I tried community and aur versions od Cutefish Dock on KDE. But it starts on just one virtual desktop and not showing up on others also does not auto hide but cover bottom side of the screen.
AFAIK the Cutefish Desktop has no Virtual Desktop implementation, hence their Dock will not integrate with a DE that has VD … Also, it requires the Cutefish Settings in order to access the options for Dock.
Latte-Dock was made and integrates perfectly with the DE, but, sadly, the developer stepped out from it. Is that why you try “alternatives” ?
A KDE Plasma Panel can be turned into a Floating Dock and have the same integrated options with KDE Plasma as the Panel.
