looking for all be colorful
