How to use gnome-remote-desktop?
first
It’s not clickable
https:// forum .manjaro .org/uploads/default/original/2X/4/47879f65f83f1f4b9bf0a11d0cc25d6d4c585b6e.png
(Remove Spaces)
secondly
How to use Gnome remote desktop?
Do you need any extra package?
If you want to use gnome-remote-desktop you can install it by opening a terminal and type:
sudo pacman -S gnome-remote-desktop
I’ve never used it so cant say how to use it friend.
I think that it may require Pipewire for additional functioning. Just have a look at the official doc here:
https://wiki.gnome.org/Projects/Mutter/RemoteDesktop
┌[日 9月 13] iManjaro(づ ̄ 3 ̄)づ susu {~}
└[14:34:52]{9}$ systemctl --user restart gnome-remote-desktop.service
꧁ ༺ ❀ 真心 ༒ 臻馨 ❀ ༻ ꧂
└[14:34:59]{10}$ systemctl --user status gnome-remote-desktop.service
● gnome-remote-desktop.service - GNOME Remote Desktop
Loaded: loaded (/usr/lib/systemd/user/gnome-remote-desktop.service; static)
Active: active (running) since Sun 2020-09-13 14:34:59 CST; 2s ago
Main PID: 50760 (gnome-remote-de)
CGroup: /user.slice/user-1000.slice/user@1000.service/gnome-remote-desktop.service
└─50760 /usr/lib/gnome-remote-desktop-daemon
9月 13 14:34:59 iManjaro systemd[1930]: Starting GNOME Remote Desktop…
9月 13 14:34:59 iManjaro systemd[1930]: Started GNOME Remote Desktop.
9月 13 14:34:59 iManjaro gnome-remote-de[50760]: Failed to initialize RDP server: Couldn’t find the server certificate or private keyfile
꧁ ༺ ❀ 真心 ༒ 臻馨 ❀ ༻ ꧂
└[14:35:02]{11}$ systemctl --user status pipewire.service
● pipewire.service - Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
Active: inactive (dead)
TriggeredBy: ● pipewire.socket
don’t work! why?
